My L7 does not ring or vibrate when a call is coming in. If I am looking at the phone's display, I will see a call is coming in. However, even though I have the phone set to the "Vibrate and Ring" option, it does neither when I am receiving a call. The phone still plays the ring tone when I am in the settings, however it does nothing when I am receiving calls. I have since changed the ring setting to "Vibrate" and it now vibrates when I receive a call or text. This problem recently started happening, and the phone was working fine before.
Iphone: If you set the iPhone to vibrate in silent mode, it still makes an audible buzzing sound that may bother or disrupt others. If you need your iPhone to stay completely quiet, temporarily disable vibration. You can turn off vibration when silent mode is on, off or both. Tap the button next to "Vibrate on Ring."
Blackberry: Turning vibration on my mobile phone on or off
Find "Notifications" Slide your finger down the display starting from the top edge of your mobile phone. ...
Turn vibration on or off. Tap the indicator next to Vibrate to turn the function on or off.
If you're missing incoming phone calls due to your iPhone not ringing, you may have accidentally switched the ringer to vibrate or silent, according to Apple. The switch on the left side of the iPhone turns off the ringer and usually sets your phone to vibrate mode, but if your iPhone's vibrate setting is also disabled the phone will instead be set to silent mode. When in the phone's sound settings vibrate mode can be enabled, and the ringer volume of your phone is adjustable.
hi :)
here i can advice u send phone for technician.
cause moto much model has screw lock the housing,if no tool,u must give it repair by technician.
cant hear the ring,cause of drop,normal is the speaker lose in the right position for detect with mother board.so,it cant ring :)
please give me rank if my solution useful,thanks..
This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
take the phone and have it check the board could need reflashing...but you still have not explain in detail why and how the phone's ringer just stop working.
