Question about Samsung LN-S2738D 27 in. HDTV LCD Television
Samsung lcd hdtv ... no video (black screen)
2 year old tv
Samsung wont support.
Too new to fail but not sure if worth fixing?
Yesterday just quit working. Audio works from DVD but otherwise screen vidro and controls are dead. Looked on iside case. Dont see any problems. Looks ok and all cables secure. No visual problems, etc.
Read online that capacitors can be a broblem... but dont see any caps that look suspect.
Any help is appreciated.
    Top Expert:
  • Samsung Master
  • 75,178 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Jun 30, 2017
  • 395 Answers
SOURCE: Samsung LN-R408D - No Picture
reseat the LVDS cable inside the unit. this is the cable from the main board to the panel. if the problem is still there then replace the main board 1st, part # BN94-00629F. if the problem is still there then the panel is bad, part # BN07-00245A. if you are not familar with TV repair have a tech repair this for you, if it is under warranty call the manufacturer for nearest repair place.
Posted on Feb 26, 2008
  • 11 Answers
SOURCE: Samsung LN-S4041DX 40 in LCD TV
Hi. You can try to go into service mode and reset the LCDTV to Factory Default. This will clear out all buffer over run's and any software related issues. It may fix the problem or it may not. If this doesnt fix the problem than you need to have a qualified Technician to look at it. The problem is in the AV circuit board, a technician who is qualified to repair electronics at circuit board level should be able to repair this problem rather quickly and inexpensively. Most technicians who do not have the expertise in repairing cicuit boards to component level would rather replace the whole AV board than repair it and this will be rather expensive.So talk to the repair shop before you drop the TV off.
Be very careful when accessing service mode. I suggest to write down all information in all areas before proceeding to a factory reset. If you do not record all values correclty you run the chance of not being able to use the TV again. To go into Factory Service mode, use the original remote and in this sequence push POWER OFF-MUTE-1-8-2-Power ON, the set will turn on and enter service mode, if you hit all previous keys correctly. If it doesnt try again. When you are done hit POWER OFF and this will exit service mode and save the data.
Posted on Jan 28, 2009
SHOGUN125
  • 58 Answers
SOURCE: using my Samsung LCD TV as monitor for my Sony Vaio Laptop
yes sir..i think you must looking and buy VGA adapter 15 to HDMI complete with the HDMI cable set. you can find this adapter at the computer spare part store or electronic part store. not cheap but very usefull for you in the next day.
is very easy to connecting...plug you adapter to the output VGA VAIO.. connect the HDMI cable to adapter (like USB) and the rest to the input at your samsung lcd...good luck..
Posted on Jan 31, 2009
  • 3 Answers
SOURCE: Trying to hook compaq presario laptop to philips lcd digital tv
hey fox,
sounds to me like a connection problem. If the compaqs output is vga, you need to convert the input (tv side ) to hdmi, component, s-vidio... what ever you can find. Typically when you hook up your computer to a flat screen or such, its best to try to use the hdmi ports or the rpg. But if thats not available you need to take the outout from your laptop ( whatever type that might be and input it into your flat screen tv. If you input laptop into tv under ( eg..HDMI) then when you VIEW it you need to select the correct source on your flat screen. Such as hdmi or pcmi or rpg.I know that the do sell alot of cables that adapt from one type of connection to another. Typically only one cable is required from the laptop to the flat screen. If you think about it you are only using the flat screen as a monitor.
Posted on Feb 14, 2009
  • 718 Answers
SOURCE: Samsung LNS2641D 26-Inch LCD HDTV lost its picture
Since you have sound on the stations this is a problem in the display. Take bright flashlight and hold it against the screen. Look for an image around the edge of the flashlight. If you see an image then its one of three problems;
1) The inverter board is bad.
2) The CCFT (cold cathode fluoresent light) are bad.
3) The power supply to the inverter board is bad.
Someone knowledgeable in electronics can replace the bad part(s).
Posted on Mar 10, 2009
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
Vizio 47" screen won't stay on
Your Vizio TV may be exhibiting symptoms of power supply trouble even though it is quite new.
Dec 01, 2013 | Vizio E3D470VX 47 in. 3D LCD HDTV
Samsung 27" lcd tv picture goes black, still have
0ne of 3 has failed:
(in order of probability):
1. Backlight inverter
2. Power Supply
3. Backlight
Please seek the expertise of an experienced TV repair technician - as they contain potentially lethal voltages that must be properly discharged before work can begin.
Thanks!(*&^%
Mar 19, 2011 | Samsung LN-S2738D 27 in. HDTV LCD...
OK so i found this Samsung LN-3251D 32" HDTV LCD TV /MONITOR Last night they were throwing it out i brought it home and Plugged it in and hooked it up to see what is wrong with it i found that the...
The LCD screen panel is broken or damage.Not worth fixing,sorry.The LCD screen panel are 90% of the tv.The screen panel,will cost the same as a new tv,to replaced.The tv now,only can be worth as salvage electronic boards for parts.
Oct 06, 2010 | Samsung LN-S3251D 32 in. LCD HDTV
Spider Crack on Display
That 46" LCD panel will caot you more than the TV iself, you can try contacting www.shopjimmy.com to see if he has his panel in stock, you may have to get the information as printed on the label on the back of the panel.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Jul 07, 2010 | Samsung LN46A650 46 in. LCD HDTV
Black shadow boxes on 46 in Samsung 46 in LCD HDTV.
Ur backlight video board is dying,must replaced to solved this problem.Part and labors about $500.
Dec 15, 2009 | Samsung LN-T4661F 46 in. LCD HDTV
Our 4 year old hit the front of our LN -T4061F Samsung set with a plastic ball. It now has a shattered imprint that is black with white shatter marks and ranbow stripes...any chance the repair is less...
Sadly, the screen is the most expensive part of the TV. The replacement screen would cost more than the TV is worth. Shopjimmy.com is the only affordable place to buy the replacement screen, But, they are out of stock. Usually, the screen cost around $250 to $350. Any other website will cost an arm and a leg. Buying a new TV would be best at this point.
http://www.shopjimmy.com/catalogsearch/result/?q=LN+-T4061F+screen
Nov 16, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
Flashing black and white vertical lines
Vertical lines in the display indicate a failing screen. New screens are expensive and not worth the labor and parts charges to repair it. It's new monitor time.
Jul 28, 2017 | Samsung LTN1535 15 in. HD-Ready LCD...
Samsung LN-S2738D 27 in. HDTV LCD Television Logo
70 people viewed this question
Jerry Greenberg
Jerry Greenberg
