Won't run through the washing process.
I have a Frigidaire Tumble Action Washer that was working and now it's not. I've run through the diagnostic procedures supplied with the machine, and I'm getting a communication error. The troubleshooting guide indicates that either the control panel board or speed control board is bad. It says to replace the control panel board first and if the problem still exists replace the other one. I'm interested if there is a fix besides replacing the board, and if not where can I order a new board. Any help is appreciated. Thank you.
  • 121 Answers
Boards can be ordered through Sears Parts
Posted on Jun 02, 2009
LTF2140ES0 washer just beeps three times, wont start
Frigidaire engineers are so smart they programmed it to beep 3 times for door lock problem, draining problem and other problems in the internal electronics and didn't bother to give the users specific info to read off the machine.
Oct 30, 2008 | Frigidaire 14 Cycle Tumble Action Washer
Need to replace water pump in Frigidaire tumble action front loading washing machine. Parts are hard to reach/get to. Is there a step by step for the process available?
After unplugging the machine, turn it around and remove the rear cover, After that all the parts are relatively easy to access and it will be obvious how to replace the water pump.
Feb 13, 2011 | Frigidaire 14 Cycle Tumble Action Washer
Frigidaire Tumble Action Washer buzzing door lock
you might have a damaged door lock mechanism.it might be jammed in the closed position,and should be changed
Feb 06, 2010 | Frigidaire 14 Cycle Tumble Action Washer
Frigidaire Tumble Action washer won't complete the final spin. leaves clothes soaking wet.
Had the same problem and fixed with ease. The problem is with the door lock. There is a secondary locking mechanism that kicks in for the final spin due to the high speed. When the secondary lock goes bad the washer will not do the final spin. The replacement part is under $40 @ AppliancePartsPros.com .
Dec 08, 2009 | Frigidaire 14 Cycle Tumble Action Washer
Fabric softener dispenser won't drain the fabric softener.
Not sure if you already did this, but try pulling the face plates off inside the dispencer and take it to the sink and run very hot water into the "stand pipe" that projects off the back of the face plate to make sure they are clear and no old crusty products are in the hole.. Then put them back in and push down hard and make sure they are fully seated.
If the plates are loose and not seated or clogged, there will be little or no siphon effect to draw the fluids out of the dispenser. At least thats how it seems to work
Also, if you pull the top off the washer, there is an adjustment on top of the dispenser to adjust the dispensing ratios I believe.
I just did that procedure the other day on my machine and the wife said it works good now.
Let me know it it works for you, I was wondering if it was just a coincidence.
Jan 15, 2009 | Frigidaire 14 Cycle Tumble Action Washer
I called in an electrician/plumber - thanks !
Jul 01, 2008 | Frigidaire 14 Cycle Tumble Action Washer
Washing Machines Logo
81 people viewed this question
Top Washing Machines Experts
