Question about Logitech 931249-0403 Mouse
My Logitech V220 optical cordless mouse suddenly quit working. I thought maybe it was the battery so I replaced it, however it still does not work. I've only had it for 3 months. When I try to use it after putting in the USB it does not move, even though the light will come on briefly. Ok, I'm thinking that I'm an idiot but really not. Replaced batteries (2) AA batteries into mouse, clicked the connect button on the remote and then clicked both power and reset buttons on the mouse. Nothing happens. I went out and bought a second set of batteries thinking the ones I bought were bad but no, it still won't connect. HELP I need my laptop.
    New Friend:
  • 24 Answers
Your laptop may be lacking the driver for the mouse or the mouse sensor might be spoilt
Posted on Apr 08, 2017
SOURCE: optical mouse quit working on my notebook
How to synchronize Logitech® Cordless Mouse to Receiver?
The term 'synchronize' refers to connecting a non-Bluetooth wireless device with its receiver. In the case of the Logitech® Cordless Mouse it uses a 2.4GHz Micro-Receiver that does NOT have a connect button for synchronizing/connecting the mouse. This is because the mouse and receiver are pre-synchronized at the factory. If the mouse and receiver ever lose connection for some reason, there is a utility, called the Connection Utility that will re-establish the synchronization between the device and its receiver. SetPoint 2.40 or higher is required in order to use this utility. You can download SetPoint and the Connection Utility from www.logitech.com. It is suggested that you save the file(s) to the Windows desktop or somewhere you can find them easily. If you have already installed Setpoint 2.4x, the Connection Utility will be located on your hard drive at the following location:
C:\Program Files\Logitech\SetPoint\logitechconnect.exe or click on Start/Program/Logitech/connect utility
In order to use the Connection Utility, please double click the Connection Utility icon and then follow these instructions. Please note that a message stating "To connect your device, press the connect/reset button on the bottom of the device" may appear during this process. Disregard this message and do the following:
Connect receiver to the USB port on your PC
Put a charged battery in the Logitech® Cordless Mouse
Run the Connection Utility (logitechconnect.exe)
Click the mouse left button and keep it pressed until told to release it in the following steps
Press the reset/power button under the mouse briefly (do not hold the button as it will turn the mouse off.)
Click the right mouse button 5 times
Release the left mouse button
The Logitech® should be resynchronized with the receiver within a few seconds.
Posted on Feb 26, 2008
IrishDruid
  • 2712 Answers
SOURCE: Cordless mouse V220 Download
Try this link:
http://www.logitech.com/index.cfm/428/3295&cl=us,en
Should work..:)
Cheers
Posted on Apr 17, 2008
frcs68
  • 1605 Answers
SOURCE: Logitech cordless V220 Battery compartment - can not open.
push on the little button at the bottom of the mouse and slide the top bottom half of the cover toward you. The mouse require 1-AA.
negative of the battery towards the left click button.
Posted on Jan 30, 2009
  • 38 Answers
SOURCE: logitech V220 cordless mouse won't work
The V220 is a quite nice rodent, my favorite. Check 3 things.
1) Is the battery facing the right way? Minus end goes in first. Green LED should turn on for a few seconds after the battery is installed.
2) Is the mouse ON? The switch under the mouse is supposed to turn on automatically when the receiver is removed. This does not always work.
3) Unplug the USB Receiver. Connect it to a different USB port. Run the Logitech Connect utility.
If the mouse still does not work, uninstall the Setpoint software and reboot. It is possible that the driver did not install correctly. After reboot, try Step 3 again.
Setpoint software is only needed if you want to use the wheel click or horizonal scroll features.
If all else fails, try installing your V220 on a different computer.
Posted on Jun 01, 2009
  • 3278 Answers
SOURCE: Logitech V220 Cardless Optical Mouse is not working
As long as you have installed the mouse driver, you have done everything possible ... the mouse is faulty.
Posted on Jun 25, 2009
My V220 wireless mouse has just stopped working after I changed battery. It just will not connect. Only had it about 3 months
Two probably blunt/stupid answers, but you'll never know:
* is the new battery really full?
* is the new battery properly seated (mind polarity...)
Aug 11, 2010 | Logitech V220 Cordless Optical Notebook...
V220 worked for years. Just quit. Replaced battery, went through mouse reset procedure & download. Still does not work, battery is good.
Seems that removing the laptop battery & getting a simple reboot, was all it needed. Thanks for the quick responses from you.
Feb 15, 2010 | Logitech V220 Cordless Optical Notebook...
My logitech V220 optical mouse won't work, I changed the batteries.
Hi three, uninstall the Logitech V220 Cordless optical mouse driver from the laptop and then restart the laptop again. Now install that Logitech V220 Cordless optical mouse driver again . I am sure its will start working. If not then make sure your batter Is properly fixed inside in the mouse & that's fully charged. After those thing if still not working then visit service center, because the mouse censer stop working and its damaged.
Thanks & waiting for your feedback.
Feb 09, 2010 | Logitech V220 Cordless Optical Notebook...
Jun 25, 2009 | Logitech Cordless Mouse
Logitech v220 cordless mouse - worked fine for 6 mths - recently changed battery. worked fine. today, would not move cursor when on a white / light surface (although it has previously just fine). It...
Most opticals do not track on smooth white surfaces. It needs textures or color. Try pressing the "CONNECT" button on the bottom of the mouse and on the remote sensor.
Jun 17, 2009 | Logitech Cordless Mouse
Logitech V220 cordless mouse won't work
Mar 01, 2009 | Logitech Cordless Mouse
Download software
This is the link to the donwload page of Logitech V220 cordless notebook mouse SpinPoint software. Pick an OS and a version (32bit or 64bit OS) then donwload.
http://www.logitech.com/index.cfm/428/146&cl=us,en?osid=1
Please rate.
Feb 23, 2009 | Logitech V220 Cordless Optical Notebook...
Cordless Optical Mouse Not Working
you need to connect it back to the reciever, everytime you connect the mouse on the bottom it will be looking for the reciever to connect to. Try pressing the connect button on the reciever first then the connect button on the mouse
I hope this helps
Nov 15, 2008 | Logitech Cordless Mouse
Optical mouse quit working on my notebook
Look in device mgr and make sure port is "always on"...accordianman
Jan 21, 2008 | Computers & Internet
Logitech 931249-0403 Mouse Logo
142 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
