Question about Tamron AF 28-200mm f/3.8-5.6 LD Aspherical Lens
Tamron 18-200mm on Canon EOS 400D, Error 99
My lens will work from 18mm to approx 25mm and then I get a Err99 on the camera throughout the zoom range to 200mm. I suspect a fault has occurred in what I presume is an electrical tape/connector that extends through the lens body as it zooms out. I'm wondering if this is a known problem and if a repair will be so expensive that I may be better off replacing the lens? Its an 18-200mm 1:3.5-6.3 Macro. Advice appreciated!
SOURCE: Tamron 28-300mm Model 185D Auto Zoom on Nikon d40
Autofocus function on the D40 only supports lenses with the
AF-S feature, which have an autofocus motor built into the lens,
instead of using an autofocus motor drive built into the camera.
The Tamron lens you have, does not have a built in motor and
the autofocus function relies on the motor drive in the camera.
It will not work with the D40 or D60, but it will work with other
Nikon digital SLRs, such as the D80. Need to get an AF-S
type lens or upgrade to different Nikon digital SLR. Unless
you do this, you will have to manually focus the Tamron lens.
All of the Nikon DX (for digital) series lenses are also AF-S
type, so they will work with the D40, which is designed as
an entry level digital SLR, therefore it is intended primarily
for use with DX lenses, which are typically sold in a kit with
the D40. Most common one is Nikkor 18-55mm DX AF-S.
Other Nikon AF-S lenses made for film cameras (FX type)
will also work with the D40, but these tend to be expensive
professional models. DX series lenses tend to be more
affordable. You might consider the 18-200mm DX AF-S
as an alternative to the Tamron, but these are not cheap.
Posted on Jul 05, 2008
SOURCE: ERROR 99
try cleaning the lens contacts of your lens and camera.
Posted on Aug 13, 2008
  • 134 Answers
SOURCE: I broke the top lens on my Tamron AF 70-200mm
Contact Tamron USA via their web site or a phone call to get a price quote for the front lens assembly. However, I would strongly suggest that instead you allow Tamron to repair your lens since more than likely the internal roller glides have been compressed due to the impact. This would allow the front lens group to wobble a bit while focusing and zooming, and this would seriously affect the image quality.
Posted on Apr 26, 2009
  • 117 Answers
SOURCE: My Canon 400D Camera keeps coming up with error 99
Hi turn on the camera with the lens on set to tv and a iris of f22 and use the stopdown button if the lens stops down the lens is ok if not the lens is faulty may need a intuper replaced
Posted on Jan 11, 2010
Testimonial: "Many thanks for your help with this problem. What is a Intuper? I have never heard of this before."
  • 11 Answers
SOURCE: CANON rebel EOS TAMRON
It's probable that although it's designated Macro, the lens actually only gets in fairly close. I recommend you buy a closeup filter which is a simple lens you screw on the front of your lens. You can different strengths for getting in closer. Otherwise treat yourself to a set of extension tubes which do the same thing but more effectively.
I hope that helps
Posted on Mar 30, 2010
I have worked all day, thinking Ive recorded the event i covered. In the process I discovered this Error 99. My Canon EOS 350D could only take a successful shop when I zoom an object and go far to make...
If you get err99 with lens then lens diapharm unit goes wrong and its giving er99.
if you getting with body and there is coupleof possiblities.
please descride brifly your camera fault
how and when you geting err99
Aug 05, 2010 | Canon Rebel XT / EOS 350D Digital Camera
My Canon 400D camera keeps coming up with error 99 I have cleaned the contacts on both my camera and my Tamron 28-200 lens.At first i thought it was my camera but I tried it with another lens and it...
Jan 11, 2010 | Tamron 28-200mm F3.8-5.6 for EOS
Error 99 on EOS Canon 450D
This is what the people at the canon tech support say to do for error 99
read this!! :)
The guy at tech support listened and then told me that the lens contacts were dirty and to get a pencil with an eraser on the end, just a regular old pencil with a red rubber eraser. Detach the lens from the camera, hold it so that the lens’ gold contacts are pointing down and lightly erase their exposed surface, cleaning them of any hand oil that might have gotten on them.
Do the same thing with the gold contacts inside the camera body. This is a bit harder but it’s doable: just hold camera so lens opening points down so no gunk falls in. Erase lightly. I used a lens cloth and dabbed at the contacts rather than blow them so as not to blow the erasings inside the camera.
I did this to each of my three lenses just to be sure. Lo and behold, it worked
hope this works for you!!!! have a nice day!! :) :)
Dec 04, 2009 | Canon EOS 450D Digital Camera
I want purchase a zoom lens 55-250,70-300,75-300 for my Canon EOS 400D camera what is the price range?
If you are talking about canon only (not sigma/ tamron etc) lenses then there are many different variations of the above lenses ranging from a few hundred to over a thousand UK pounds ( I dont know your currency/country) If you are looking at the budget market then the best value of the 3 mentioned id the 55-250 by canon which has good optical quality and built in IS (Image stabilistaion) and is remarkable value for a CANON branded lens
http://www.photozone.de/canon-eos/194-canon-ef-s-55-250mm-f4-56-is-test-report--review
Other option in the price range would be the 75-300 mk III but it is non IS but does give you a longer reach.
Mar 25, 2009 | Canon EOS 400D Digital Camera
Canon eos 400d
Contact Canon - some makes of lens which are not Canon are not electronically compatible for various reasons, and can actually damage the camera. So, get using the phone and check if it is compatible before doing anything else - but personally, I would not use the lens until I find out
Jul 02, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
Error code 99 canon E0S 450D
Try this:
http://www.richardsnotes.org/archives/2005/04/29/50mm-lens-contact-points/
Jun 14, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Canon error code 99
Your camera performs a quick 'integrity' check before each shot and goes into error 99 mode if the lens in incompatible or has a diaphragm problem. ( it will also display e99 if the shutter or flash unit is not ok but this does not apply here ). This is how you can check whether the diaphragm mechanism is ok : attach lens to your old camera and set camera to AV and set F stop to 16 . open back and release shutter and look through the back to see if your lens is closing to F 16. If it is closing fine then the lens is ok but is not compatible with your D400.
Sep 10, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
AF 70-300 causes error 99 in my Canon 300D
This is usually a torn flexible circuit or binding aperture in the lens. It'll have to go to a repair shop for replacement. About a $80 job.
Nov 04, 2006 | Tamron Zoom Telephoto AF 70-300mm...
Cameras Logo
593 people viewed this question
Top Tamron Cameras Experts
Steve
Jerry Greenberg
Jerry Greenberg
bhargav
Are you a Tamron Camera Expert? Answer questions, earn points and help others
