Question about Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned
Trimmer head won't turn
The trimmer head on my Ryobi 2800R doesn't spin anymore - motor works fine but the line doesn't turn - I am fairly adept at repairing most things but can't find a manual to see the exploded view for one of these and I don't want to just dive in blind if I don't have to. Any ideas on if this has a shear pin or is it a bad clutch?
  • 1,040 Answers
If you didn't recently take it apart, then it sounds like you have broken the drive shaft in the neck of the trimmer. You can probably find this at an outdoor power and equipment type of store.
Jim
Posted on Jun 02, 2009
  • Jim Parker
    Jim Parker Jun 06, 2009
    Did you solve the problem?
    Jim
Ryobi line strimmer hedge cutter attachment won't cut even though the blades are moving can you give any idea what he problem might be?
grass,string or vines can get wound around the motors shaft, you will need to take off the spinning head to remove debris from motors shaft
Jul 25, 2014 | Ryobi Garden
Powerhead runs but tools (blower, trimmer. edger) won't work.
Hi Jim Kamph...
You have a broken drive cable inside of the trimmer.You will need to replace the drive cable
Please rate me
Bud
Sep 26, 2012 | Ryobi Garden
Ryobi 975R head won't stop turning.
sounds like the idde is to high
Aug 06, 2012 | Garden
Hi, I have a RYOBI ELT1100QFA electric line
electric line trimmers suffer from one major design problem
the motor has phosphor bronze bushes and the bottom bush goes dry from the grass juice and wears out and the armature poles out and lacks power to work
to get 5 years is good but it is time to take it in for a service or junk it and get a new one
Mar 30, 2017 | Ryobi Garden
Ryobi trimmer not spinning, the motor runs fine, I think the friction clutch is worn.
Either the cintrifugal clutch is not engaging(if that model has one). Or the drive cable is snaped, or the rotary head drive lug is stripped. Pull off the drive head(where the nylon cord goes) & behind it is a flexable cable that transmits drive from the motor to the drive head(bobbin).pull it out and see if its broken.Check The rotary drive head lug,its on the top of the drive head (bobbin) you removed.
hope this helps
Regards Andrew Porrelli
Dec 05, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 2800r gas trimmer how to adjust carb mixture?
The are limiter caps and can be removed. Just pop them off and you'll see screws under them (put a small screwdriver around the bottom of cap and push upward and they'll come off).
Sep 26, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi 775r gas trimmer stalling when tilted
You have a air leak between to tank and motor. Could be carb gasket. When using in tilted position you dont have gravity feeded carb anymore, causing air to be sucked into carb. Take off carb and spray with crb cleaner, then blow out with air gun. Replace gasket, make sure all new lines and bulb connections are connected securely.
Jul 17, 2009 | Garden
Ryobi RLT30CES line trimmer head problem
Many small line trimmers lack a clutch system by design so this could be normal.
May 24, 2009 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 15" Electric Factory Reconditioned Trimmer (ZRRY41002) - Factory Reconditioned Logo
716 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
