Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Whirlpool refrigerator leaking from top of unit
Whirlpool refrigerator model # ET22RKXGX02; This is a top mount with the freezer on top. I have a problem with water filling up in the refrigerator and it looks like it is coming from the freezer in the back, inside of the unit. This is driving my wife crazy. Any help out there?
Listened to other posts and figured drain plug was clogged. It was with ice. Removed bottom pan and back panel of freezer, removed ice on bottom, put hot water in drain to thaw ice until it flowed into pan underneath fridge. Thanks for the ideas.
Posted on Jun 04, 2009
Leaking inside back of refrig
If this is a top mount refrigerator (freezer on top), more than likely the drain is frozen. Try defrosting the unit for 24 hrs.
Jan 01, 2014 | Whirlpool Refrigerators
My fridge is leaking water from the top shelf down to the bottom and onto the floor
You most likely have a clogged defrost drain tube in the freezer, this diverts water through the damper into the fridge section in units with the freezer on top... Remove the back wall of the freezer and look beneath the tubing and you will see an ice pad... Use a turkey baster and warm water to reveal the drain hole, then force warm water down it until it is clear... Have some towels handy. Whirlpool Refrigerator Drain Strap 819043
Nov 09, 2013 | Frost Inglis 17.6 Cu. Ft. -Free Top-Mount...
Top freezer of whirlpool frosting up bottom notgetting cold
If your fan motor is blowing then I would say you have a defrost problem. How about a good old apartment top mount ice box manual from whirlypool?
TOP MOUNT REFRIGERATORS
Nov 06, 2009 | Whirlpool (ET8FTEXSQ) Top Freezer...
Water is leaking from under the freezer into the refrigerator section, Is there an easy fix for this.
This is a common problem found with that model. Link below shows you how to solve it. It appears with what you said is the water is coming from the freezer compartment. If so then it can come from 2 things. A frozen defrost/cogged drain or your ice maker is leaking. Let me know how to refine your problem closer. Thanks, Sea Breeze
kitchenaid-top-mount-refrigerators/">http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
http://appliancepartsandtechnicalservices.blogspot.com/
Jun 15, 2009 | GE Profile Arctica Stainless Steel Top...
Whirlpool Refrigerator ET21GM LEAKING water ALL OVER INSIDE
there is a drain under the coils in the freezer. it is frozen and the water has no place to go. hairdryer and a lot of patience. a hairdryer can melt a freezer /warning.
Jun 09, 2009 | Whirlpool ET1MTKXKQ White 20.9 Cu. Ft....
Interior water leak on model ET18PKX6HB1 whirlpool refrigerator
The drain is clogged up. Check the clear plastic line that goes from the back to the drip pan on the bottom of the unit.
Mar 30, 2009 | Whirlpool Refrigerator Inverter Box -...
Model ET14NKXEW00 Top freezer 1996 model Whirlpool refrigerator
Water from the melted evaporator frost is normally drained down to a pan mounted on the compressor . The heat from the compressor is normally enough to vaporize this water. Sometimes the evaporation may be reduced due to- high humidity (in the kitchen). Try keeping the exhaust fan on for a while. Also check if the drain line is blocked or shifted out of the drain pan.
Oct 24, 2008 | Whirlpool ET0WSRXML Top Freezer...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
404 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
