Question about MSI 865PE Neo2-PFS Motherboard
Ethernet LAN not detect
I have MSI 865PE Neo2-P, ethernet card not detected and if i used LAN Card it's same not detected, i use Windows XP. similar problem here too... my 865PE crashed badly a while back (mostly, but not always, a completely blank screen when I turn it on). I've reflashed the BIOS (downloaded from msi.com), and it seems a little more stable now (still testing). But the LAN no longer works. Might be a physical problem with this model of motherboard. I'll try a PCI LAN.
  • MSI Master
  • 3,606 Answers
Hello download the lan driver from here:
http://www.msi.com/product/mb/865PE-Neo2-P-Platinum-Edition.html#/?div=Driver&os=XP%2032
Try to renew the driver and install the new one.
And check your bios settings for the lan.
Good luck
Posted on Nov 06, 2012
I can't use my USB port
Hi, try to update your drivers from here:
http://www.msi.com/product/mb/865PE-Neo2-PLS--PFS--PFISR.html#/?div=Driver&os=XP%2032
Remember to select the windows system you are useing.
The drriver needs to be unziped before installation.
Try also to run windows update or microsoft update.
The usb driver is in one of the service packs.
Hope this will help you.
Apr 12, 2011 | MSI 865PE Neo3-F Intel 865PE LGA775 DDR...
MSI 865PE Neo2-V Motherboard does not boot to BIOS. It just powers up and the drive lights are on continuously. Is there a replacement MB that uses essentially the same BIOS and won't require re-formating...
This one is pretty much identical
http://cgi.ebay.com/MSI-865PE-Neo2-P-Motherboard-P4-socket-478-EMS-/180572214688?pt=Motherboards&hash=item2a0af155a0
This one is similar but you will need to reinstall a new audio driver
http://cgi.ebay.com/MSI-865PE-NEO-2-Motherboard-Processor-/200552149636?pt=Motherboards&hash=item2eb1d6f284
Dec 09, 2010 | MSI 865PE Neo2-V Motherboard
Driver sound card 865pe neo2-v
Normal 0
You can download the audio drivers from MSI WEB support site, select your model motherboard to download :-
http://www.msi.com/index.php?func=downloadindex
Oct 16, 2010 | MSI : 865PE NEO2-V P4 Prescott/S478/FSB...
My PC with 865PE Neo2-FIS2R doesn't boot on SATA HDD... It actually runs windows server 2000. but after an unexpected power shutdown... the pc always boot on Managed PC Boot... upon checking on the Boot...
Hi Good day!! well i think your board didn't detect your HDD for some reason:
1. unexpected shutdown
2. cable not properly connect in HDD to motherboard
3. HDD have been damage because of improper shutdown.
here are the step to detect your HDD
1.pull out your cable from the HDD and then re-insert it make sure it its inserted properly.
2.go to CMOS and then in the "MAIN menu" check the primary master, primary slave, etc. in the primary master your HDD should be detect there. if not enter your primary master for auto detecting.
if nothing happens and still not detected you must replace the cable of your HDD.
Pls. Reply to help you more
Regards
JR
Oct 07, 2010 | MSI 865PE Neo2-FIS2R (MS-6728-030)...
Can prescott 800 mother support p4 2.4ghz/1m/533 processor
The MSI 865PE Neo2-PLS
Supports Intel® P4 Northwood/Prescott (Socket 478) processors.
FSB 400 (for Northwood only), 533, 800MHz.
Supports up to 3.2GHz or higher speed.
See page 1-2 in your manual. Also see page 2-3.
MSI supported CPU list; http://www.msi.com/index.php?func=prodcpusupport&maincat_no=1&prod_no=569#menu
Main link for 865PE Neo2 platform; http://www.msi.com/index.php?func=searchresult&keywords=865PE+Neo2
Cheers'
Mike
Jan 20, 2010 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
Cant find network driver msi 865pe
Go to MSI web site for your motherboard;
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=569
All three motherboards listed use the same driver.
First driver in the list:
Realtek Gigabit Ethernet Drivers
Hope you find this helpful!
Mike
Dec 12, 2009 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
Ethernet card driver files for prescott s33
www.driverguide.com will help you in a driver searching route. Good luck you may also check MSI website for them too.
Please rate.
Aug 18, 2009 | MSI : 865PE Neo2-PLS P4 Prescott FSB800...
MSI 865PE Neo2-PFS Motherboard Logo
268 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
