Question about Canon CanoScan N1240U Flatbed Scanner
I dont have a cd-rom to install
I have a canoscanN124OU and i don't have a CD-Rom to install it and i really need it. What can i do is it possible to do it without a cd or no. i appreciate the help thanks.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 80 Answers
You can find the drivers at below link. Please choose the drivers/software according to the version of windows you are running on your computer.
http://support-au.canon.com.au/EN/search?canonsearch=1&lang=EN&category=Scanners&series=Scanners+%28Small+Office+-+Home+Office%29&model=CanoScan+N1240U&menu=Download
Please rate this if this solves your problem.
Posted on Jun 02, 2009
Bootmgr is missing
Take one bootable windows cd rom , insert the cd rom in cd rom drive, restart your Laptop , go to bios setup and select boot from cd rom after then save and exit . your Laptop will boot from cd rom . it will take some time , when you will see action prompt , select R ( if your bootable windows cd rom is SP2 ) , select D ( if your bootable windows cd rom is SP3) . if you select R you will be prompt repair consoul , format C:\ then instal windows SP2 . if you select D , you will be prompt delite partition , delite partition C:\ after then select C to creat partition and install windows SP3. either of one windows install like that and problem will be solved. n.b. if you don,t have cd rom drive pls collect USB cd rom drive.
Jul 30, 2012 | Dell Latitude D620 Laptop (Latitude-C620)...
How do i install this drive?
Unplug the power cable from your power supply and open up your computer Don't forget to wear your antistatic wrist band. Determine which drive bay you are going to install a CD-ROM into. You should pick on of the uppermost drive bays. Before you install a CD-ROM, make sure you have the proper jumper settings. Since we are only installing a single CD-ROM, set the jumpers as MASTER. The jumper settings are different for each CD-ROM drive, so consult your owner's manual so you know which pins to cover up. Once you have the jumpers set, install your CD-ROM in the computer's case. How you secure the CD-ROM in one of the uppermost drive bays depends on your case. Some CD-ROM drives have to be screwed into the drive bay, while other cases come with brackets (like mine) to attach to the CD-ROM drive so that it slides into the drive bay and locks in place.
Connect the power to the back of the CD-ROM drive, then connect the ribbon cable to the back of the CD-ROM drive. Your ribbon cable has three connectors, one in the middle and one on each end. The middle connector is a "SLAVE" connector that is used if you would install an additional CD-ROM or DVD-ROM drive.
Connect one of the end connectors to the CD-ROM drive, and connect the other end connector to the appropriate spot on your motherboard. Note, hard drives and CD-ROM drives have the same style of connector on the motherboard. You want to connect your CD-ROM drive to the motherboard slot that isn't red or is the highest numbered of all the IDE slots.
Power on your computer after you plug it in. Your computer should recognize the new CD-ROM. If it doesn't, Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver
Hope this helps
Jul 04, 2011 | LG GH22NS50 22X DVDRW SATA Drive OEM...
I dont have a dvd driver only a cd rom one and when i put a dvd in nothing happens
The reason behind that is because the CD ROM cannot read DVDs. If you want to play or install DVD based programs you need to replace your CD ROM with a DVD-ROM or DVD-RW. You also can purchase an external DVD ROM if you dont want take that CD ROM from its place.
Rating my assistance will greatly be appreciated. Thank you for choosing Fixya!
Jan 22, 2011 | Computers & Internet
I'm trying to install a PC-DVD Game to my LG CD-ROM CRD-8521B, It plays CD's but wont play DVD's of any sort. Really need help...
The CD rom is limited to CD's. In order to read a DVD, you will need to install a DVD rom. My suggestion is to get an external DVD Burner - i just bought a Samsung slim external DVD burner that reads / writes CD's and DVD's.
You will have no luck ever reading a dvd in a cd rom.
May 19, 2010 | LG CRD 8521B Internal 52x CD-ROM Drive
Cd-rom drive broke , need to replace but dont know what will work
YOU CAN GET A ROM OFF OF EBAY, NEWEGG.COM OR WHAT I ACTUALLY SUGGEST IS BUYING AN EXTERNAL USB CD/DVD DRIVE. THEY ARE STILL AVAILABLE DON'T BELIEVE ALL THAT NONSENSE.
yep i just looked on newegg.com you can buy them brand new for $18.00 with cd and dvd or just cd
Mar 31, 2009 | Sampo DVE-620 DVD Player
SATA hard dive replacement
very much possible.insert yr vista cd in yr cd/dvd rom drivethen on yr system go to bios setting make sure first boot device is cd rom. then boot uy system it will ask u to press any key to boot from cd rom. so now press any key on yr key board and the rest is don by the vista all u do is just selct options like language when it ask u or say registration key. then to an extend, it will restart or ask u to press enter to restart. after restarting u dont have to press any key to boot from cd rom again plz take note. if it ask u to press any key dont press after a while it will then boot and continue from where it stopt last. so u just seat back n watch it install.
thank u
do rate this if it worked for u
May 28, 2008 | Computers & Internet
Cd driver
CD-ROM driver help CD-ROM drivers, helping you load your CD-ROM drivers on PC computers, listing what to have in the autoexec.bat / config.sys, listing different drivers .
Computer CD-ROM drive help and technical information. Complete technical help and support dealing with computer CD-ROM drives.
Good Luck if this dont do it for ya, re-install your computer back to the factory setting.
Please dont for get to Vote, Thank You.
Dec 26, 2007 | Acer Aspire 5100-5033 Notebook
Cd-rom
CD-ROM not working in Windows 9x, 2000, or XP. If after cleaning the CDs that do not read you're still getting errors ... If, however, the CD-ROM does not work, refer to the next and final possibility
CD-ROM recieving power but does not work. CD-ROM receiving power but does not work. Issue:. CD-ROM receiving power but ... CDs are read by a laser within your CD-ROM drive
Good Luck/Please dont for get to Vote, Thank You.
Dec 15, 2007 | Acer Aspire 3610 Notebook
Cd rom
Where can I get the driver for my CD-ROM?
Visit our hardware download section to obtain a generic CD-ROM driver (oakcdrom.sys) and mscdex.exe if needed.
If you are looking for a specific driver for your CD-ROM drive or a Firmware update, please see our CD-ROM driver page.
Dont for get to Vote / Merry Christmas.......Good Luck!
Dec 06, 2007 | Computers & Internet
Boot cd-rom type:cd-rom/non-emulation booting
No, it's because Microsoft changed the way boot CDs work with SP2. You need an old CD (Windows XP SP1). I had the same problem here, notebook without floppy, it won't boot from the newer XP version CDs (SP2 or SP3) - but an old SP1 CD works!
(Those were all original Microsoft CDs, and the SP2 / SP3 CDs boot just fine on several other PCs I tested. It's just that some old hardware has a problem with the boot mode used on newer Windows CDs.)
Sep 20, 2007 | Computers & Internet
Canon CanoScan N1240U Flatbed Scanner Logo
312 people viewed this question
old marine
old marine
