Question about Canon imageRUNNER 5020 Copier
Canon NP 6030 dark copies
I cleaned glass and mirrors , no help, just replaced drum 3mo. ago.
  • 4 more comments
  • surfax Oct 25, 2007
    How do I get into service mode to change drum voltage?, all glass clean even slit glass
    do's it have a lamp regulator VR adjustment ?
  • surfax Oct 26, 2007
    The transfer roller and charge roller all have been cleaned.
    The copies gray , you can manualy lighten the copies , but need to fix
    I need to know how to adjust the drum voltage in service mode !
    what buttons to push, how do i enter a negitive number (-)?,
    how do i enter the number ?....
  • Lacey03 Nov 12, 2008
    I have Black streaks on all my copies
  • Anonymous Mar 13, 2014
    i replaced the drum unit and now the copy button does not light up
    so i cannot make copies
  • 62 Answers
Have you cleaned the slit-glass located behind the drum? Its a thin piece of glass that is about the length of a drum assembly. Check that the drum voltages on the drum label have been correctly installed. Perform a AVPC in service mode to set the primary charge value.
Posted on Oct 24, 2007
Where free download service manual np6030
Posted on Mar 31, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Canon Master
  • 1,362 Answers
Did you adjust the drum?
the 6030 you have to adjust the drum when you put a new one in, there are some numbers on the drum on a sticker and you need to adjust to that number or close to it.
  • 2 more comments
  • CheckitRight
    CheckitRight Oct 25, 2007
    Open front door and cheat it to turn back on, there is a small hole on the left side by green fuser knob put in a paper clip and you will be in service mode.
  • CheckitRight
    Yes it has a lamp reg adj. in  the service mode but I doubt it will help.
    Did you adjust the drum when you put it in?
    I used to get 70k copies out of my drums every single time before having to change them.
    Do these steps:
    1- adjust the drum to what it says on the sticker (of the drum)
    2-takre out the transfer roller and wipe it with a lint free cloth
    3-well....... I'll get back with you after you've done those
    howw dark are the copies anyway?
  • CheckitRight
    CheckitRight Oct 26, 2007
    You still did not tell me if you adjusted the drum?????????
  • CheckitRight
    It has been a long time since I've worked on it but you can download the manual which will be handy for you since you have a 6030 copier.
    I usually post only free downloads, but could not find the manual off the web.
    http://www.2manuals.com/product_info.php...
  • 77 Answers
If your CCD is getting weak that will cause dark copy.Drum voltage may be off.Any other problem would bring a error code up.
In my ir3300 xerox in very light if any setting is there make to dark print?.... what is the setting can u help me ?plz
Check your drum. if drum is ok clean the laser unit and clean the drum unit and chraging roller.
And clean the laser scanner lamp and the Mirror.
You must alert while cleaning the mirrors(Reflectors) don't use thinner, alcohol and stain removers for cleaning scanner lamp and mirror don't do that to movements the reflectors just open the copy board glass and clean with a cotton.
Jun 26, 2016 | Canon Ir 3300 Black & White Copier
I CHANGED THE TONER AND DRUM, WHERE ARE THE MIRRORS AND GLASS ON SHARP 1551-CS
Does this happen when you print!! Not copy. If it does when you print might check the transfer roller and or transfer & sep assemble across from the drum. If printing is OK then clean the glass on/inside the doc feeder you will see it follow the paper thur the doc feeder
Nov 21, 2015 | Sharp AL-1551CS Copier
I have a Canon NP6230 copier that I am having trouble with.
I beliwe I allready answered that question too, a while ago,but anyway...You has to clean plattenglass,optical system and mirrors.How many copies did drum made? If more than 100000 you'll probably got to change it
Oct 09, 2014 | Canon NP 6230 Copier
What is causing dark lines on all copies?
probably the drum unit needs to be replaced,but first I'd clean optic,mirrors, glass,developing unit ,fixing unit...
Oct 01, 2014 | Canon NP 6230 Copier
Change drum kit
Remove the old drum unit,remove the drum and the drum cleaning blade,clean the charge corona wire and grid,install the new drum and drum cleaning blade,clean the image transfer /separator corona wire,clean the optical parts(mirrors ,lens,glass)clean the AIDC sensoe located under OPC drum,reinstall the drum unit in the copier,enter in the technical Rep mode,place 5 sheets A3 paper on the original glass and perform F5 AIDC sensor(Auto image density control).
Mar 19, 2013 | Minolta EP4000/5000 CS/PRO Copier
My canon np 6030 copier is printing faint copies what could be the problemmy canon np 6030 copier is printing faint copies what could be the problem
clean the optical system i.e.first mirror,second mirror,reflector,lens etc to get dark copies.
checklife of photoconductor drum if it is over replace the drum.
Jul 26, 2011 | Canon Office Equipment & Supplies
How can I reduce the darkness of the copy? because I tried to reduce the darkness by the outside adustment but also still dark>
Do you know when the drum unit was last replaced? How about the last time the optic's were cleaned? You may be able to fix it your self by cleaning the mirrors in the optic's. If you feel brave...... It is easy to do. If so, follow tese simple steps. Turn the copier OFF and unplug it from the wall. Remove the two screws on the right side of the copy bord glass and remove the plate and carefully remove the glass. Once that is done, gently slide the mirrors over to the right a bit. Then take a dry & clean & soft rag and gentle wipe the three mirrors off. Basicly, to get the dust off. Return the copy board glass & plate & plug it back in and turn it "on" and make a copy. It should come out better. If not you may need a new drum unit. Good Luck
Feb 23, 2011 | Canon NP 6035 Copier
Poor output
meaning light copies? if so the mirrors need to be cleaned also, the innner optics/blanking assy, and the **** dustproof glass...still problem? check you r drum age and the number of copies if it is more then 5 years old and over 35-40 thousand copies i would replace it...
Mar 29, 2010 | Canon NP 6035 Copier
Black streak at center of page; LP238C is model of the lanier copy machine
Problem could be on the Glass or Mirrors.
Also could be the blk drum unit
Print out a counter page.
If the line is present clean the charge roller in the drum unit
If it is not present clean the glass and mirrors
Good Luck
Mar 03, 2010 | Lanier UNKNOWN
Canon imageRUNNER 5020 Copier Logo
1,355 people viewed this question
old marine
old marine
