In general house hold circuit breaker of the house is 15 Amps or 20 Amps.
Either you have defected (weak) circuit breaker and wiring or bad Microwave oven.
The 99.99 % house hold Microwave ovens pull less than 15 Amps. They may have internal ceramic 15A fuse or 15 Amp internal circuit breaker.
To isolate your problem:
1.
Plug your Microwave oven to different areas (different electrical circuit) if the different circuit breaker still trips... your Microwave oven has a short - Most of them has a small ceramic fuse 15 amps fuse.-also check some inter lock switches at door .
2.
If the Microwave oven works Ok then you may have:
2a. You may overload the existing electrical circuit, try to unplug some other appliances
2b. You may have bad electrical outlet receptacle (Replace it with the same type , - may need helps from licensed electrician)
2c. Weak or defect house hold circuit breaker. (Replace it with the same type , brand - may need helps from licensed electrician)
Circuit Breakers do weaken over usage. It is not usually a time factor as much as a load factor. Each time a circuit breaker trips, it loses its ability to carry the same load as it did previously. In other words, a 15 amp breaker only carries the ability to carry 15 amps once. I recommend replacing the circuit breaker with one that has a matching rating. If you do feel up sizing is necessary, check the load rating of the appliances to make sure the additional size really is necessary. Increasing power to appliances that shouldn't need it increases the risks of potential electrical fires and masking real issues. Try changing it with higher amp breakers.
Please accept the solution if it's helpful. Do get back to us for any further query.
Thanks for contacting fixya.com
