Question about Uniden DXAI5188-2 Cordless Phone
No Dial Tone
In my home i have 3 cordless phones that have been working for about a year and now all of sudden there is no dial tone and when you try to call the phones dont ring. They are hooked up properly and ive tried to disconnect and hook it back up, but still no dial tone
    Problem Solver:
  • 5 Answers
Dear Sanyte1226,
Double Check that all handsets are registered, and make sure that you don't have to many phones connected to the jacks throughout your home. If all fail, very slowly, make sure the phone is on speaker, and slowly move the telephone port into the jack SLOWLY like slower than slow motion. If you here clicking, keep pushing it in slowly until you here a dial tone. I know this has happened to me before.
Best of luck, The Writer.
Posted on Jun 02, 2009
Continuous dial tone on phone line . When i try to dial out- i just get a continuos dial tone- happening on my 2 cordless, landline is fine. Dont use a magic jack, changed out hardware, new cordless dont...
There are two possible answers to this problem. The first thing is to check on the cordless phones, is a 2 way switch, one setting is for DP=Dial pulse (setting for old rotary phones) 2nd setting is TT= Touch Tone. I would guess that the setting should be set to TT on both cordless phones for touchtone.
Second thing to do is to plug in the base unit of your cordless phone to a jack that currently has a landline phone plugged into it that works and test again. If cordless phone works OK then go back to the original jack that didn't work and reverse the wires in the jack: that is what is known as a "polarity" issue.
Aug 31, 2009 | Panasonic Lands Phones
GE portable phone model # 26928GE1-D No dial tone-installed new battery still no tone
That isn't a whole lot to work with. Get a working phone and take the cord out of the base of the GE and plug it into the working phone.
If the working phone gets a dial tone, look into the modular receptical on the GE base and see if the contact wires aren't out of place.
If you don't get a dial tone on the working phone, try changing the connection cord between the phone and the wall. Also look for the same problem in the wall receptical as discribed above for the GE base.
May 28, 2009 | Uniden Cordless Phone
No dial tone
Please disconnect your cordless phones from telephone jacks throughout the home. The "line in use" is say that you have a short on the line, or a phone off the hook. So disconnect lines, then replug 1 corded phone in to check for dial tone. If working, continue to plug in 1 phone at a time(rechecking working one each time) to find the equipment that is causing you heartache.
Apr 21, 2009 | Uniden Cordless Phone
Uniden cordless phone. No dial tone.
Hi peddler65, did you plug your phone into another area to see if there is a dial tone. Then if not call the phone company or find the D-mark (where your dial tone ) comes into your home and put a jack on that and plug a phone in with all phones in the house unplugged.
Thanks.
Nov 14, 2008 | Uniden Cordless Phone
No dial tone
Did you plug in another phone to see if there is dial tone. Then if not call the phone company or find the D-mark (where your dial tone ) comes into your home and put a jack on that and plug a phone in with all phones in the house unpluged. Let me know this is a very general comment about dial tone so if you can get more specific that would be great.
Nov 07, 2008 | Uniden Cordless Phone
Phone won't work
our phones were working fine. now after an eight hour electrical shut down, no dial tone.
Jun 15, 2008 | GE 21028GE3 Cordless Phone
GE cordless model 26928GE2-A
Dial tone is OK, but can't dial out
• Make sure the tone/pulse setting is programmed
correctly.
TONE/PULSE DIALING
1. Make sure the phone is OFF (not in TALK mode).
2. Use the CID/VOL left (-) or right (+) arrow button to
scroll to 1TONE or 2PULSE, or use the touch tone
pad on the handset to enter the desired setting. For
example, to choose TONE dialing, press the number 1
key. 1TONE is the default setting.
3. Press flash/program to store selection. You will hear a
confirmation tone.
Feb 06, 2008 | GE Cordless Phone 900 MHz
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Cordless receivers not working
If you have tried the phone base unit in the same jack that works correctly with your answering machine and you still cannot break dial tone, then you have a defective base unit. Jer
May 09, 2007 | GE 25831GE3 Cordless Phone
CORDLESS PHONE - NO DIAL TONE
Plug out the power from the main charger and then plug in again. It needs to reset after they have gone dead. Immediately you can lift one of them off the charger and you will hear your dial tone.
Apr 18, 2007 | Uniden DXAI5588-2 Cordless Phone
Uniden DXAI5188-2 Cordless Phone Logo
180 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
