Question about HP Compaq nx9010
My computer is overheating and how do u clean the fan
Its overheating its not cooling down if im on the computer for a long time
    Guru:
  • 597 Answers
Need to blow all the dust out of the vents on the side and bottom of laptop and check out the fan while the laptop is running. If the fan seems to be running slow, the bearings may be damaged and you may need to get another fan.
Posted on Jun 01, 2009
Dell d610 shuts down while playing games
Some games require more processor use, some less.
If the games that cause your computer to shut down feature high resolution graphics or fast 3D rendering, then the problem could be insufficient processor cooling. Once the processor gets overheated, it goes into thermal shut down.
If, while you play, the computer runs hot before it shuts down (check the cooling fan outlet), then these are some of the possible reasons:
-cooling fan blades could be obstructed by dust - cooling fan needs to be cleaned or replaced
-heatsink radiator and / or air outlet could be obstructed by dust - also need(s) to be cleaned
-thermally conductive grease on the microprocessor heatsink could be
partially or entirely dried up - old grease needs to be carefully removed and new grease applied (caution - do not use any kind of thermal grease that contains metallic particles like silver or aluminium - you might short out the processor - only use the kinds which are electrically nonconductive)
of course the problem could be elsewhere, but the above mentioned problems turn out to be a common issue with many laptop computers after a few years use, regardless of manufacturer brand and model, also it could be any of or the combination of any or all of the above problems (obstructed air outlet leads to more dust being deposited on the fan blades, more dust on the fan and outlet leads to processor overheating which leads to thermal grease drying which leads to even more overheating and so on...)
hope this helps somewhat
regards
triarcuate
Mar 31, 2012 | Dell Latitude D610 Laptop Computer -...
Tip
Tips to secure your computer from overheatingTips to secure your computer from...
<span>There are some simple ways that make you aware about your problem regarding computer overheating.</span><br /> <br /><span><br /></span><br /><span>1. </span><span>The Cabinet fan and processor fan inside the system keeps the computer cool and free from dust. So keep these fans working on.</span><span><br /></span><br /><span><br /></span><br /><span>2. </span><span>Always keep your computer clean inside for stop a computer from overheating. </span><span><br /></span><br /><span><br /></span><br /><span>3. </span><span>For stop your computer from overheating always put it to sleep mode when it's not going to be in use.</span><span><br /></span><br /><span><br /></span><br /><span>4. </span><span>If you are using a laptop, you can prevent it from overheating by purchasing a cooling pad, and do not put it on a restricting surface like your pillow or bed.</span><span><br /></span><br /><span><br /></span><br /><span>5. </span><span>Always try to put your computer in cool place from preventing from overheating.</span><span><br /></span><br /><span><br /></span><br /><span>These steps will prevent your computer from overheating successfully.</span><br /><span><br /></span>
on Dec 24, 2010 | Computers & Internet
Its overheating and shutting down after maybe 15-20 minutes
Almost certainly a clogged cooling fan , vents or build up of dust on the cooling fins. You will need to gain access to the CPU fan and remove the heatsink assembly, blow all dust out of the cooler matrix, clean the fan blades and the cooling vents. Clean off any thermal paste on the cpu and regrease with new paste, refit and reasemble.
You CAN cut corners by cleaning it "in situ" but a thorough cleaning is advised.
Eventually if not cleaned, teh graphics chip will fail with overheating
Jan 29, 2011 | Computers & Internet
Laptop keeps shutting off by itself
When you encounter about this issue this is overheating problem maybe the CPU fan is not spinning and faulty already, you need to check the CPU fan and replace a new one.
Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed.
Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Oct 08, 2009 | Gateway (60.44K08.001) Laptop Heatsink
I've had a bad dust problem and my cpu fan began making a loud whirring noise and finally the computer shut down altogether. Took the cover off totally cleaned out the dust and turned the power back on....
If the computer detects overheating or fan failure it will shut down automatically. If you replace the fan you should be fine. Remove your old fan and try to get one that connects the same way, some of them connect directly to the heat sink, others to the motherboard.
Apr 16, 2009 | Sony CPU FAN CPU Fan
Main cooling fan
If this is not caused by overheating try defraging your hard drive and doing a disk cleanup.
computer slowdowns can also be caused by a virus infection try also scanning for virus in your computer.
Jan 15, 2009 | Packard Bell Easy One Silver 2120 Notebook
Fan starts runnung fast and everything is frozen
Overheating. Try using canned air and blowing out vents. If you are comfortable with it, take the laptop apart and clean it out. If not, contact a local computer shop that can do it for you. If cleaning doesn't do it, the CPU heatsink will need reseated or the CPU will need replaced.
Jan 15, 2009 | HP (344872-001) Laptop Cooler, Cooling Fan
Dell Inspiron 8600 - overheating and shutting down
Start by cleaning the fan and heat sink. Dirt or dust build up can cause them not to work as efficiently as they should. If cleaning doesn't fix it, you might consider replacing the fan and heat sink or purchasing a cooling pad.
Jul 22, 2008 | Computers & Internet
Overheating?
Hey,
I think it's the cooling... Because when i let it cool down after it shuts down for like a few minutes I can boot it back up. But if i try to boot it up right after it shuts down it won't let me. I think it has a built in temperature monitor to make sure it doesn't overheat. I'm going to install some computer fans on the vents of the projector to get some more airflow. Hopefully that will do the trick.
Nov 03, 2007 | CTX Optoma EzPro 680 Multimedia Projector
HP Compaq nx9010 Logo
190 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
