Question about HP Photosmart D5069 InkJet Printer
HP Photosmart D5069 won't print
The above printer will not print
Tengo tu apellido yo soy Milagros Sainiuk
Posted on Aug 23, 2009
Side problem in samsung 4521
ok, if new catrdge doesn\'t correct the problem,, surely it might be laser window . clean slit glass just above the drum place. if copy only defective print ok,, it may be other case; but both c&p bad, cent% laser obstruction. clean as above, all the best!!!
Dec 21, 2013 | Samsung SCX 4521F All-In-One Laser Printer
Hp deskjet 948c. What Do The Button's Do
buttons and lights The HP Deskjet printer buttons let you turn the printer on and off, cancel a print job, or resume printing. The lights give you visual cues about the state of the printer
sayurisan20_33.jpgcancel button
print cartridge status symbol and light **The light above the Print Cartridge Status symbol flashes when a print cartridge is low on ink or incorrectly installed.
sayurisan20_35.jpg resume button and light
**The light above the Resume button flashes when an action is required such as loading paper or clearing a paper jam. When the problem is fixed, press the Resume button to continue printing.
sayurisan20_36.jpg power button and light **
The Power button turns the printer on and off. It takes approximately five seconds for the printer to turn on after you press the Power button. The green light above the Power button flashes when printing is in progress. Caution! Always use the Power button on the front of the printer to turn the printer on and off. Using a power strip, surge protector, or a wallmounted switch to turn the printer on and off may cause premature printer failure
Jun 17, 2011 | HP Office Equipment & Supplies
Printer is not printing at all - printer was unplugged and restarted - still not printing - receiving above error message.
please write full error message. or check and change your usb cable, check that if there any paper jam in printer, reinstall printer driver, check is printer printing test print from itself.
Mar 14, 2011 | Office Equipment & Supplies
New cartridge prints very light
It is a possible drum issue, but before you get a new one remove the toner and drum and look up above where the drum sits inside. Use a dry soft cloth to wipe the narrow window that's above and try printing again. Toner save being turned on in printer properties will make lighter prints as well.
Jan 07, 2010 | Brother HL 1440 Laser Printer
Print head, some nozzles blocked
the print head is defective and print head control board, need replacement. normaly very expensive spare parts, above printer price.
Dec 25, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My hp 5780 printer only prints in black and white
Please check if your Colour Ink Cartridge is not emply. If their's ink in the cartridge then try to service your printer through the Print Preferences. Your Colour Cartridge Nozzels could have been blocked thats why your printer is unable to print in Colour.
In case if both the above doesn't work then check in the Print Preferences that you should not have saved the option of PRINT DOCUMENT IN BLACK ONLY.
Hope the above will help you.
Apr 26, 2009 | HP Officejet J5780 All-In-One Printer
Not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Feb 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
Printer doesn't print even with new ink cartridges.
turn the printer i turned on and Press the cleaning button ,. Cleaning takes about two minutes, the printer makes some noise when it finishes you run a nozzle check for print quality and reset the cleaning cycle.
load paper . go to the printer menu as follows: click Control Panel, and then double-click Printers. Select the Epson printer if have more than one printer is installed. Click File, click Properties, click the Utility tab, then click the Nozzle Check icon.
The printer will print a Nozzle Check pattern in black, and in cyan, magenta, and yellow. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If any dots are missing, clean the head again.
If your software is different, and does not have these options, you can do it this way:
1. Same as above.
2. Same as above.
Turn off printer and computer. Disconnect interface cable from printer. Load paper. Hold down the load/eject button and press the power button to turn on the printer. Release both buttons.
3 Same as above.
4 Turn off printer and reconnect the interface
May 17, 2008 | Lexmark X1240 All-In-One InkJet Printer
Hp 1200 business inkjet help
I have a solution that is very similar to that printed above.
I have tested it on five installations on the computers on my home network and an HP Business Inkjet 1100, and the PCs running Win XP SP3.
Step 1) If you are setting up the printer from the HP CD, decline the question where it asks if you want to print a test page, (this will avaoid the first print job before re-setting the dates).
Step 2) Reset your clock back to a year prior to the year when your cartidge expired.
Step 3) Print a test page, or two. Or a few pages from any application.
Step 4) Reset your clock back to the current year.
The printer now prints fine. Since I performed the sequence above I have been printing with the "expired" cartridges for a few weeks. I have printed on about 15 occasions over the past few weeks, amounting to about 50 pages. No problems so far. I don't know how long this solution lasts or whether I will have to go through it again.
I have gone through a few different "solutions", including a Registry hack that didn't work, but this simple solution above has worked every time on five different installations.
I did not need to turn the printer on/off, and did not need to re-boot the computers.
However, if I sent a print job to the printer before performing the sequence described above, and the printer gave an "expired cartridges" error, then I would need to turn the printer on/off to clear the error, and flush the print queue.
Jan 28, 2008 | HP Inkjet 1200dn Printer
Color printing
Hi I take it that you have removed the blue tape that is over the cartridge when you install it? If you have are they original or refills if refills change for an original.
If you have done the above then remove the ink cartridge and with soft cloth wipe clean the gold contacts on the cartridge and also on the carriage.
When you have done the above try printing again if still not printing then check the following.
  • Goto Start Printers and Faxes
  • Right hand click on the printer Icon
  • Select "Printing Preferences"
  • Make sure that you are set to color
  • Close window the Right hand click on Icon again
  • Select Properties
  • Click on Print test page
  • This should not print in color if color was selected in printing preferences.
I do hope this works for you
Thanks J
Nov 11, 2007 | HP DeskJet 1220c InkJet Printer
HP Photosmart D5069 InkJet Printer Logo
156 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
