Question about KitchenAid KSRG25FKSS Side by Side Refrigerator
Kitchenaid Fridge -- burnt rubber smell
Last night I woke up to the strong smell of burnt rubber emmiting from the bottom vent of my Kitchenaid refrigerator. It is a 6 year old unit (model # KSRG25).
The temperature seemed to be correct on both the freezer and fridge side. I put a temp. probe in the fridge and it registers consistently around 40F (+/-1)
When first discovering the issue the vent fan was blowing out the usual warm air (but smelling burnt). I went to work, returned 10 hours later and the temp. is still fine. The smell is still present. And notably, the fan is constantly on but only blowing cool air. The fan does not shut off. Also, and important to note, every 5 min. or so I hear what sounds like motor (or solenoid) attempting to turn on. It hums for 6 or so seconds then shuts off. Lastly, when I slide the fridge temp control from the current setting from just plus of midpoint to "1" the fan does shuts off. What should I do??
  • 1 more comment
  • sergeoo Jun 02, 2009
    Billtokuma, thank you for the response. I considered that it may be the defrost timer...but the compressor has not turned on for full day now and the temps are finally rising.
    What kept the temps stable yesterday withouth the compressor running may have simply been the insulative effects keeping the fridge cold.
    I have a tendency to think it is the compressor start relay.
    Your thoughts?
    Update: I finally had time to pull the back off to discover a charred compressor starter relay. (Lucky it didn't start a fire!).
    I ordered a new relay/capacitor overload kit for the fridge and will update this afternoon when the part is in.
    Appears to be a easy swap--and will save $180 replacing this myself vs. KitchenAid authorized repair service.
    Final update--I installed a new compressor start relay/capacitor ($59 part). And all is working well again.
    Problem Solver:
  • 16 Answers
Sound like defrost timer going out slowly
Posted on Jun 02, 2009
There is a strong odor coming from the freezer something like a fish smell or a burnt wire. The ice maker is working ok and the fan blows air just fine and the freezer and refrigerator are operating just...
The smell could either be the fan motor or the defrost heating coil...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Mar 18, 2011 | Amana ABB1927DE Bottom Freezer...
Burnt plastic smell coming from bottom of frig
This is a sign of a short and should be looked at immediately. A smell like that is a sign of something burning. I could be the start relay and start capacitor with overload. But I would not sleep with the possibility of a fire. I will look over your model and see if I can find what this could be, Sea Breeze
Aug 28, 2009 | GE Refrigerators
Chemical odor in freezer
can you verify the odor. Does the odor smell like burnt wire insulation or of that of burnt meat?
Jul 05, 2009 | Kenmore Freezers
Compaq presario V3019US notebook pc has burning smell
Take out the battery and run just on external power, see if the smell goes away. If it does, check to see if there is a recall on that battery.
Jun 08, 2009 | Computers & Internet
Freezer cutting on and off, not cooling
i would say it is a evaporator fan motor liocated between frezer and fresh food parts of fridge..but also could be a damper it self or damper motor
Feb 25, 2009 | Amana ARB2557CSR / ARB2557CSL Bottom...
Very Strong Odor When Refrigerator Runs
Without looking at your fridge I would say the strong rubber smell is the heater element has dust on it or the heater contactor is closed and the heaters are staying on. Either way it would be good to get it checked out. I cannot think of anything else that would make a rubber burning smell.
Jan 23, 2009 | Frigidaire FRS26R4A Side by Side...
Burning Rubber smell coming from fridge
try taking the bottom panel off and vacuming all the dust on the coils. The dust may be heating up and burning. The coils are usually at the bottom of the fridge. Check to see if the fan is running also.
Jan 16, 2009 | Refrigerators
Fridge smell
check the pipes at the back of the fridge, it could be that one of the pipes has a crack and is leaking gas or oil. If not check the inside of the fride for a brown oily residue. This indicates a leak. Don't turn the fridge back on becasue if the oil and gas mix then the fridge will no longer be usable. If you find either of these get an engineer to fix the problem.
Oct 25, 2008 | Frigidaire FRS26R4A Side by Side...
Cooling problem with a ge top freezer refrigerator
I have one that did the same. The coil in the back of the freezer was frosting up because it wasn't defrosting like it was supposed to. I noticed that the thermostat looked damaged so I ordered a new one from sears parts direct which by the way will show a diagram of the model you have. I just installed it last night so I will post how it comes out. This morning the freezer has a burnt smell but I am hoping its from the defrost not working for a while!
Mar 03, 2008 | GE Hotpoint Top-Freezer Refrigerator
KitchenAid KSRG25FKSS Side by Side Refrigerator Logo
691 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
