Question about Danby DCD5505W Electric Dryer
Danby Dryer too hot
Danby dryer M# DCD5505W has a temperature problem. It will burn the clothes! but if we restart the dryer it won't dry them at all, its totally random. It sounds like maybe the tstat is no good or the sensor. Any ideas?
  • 121 Answers
First of all, check to see if you have a hose going outside that is fully clear of lint from beginning to end. then check to see if your heat is staying the same on a empty load run machine empty, then turn your thermostat to cool after it heats up and see if the temp went down to see if working properly.
Posted on Jun 02, 2009
I have a Danby Clothes Dryer Model #DCD5505W-1. The dryer works but will not heat. Is there a reset button? If so, where is it located?
More than likely the heating element has burned out or the control circuit board. There is no such switch as a reset.
Jan 24, 2017 | Danby Dryers
My danby dryer keeps shutting off and turning on and the clothes take forever to dry
GOD IS STILL GOOD !!!!
ELECTRIC Dryer no heat or little heat, or shuts down to fast:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective or has a short if its grounding out? Which in turns causes blown fuses or thermostats or overheating.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.html
Sep 09, 2014 | Danby DCD5505W Electric Dryer
Dryer gets too hot on regular laundry setting but seems to work ok on delicate laundry setting.All vents and filters are clean.When using regular setting when drying is done the clothes are too hot to...
The cycling or operating thermostatis often the problem when a dryer runstoo hot, but there are also other things that can make it run hot also.
Here is a tip that I wrote that gives more details about why a clothes dryer will get too hot.
Clothes Dryergetting too hot
heatman101
Aug 06, 2011 | Danby DCD5505W Electric Dryer
Dryer pauses several times and takes 6 hours or more to dry it does not heat.
so it is drying clothes but is taking forever:
http://www.applianceaid.com/dryertip.html
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
so the dryer is not heating:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
these should fix the problem Good Luck Tim
Feb 19, 2011 | Danby DCD5505W Electric Dryer
Danby dcd5505w clothes dryer is not heating
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Nov 21, 2010 | Danby DCD5505W Electric Dryer
Searching for a Danby Dryer belt
appliance parts pros 1-877-477-7278
Oct 31, 2009 | Danby DCD5505W Electric Dryer
My dryer is not producing heat? not drying clothes - all switches on
I'm not 100% positive, but I would say your heating element is out as being the most likely culprit especially if you have kids and do alot of laundry as I do.
Oct 17, 2009 | Danby DCD5505W Electric Dryer
Dryer isn't heating properly, clothes are not drying in one cycle...takes 3 cycles
this is usually indicitive of a clogged vent
goto the place where it exhausts and see what kind of air you feel while the machine is running
if you cant feel any or very little
you need to clean your vent or have it replaced
Oct 08, 2009 | Danby DCD5505W Electric Dryer
Dryer belt PH 1930 for danby model dcd5505w-1
Call Danby Customer Service at 1-800-263-2629; The part costs $25 or so plus another $7 shipping. Better than getting it through a distributor, I was given a price of $40 through a local place.
Oct 30, 2008 | Danby DCD5505W Electric Dryer
Danby Dryer DCD5505 starts and stops continuosly
ITS COMPLETELY NORMAL!!! THATS HOW IT WORKS.
Oct 23, 2008 | Danby DCD5505W Electric Dryer
Danby DCD5505W Electric Dryer Logo
166 people viewed this question
Top Danby Dryers Experts
Tim Whalen
SHARCNET-USA
SHARCNET-USA
Are you a Danby Dryer Expert? Answer questions, earn points and help others
