Question about Samsung SGH-x427m
Keys won't work
I was just literally using my phone and now my keys won't work.  I took out the battery and put it back in, used the "end call" key to power my phone on, and that works.  However, once the phone is on, the keys no longer respond, including that one.
  • 1 more comment
  • Anonymous Nov 29, 2007
    I have the same problem.
  • af7h Feb 17, 2008
    I have the same problem as aubs5 has
  • keditimdola Oct 19, 2008
    I have a V9 phone was outside the rain for two days. After that I charged it with the wall charge then the keys is broke...don't know what to do ..
    Problem Solver:
  • 4 Answers
Try taking out your sim card and letting the phone rest or try plugging it in to the wall and charging it
Posted on Jul 19, 2008
Tip
How to reset Kyocera Zio m6000
Soft reset
Dial: ##4357*
Select view
Scroll down to select reset.
6 digit code: 000000
Click Ok
Should reboot.
Dial *228
Hard reset
1. Power down the phone
2. Hold down the volume up, end key, trackball and send key simultaneously.
3. Phone boots. After it vibrates you let go.
To reset Kyocera Zio try the following:
1. Remove battery and put it back after two minutes
2. Press and hold down the home button key while turning on the phone.
3. If by chance the phone starts , do Menu Button > Settings > SD Card USB MASS > Factory Data Reset
If it does not work, try:
Hard reset 2.
1. Power off the phone.
a. Press and hold red END key for 2 seconds >> Phone Options >> select Power Off >> Phone will shut down >> Ok
a)
2. Remove battery for 15 seconds & replace battery.
3. Power up the phone.
a. Press and hold red END key for 2 seconds and wait until the device powers up completely.
b)
4. Power off the phone.
Procedure, cont.
5. Press and continue to hold the Volume Up button using your left thumb.
6. While still holding the Volume Up key, use your right hand to depress the green Send key, the white Track ball and the red End key (sequential order).
7. Continue to hold all 4 until keys completely down until the handset vibrates twice then let go of the keys & track ball.
a. Formatting Data and Cache appears
1. If you do not see the above (Formatting Data and Cache) redo steps 1 through 7.
2. If you get a Fast Boot, Self Test or Blue screen redo steps 1 through 7.
3. Allow the phone to completely reboot. This may take a few moments.
4. The phone has now been re-set to factory default settings. Please proceed through standard set up and activation procedures.
If still no luck, call Kyocera directlyand report the problem.
on Sep 03, 2010 | Cell Phones
Sprint zte fury touch screen unresponsive..any solutions?
Your touch screen didn't like "touching" your "really sweaty" chest! Te oils from perspiration are playing havoc with the screen. Use some rubbing oil on the screen with a soft cloth to remove the oils.
Jan 13, 2013 | ZTE Fury - 4gb - Black sprint Smartphone...
Lenovo P650WG Phone Won't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 04, 2012 | Cell Phones
I put a lock code on my phone and forgot the numer
use code
*#7328748263373738# to reset security code to default.
Default security code is 12345
for expert choise
hard reset your phone:
1. Switch-off the phone (Remove the battery and re-insert it, if necessary). Now Press and HOLD the GREEN (Call) key, RED (Call end) key and the Camera-capture key SIMULTANEOUSLY. While still pressing the above three keys press the power On/Off key, hold them until phone boots up.
2. Nokia N97 and N97 mini - Press and HOLD the left shift key, spacebar key and the back key simultaneously. While still holding the above three keys, press power-on key, hold them until the phone boots-up.
NOTE however that the format will erase all the data in phone memory and you will also lose your free music that came with the phone. Also make sure to fully charge the phone's battery before the format process.
Mar 12, 2011 | Nokia 5800 XpressMusic Smartphone
Samsung Blast Power Button No longer Works.
that happened to me after i dropped it in the toilet. if you pry up the keys around it aswell as the power key because they are all connected and push really hard on the silver thing it will turn on. then just push the keys back in place. trust me it works!
Jul 13, 2009 | Samsung Blast Cellular Phone
Blackberry 8900 - phone is on but keys don't work
I think the keypad of your phone is not working. You may need to replace it. Hand it over to a skilled person to do the job
Jun 17, 2017 | RIM BlackBerry Bold 9000 Smartphone
Headset mic doesn't work
Disconnect the all lines and power
Remove battery of the headset
Put battery back in
Connect phone line
Connect power cord
I am trying this according to Thomas 800-511-3180
Jan 16, 2008 | RCA 25110RE3 Phone
Samsung SGH-x427m Logo
64 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
