Question about Sony STR-DE675 Receiver
Only one speaker working on my str-de675 receiver
The front left speaker output on my receiver is the only one that is working. I can take the speaker wire from different speakers and they only work in the front left. Anyone know what would cause this? Same problem I only have sound out of one speaker. I switch speakers same result. I want to tear into this myself need a game plan
  • 643 Answers
Check your main board witch is under the powersupply. careful the caps hold charge and hurt really bad. check your digtal input board also.
Posted on Jun 02, 2009
Sony's STR-DE675 5.1 Channel Receiver - Speaker OFF problem
There's a button that turns the speakers OFF right above the headphone jack.
Get the manual: retrevo.com
May 21, 2010 | Sony STR-DE675 Receiver
Is the STR-DE675 5.1 Surround Sound Receiver compatible with P.C.
Sure! Any P.C. with an audio output jack, like an 8mm phono jack to stereo for example, can be connected to any audio input on the receiver.
May 13, 2010 | Sony STR-DE675 Receiver
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
HOW CAN I HOOK UP CAVILIER 200A POWER AMP TO A sony str av 770x f
You can pull the Left and Right stereo program from either MD/Tape or Video 2 Audio OUTputs. Run a pair of RCA cables to the Active EQ's Line IN; then the EQ's Line OUT to the Cavalier's Line IN.
If the Tape output you're borrowing the program from is already connected to something, use RCA-cable splitters.
Remember to NEVER activate the monitor for that Tape function during playback of any digital audio source - it disables the digital input; or if the 901's are being used - it will remove the signal to the Cavalier.
Now if you wanted to use the 901's in your movie listening this will work with two limitations
Your receiver doesn't have preamp outputs for Front Left and Right out so you'd be extracting only the mixed-down 2-channel version of whatever the Sony is processing.
You'll have to manually control the Cavalier's volume because the pre-out you're using is BEFORE the Sony's volume control.
It might still be an improvement over what you have now.
Mar 21, 2010 | Sony STR-DE675 Receiver
If the speakers themselves work fine, then the problem lies within the amplifier output. The channels can go bad after hard use, they can be repaired but it may well exceed the cost of the amp if it is not just one channel. Also be sure that you are hooking up speakers that are rated for your amplifier by matching the OHM resistance of the amplifier to compatible speakers.
May 03, 2009 | Sony STR-DE675 Receiver
The front speakers are too quiet
press SET UP :select NORM.SP then is select LARGE .that should do it
Nov 20, 2007 | Sony STR-DE675 Receiver
SONY STR-DE675 RECEIVER
check the speaker's connections, I got them message when a speaker wire was unplugged and plugged back in while the unit was powered on
Oct 02, 2007 | Sony STR-DE675 Receiver
Sony STR-DE675 Receiver Logo
499 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
