Question about Kenmore 700 sq. in. Cooking Area Gas Grill 14116325
Low pressur on gas grill
I have a 4 burner Kenmore grill. I can light three burners with no problem and have a good flame when lighting the fourth burner I loose all gas pressure.
  • jeffcappello Jun 02, 2009
    doesn't matter in which order I light the burners as soon as number 4 is lit they all go out. orifices are clear and open
  • rjbeg123 May 11, 2010
    Sounds like the 4th burner is bad. Try lighting one other and then #4 do you have the same problem? Just 4? if yes burners do go bad they should have quite a bit of back pressure but as they corrode the jets will open and dump gas or the line may have failed dumping gas and that results in pressure drop in the others to the point that they won't light.
  • 121 Answers
Orfices are possibly clogged with spider web
and the check to see if your dial on tank is fully open and check to see if your tank is almost empty...
Posted on Jun 02, 2009
Natural gas grill low flame
Did you change the reg , lpg burns at 14 inches wg nat gas burns at 4inches wg
Feb 16, 2013 | Char-Broil Commercial Stainless Steel...
On a kenmore 5 burner grill when lighting the fourth burner all of the grill shuts down, regardless of which is the fourth burner?
Sounds like the pressure regulator is malfunctioning. Try disconnecting your gas line. Open/Close all burners then reconnecting gas. If propane, don't turn bottle off before burners. Always turn burners off first, then bottle. then bottle on before burners. This primes the regulator to the proper pressure.
Jan 09, 2012 | Kenmore Grilling
My first 2 burners furthest from the tank light alright, however when I light the middle burner or the other 2 closest to the tank my flame dies out.
Sean, It sounds like a gas pressure problem, that may be easy to resolve.
1. Turn the gas tank valve OFF
2. Disconnect the hose from the tank and wait five minutes.
3. After 5 minutes, reconnect the hose to the tank and open the tank valve VERY, VERY SLOWLY
(Slow Motion, slow).
4. Once the valve is fully open, light the burner farthest from the tank first and turn it to HIGH. Does the
Flame height look correct? If so, light the remaining burners the exact same way. Now, did all
the remaining burners light and the flame heights look normal? If so, you solved the problem.
Remember, always turn the tank valve ON Very, Very Slowly.
If that did not solve the problem, you will need to replace the grill's Hose/Regulator assembly. You can purchase one for about $30,00 from any home improvement center or hardware store that sells gas grills and accessories. Take your old one with you for comparison purposes.
Hope the helped you troubleshoot and solve the problem. Please let me know and Happy Grilling!!
Jun 18, 2011 | Kenmore 882 sq. in. Cooking Area Gas Grill...
Low flame at burner. I've put a new tank on my grill and now the flame stays very low on all burners. I've heard that there can be some pressure problems with a newly filled tank. Is there a quick...
Mike, there can be some pressure problems, but it's not the new tank. However, it does cause the problem and here's how you resolve it.
1. Turn the gas tank valve OFF.
2. Disconnect the hose from the tank and wait 5 minutes.
3. Reconnect the hose to the tank and turn the tank valve ON VERY, VERY SLOWLY (Slow motion, slow).
4. Once the valve is fully open, light the burner farthest from the tank first and turn the burn to HIGH.
Does the burner light and the flame height look correct? If so, light the remaining burners the same
way. Now, do all the burner flames look as the should? If co, you solved the problem. Always
remember to turn the tank valve ON very, very slowly>
If the above did not solve the problem, you will need to replace the grill's Hose/Regulator Assembly. You can pick one up at any home center or hardware store that sells gas grills and accessories. It will run you about $30.00 (+/-) .
Hope this helped you to solve the problem Please let me know & Happy Grilling!!
Jun 12, 2011 | Grilling
The first two burners on the left light and have good gas flow. When I light the middle and the left two burners the flames flicker and go out, like there is not enough gas. I cleaned the burners, tried...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Aug 22, 2010 | Kenmore Elite 900 sq. in. Cooking Area Gas...
Grill will not stay lit if using 4 th burner will only work on 3 burners and gas is low
Check that the fourth burner tube is set properly into the unit. Then turn all burners off, turn off the natural gas supply or remove the LP tank. turn all the burners on (don't try to light) wait a couple seconds turn all burners off. reconnect gas source. turn on gas, open burners fully and try to light.
Aug 08, 2010 | Jenn-Air Grilling
I have a Kenmore 4 burner grill that I purchased about 3-4 weeks ago. 3 of the 4 burners have nice blue flames and work very well but the left middle burner gets a huge yellow flame no matter what temp it...
does the same burner flame turn blue if other burners decreast in flow-with that burner on high and others low-is it still yellow? if so Gas Valve needs to be replaced.
Oct 05, 2009 | Kenmore 700 sq. in. Cooking Area Gas Grill...
My kenmore elite gas grill will light, then quickly go out.
check for leak if it is propane if no leak most likely regulator and hose
Aug 10, 2009 | Grilling
KEEPING GRILL LIT
There is a safety device that shuts the gas off or nearly off if there is insufficient back pressure, such as can be caused by a leak. Check to insure that all of your new burners are properly seated.
Jul 02, 2009 | Weber Q Grill
Rangemaster 110 grill flame.
to find out if the regulator is good or bad, turn any of the burners that do not have the problem, one at a time but take a close look at the flame and see if the flame goes lower and lower as you turn a second burner and a third and the fourth one, if the flame goes lower and lower the regulator is bad. but if the problem is with just the grill one , it has to much air, you can turned down the air where the burner meets the valve that supplies gas to it the burner has a vent, it needs to be close a little bit, you can close it little by little and testing the burner on the on position until the splutter goes away.
Dec 11, 2008 | Rangemaster 110 (Dual Fuel) Dual Fuel...
Kenmore 700 sq. in. Cooking Area Gas Grill 14116325 Logo
411 people viewed this question
Top Kenmore Grilling Experts
Dan Webster
Dan Webster
Gary Kenady
Gary Kenady
Paul Carew
Are you a Kenmore Grilling Expert? Answer questions, earn points and help others
