Question about Acer Aspire 5100 Notebook
Boot manager files compressed windows won't start cannot start up
Windows operating systems have been compressed and now computer does not start up
Make sure computer is off, insert xp disk, at the top left corner of your screen you will see boot from cd press any key and let windows do its thing follow instructions . use up and down arrows to highlight and delete old files . old wndows that did not work. yes you are sure to delete refomat follow and answer questions very simple. your computer will blink flash thats part of the process, it will even reboot do not touch anthing at all the computer will let you know when its done, once you start the installation i repeat let the computer o its thing sometimes its fast sometimes not wait frediemccly@yahoo.com
Posted on Jun 02, 2009
Bootmgr is compressed
The Windows operating system allows you to compress the files on your drive to conserve disk space.
In some situations, this compression process will compress files required for the operating system to boot.
Files that are compressed must be decompressed prior to execution.
Since the operating system has not loaded, boot files cannot yet be decompressed.
In this case, the operating system will fail to load and a "BootMgr is compressed" message will appear.
An easy way around this problem is to boot from the Windows DVD, and use the provided interface to access your drive properties and decompress it.
Turn on the computer, and insert your Windows DVD.
Press a random key on your keyboard once you see the "Press any key..." message.
This interrupts booting from the hard drive and forces a boot from the Windows DVD.
Click the "Next" button at the bottom of the Windows 7 dialog, and then click the "Repair your Computer" link Below.
http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7
http://msdn.microsoft.com/en-us/library/aa364219(v=vs.85).aspx
File Compression and Decompression
Select the "Load Drivers" button at the bottom of the "System Recovery Options" dialog, and click the "OK" button on the "Add Drivers" dialog.
This opens a file browser on your screen.
Click the "Computer" icon, which is located on the left hand side of the screen.
This displays an icon for your disk drive.
Right-click your hard drive, and click "Properties.
" This opens a Local Disk Properties dialog.
Click to deselect the "Compress this drive..." option at the bottom, and then click the "Apply" button.
Select the "X" icon to close the file browser window.
This takes you back to the Install Windows dialog.
Press the "X" icon at the corner of the Install Windows dialog.
This opens a cancellation dialog. Select the "Yes" button on this dialog to restart your computer.
Nov 26, 2013 | Acer Extensa 5620 Notebook PC
Boot manager compressed press ctrl+alt+del
Causes of BOOTMGR Errors
There are a number of possible causes for BOOTMGR errors, including the most common "BOOTMGR is missing" error message.
The most common reasons for BOOTMGR errors include corrupt and misconfigured files, hard drive and operating system upgrade issues, corrupt hard drive sectors an outdated BIOS and damaged or loose IDE cables
Anothe reason you might see BOOTMGR errors is if your PC is trying to boott from a hard drive or flash drive that is not properly configured to be booted from. In other words, it's trying to boot from a non-bootable source.
This also would apply to media on an optical drive or floppy drive that you're trying to boot from.
make sure there are no disks in cd floppy usb drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your ((MOTHERBOARD TO YOUR HARD DRIVE)) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
if its a flat ribbon 40 pin IDE it will be the fist to fail
Make sure all power and data leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty a computer needs
Data and Power to travel through every working device and to continue its cycle and to have an end so any faulty leads will end up with a computer error.
also make sure you have set it boot from you hard drive in BIOS
Restart your computer and enter BIOS mode.
On most computers this is done by pressing the Delete ot F2 key but will vary depending on your computers bios other keys Acer: - Ctrl+Alt+Esc , ALR PC: (F2) or (Ctrl)(Alt)Esc) , Award BIOS: (Del) or (Ctrl)(Alt)(Esc).
Scroll over to the "Hard Drives" tab, and make sure your computer has the hard drive assigned to be on.
Often during BIOS you can select auto-detect or change options with your hard drive to make sure Windows can recognize it.
Once you've selected your desired options, continue to boot.
or
The solutions might be very simply... remove your hard-disk and attached to other PC or laptop as an external hard-disk.
When it is detected, go to my computer, right-click, untick that (stupid) option, immediately you see the message uncompressing and its done.
Put your hard-disk back in to your machine its ready..
w7
insert your OS CD
go to DOS window and type in your OS driver (usualy C:/
type in bootrec /FixMbr
then type in bootrec /fixboot
then type in bootrec /rebuildbcd
then type in exit
it will work 100% only if you prompt at the same order
Hope this helps.
BOOTMGR Is Compressed
Aug 06, 2013 | Computers & Internet
My bios setup is locked with password and i dont know the password,what shall i do?
The Windows operating system allows you to compress the files on your drive to conserve disk space. In some situations, this compression process will compress files required for the operating system to boot. Files that are compressed must be decompressed prior to execution. Since the operating system has not loaded, boot files cannot yet be decompressed. In this case, the operating system will fail to load and a "BootMgr is compressed" message will appear. An easy way around this problem is to boot from the Windows DVD, and use the provided interface to access your drive properties and decompress it.
Turn on the computer, and insert your Windows DVD. Press a random key on your keyboard once you see the "Press any key..." message. This interrupts booting from the hard drive and forces a boot from the Windows DVD. Click the "Next" button at the bottom of the Windows 7 dialog, and then click the "Repair your Computer" link Below. http://windows.microsoft.com/en-US/windows7/What-are-the-system-recovery-options-in-Windows-7 http://msdn.microsoft.com/en-us/library/aa364219(v=vs.85).aspx File Compression and Decompression Select the "Load Drivers" button at the bottom of the "System Recovery Options" dialog, and click the "OK" button on the "Add Drivers" dialog. This opens a file browser on your screen. Click the "Computer" icon, which is located on the left hand side of the screen. This displays an icon for your disk drive. Right-click your hard drive, and click "Properties. " This opens a Local Disk Properties dialog. Click to deselect the "Compress this drive..." option at the bottom, and then click the "Apply" button. Select the "X" icon to close the file browser window. This takes you back to the Install Windows dialog. Press the "X" icon at the corner of the Install Windows dialog. This opens a cancellation dialog. Select the "Yes" button on this dialog to restart your computer. Hope this helps
b>
Jan 21, 2013 | MSI Wind U100-016US Laptop
Bootmgr is compressed in my presario cq40
b>
Jan 21, 2013 | HP Compaq Presario CQ40-330TU
b>
Jan 21, 2013 | Compaq nl284la - Presario Cq40-320la...
My lenova laptop BMR is compressed, what's the solution for it?
b>
Jan 20, 2013 | Lenovo 3000 G530 Notebook
Whats the solution for BMR compressed?
b>
Jan 20, 2013 | Acer Iconia Tab A50010S16u Notebook
b>
Jan 09, 2013 | Microsoft Windows 7 Ultimate 32bit
I have a acer aspire 5000 and when i turn it on it says bootmgr is compressed, press ctl+alt+del to restart but it wont restart
b>
Jan 05, 2013 | Acer Aspire 5500 5570-2609 Laptop
Boot manager compressed dell inspiron e1505
you may have trouble sorting this with out the disc.Here are the steps to replace the BOOTMGR:
  1. Boot from the Windows install disc.
  2. Click on Repair your computer after selecting proper language, time and keyboard input.
  3. Select the Windows installation drive, which is usually C:\ , and click Next.
  4. Choose "Command Prompt" when the System Recovery Options box appears.
More items...
BOOTMGR is compressed: Press Ctrl+Alt+Del to restart
https://neosmart.net/wiki/bootmgr-is-compressed/.....or try this link.. boot manager is compressed press ctrl alt del to restart Google Search
Oct 14, 2017 | Dell Inspiron E1505 Notebook
Acer Aspire 5100 Notebook Logo
891 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
