Drum does not spin in spin cycle
DRUM DOES NOT SPIN
THANKS FOR THE INFORMATION IT WAS THE SWITCH THAT IS PUSHED OWN BY THE LID FIRST I TWISTED THE WIRES TOGETHER THEN NOTICE I HAD THE LID ASSEMBLY FROM MY MAYTAG MACHINE I TOOK THE SWITCH A LOOSE AND PUT IT ON MY WASHING MACHINE AND CONNECTED THE WIRES TAPE THEM AND THANK GOD I CAN WASH CLOLTHES, MY WHITE WILL BE REALLY WHITE AFTER 3 DAYS IN BLEACH WATER! THANK YOU GUYS SO MUCH!
Posted on Jun 03, 2009
  • 10,865 Answers
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Jun 02, 2009
  • Joe Hogan Jun 02, 2009
  • 121 Answers
Check timer motor or clutch assbly
Frigidaire topload washer inner drum not rotates during wash cycle
inner drum is not supposed to rotate . just the agitator .spin cycle is when that will rotate
Sep 28, 2016 | Frigidaire Washing Machines
On spin cycle sounds like change or rocks spinning around in drum.
Could be a bad bearing or something loose on the drum that doesn't rattle until you get up to spin speed. Look for something like pins, nails or screws stuck in the holes of the drum, or possibly under the protuberances (fins) inside the drum. Does the sound occur all through the spin cycle or only at top speed?
Jul 08, 2015 | Washing Machines
Hi, I have an Amana front load washer NFW7200TW that will go through entire cycle but won't spin- cycle ends and clothes are very wet. Unlike the other posts I read, mine shows no error code nor does the...
I have a similar problem with a Kenmore top loader washing machine.It turned out a problem with the main shaft of the drum; it wears out and caused drag on it. at one point i installed a washer or spacer between the shaft and drum it worked for a while and the problem came back again. it is a mechanical problem and it is present with other brands that share the same drum and shaft.
Finally I end up buying a different brand this time a LG .
Mar 08, 2015 | Amana Washing Machines
Drum shakes during spin cycle
I have a 7 year old duet washer. It started to shake during the spin cycle. It is level and the shocks and springs holding the drum are working. When the washer gets to the spin cycle, it is apparent that the drum is off center.
I tore the machine apart and found that there is a bracket at the back of the drum. This bracket sits in water so it was covered in slime. I found several large cracks in the bracket. Once these cracks occur, there is now way the drum can spin correctly. The bracket is welded to the back of the drum, so it has to be completely replaced.
What a poor design. I would guess that many, many other people will be seeing the same problem within a couple years. I was lucky in that I did not pay for a repairman to try to fix it.
Oct 05, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer won't spin. Belt is slipping. Tub is stuck.
The belt sounds worn out since its slipping. Change it out. Its cheap fix.
The drum brake does just what is sounds like. brakes the drum. For instance when u open the lid during a cycle and everything stops thats the drum engaging and stops the movement of teh drum. If the brake is malfunctioning two things will happen, you open the lid (assuming the safety switch is still good) or the drum will not spin at all.
Aug 24, 2009 | Maytag LAT3600A Top Load Washer
Ariston Margarita 2000 NOISY spin cycle....
Remove drum drive belt, and spin drum by hand, if there is any resistance,. or it feels rough or noisy, the the main bearigs have probably failed.
If it is o/k then check motor for worn or noisy bearings,
Please rate my solution.
Thanks.
Jul 24, 2009 | Ariston Technologies Ariston AWD12 Front...
My LG TROM wash googd but dosn't want to spin
Check and see what type detergent you are using. I bought regular liquid detergent and the machine began making noise during the spin cycle and the drum would not spin. I was informed that you have to use detergent that is labeled HE (High Efficiency). The regular liquid detergent will suds up during the wash cycle which then causes the drum to slip and not spin during the spin cycle. What you are hearing during the spin cycle is the drum slipping. Unplug your washer for 30 minutes and let it reset. This lets the suds dry out. Run a cycle with no spin to rinse out the drum. This should eliminate your problem. If you have clothes in the machine, run a cycle with no spin, just don’t add any more detergent. Then run the normal cycle with spin a second time with no detergent. I hope this cures your problem.
Apr 11, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Washing Machines Logo
476 people viewed this question
Top Washing Machines Experts
