Question about Pioneer VSX-818V-K Receiver
Shut off will not turn back on
My pioneer receiver shut off and will not turn back on. Its only about 2 months old
2 Suggested Answers
dunnbiker
  • 8546 Answers
SOURCE: Pioneer VSX-818V receiver. less than
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Aug 27, 2011
How do you troubleshoot a Pioneer VSX-1023 A/V receiver?
Try to do the factory reset on the Pioneer:
Switch the Pioneer into standby (turn it off).
1. Simultaneously press old the buttons on font panel for 5 seconds - BAND & STANDBY/ON
2. "Reset" on the front panel press
AUTO SURROUND/STREAM DIRECT
3. Then press ALC/STANDARD SURROUND
OR
Simultaneously pressing "down" and "on/off" for 5 seconds to reset the Pioneer
Mar 05, 2015 | Pioneer VSX-1023-K Receiver 7.1 Channels,...
Pioneer VSX-D509S keeps shutting off
Aside from any intrinsic problem with your receiver, the usual suspects are;
1) Poor receiver ventilation. 2) Very high levels of bass. 3) Shorts in the speaker wiring. 4) A rubbing loudspeaker voice coil.
Sep 20, 2009 | Pioneer VSX-D509S Receiver
I turn on my Pioneer VSX-D509S 5.1 surround amp comes on for a few seconds and then it says "powering off"... and shuts off
Disconnect all your speaker wires from the back of the receiver and turn it back on. If it shuts off, you need to have it serviced. If not post a comment and I can walk you thru troubleshooting. Hope this helps
Jun 24, 2009 | Pioneer VSX-D509S Receiver
Pioneer VSX-9700S Audio/Video Receiver powers on then shuts off
The Pioneer 9700s is a very good sounding unit, if you are talking in home threater space, but your problem sound like the power amplifer section is giving out too HIGH DC voltage therefore ripping the protection circuit. In these newer home threater ammplifers, there are not dc offset voltage adjustment on the circuit brd. All is done by negative feed back. Sorry you ar eout of luck I don,t hinkit is worth fixing. They are not as well make as the older Sa7500, and Sa9800 amplifers of old. There is a good chance that aftera few month something else will go on them. That is why they are so cheap on Ebay, these thraeter receivers.
Apr 18, 2009 | Pioneer Audio Players & Recorders
No power
Press TUNE+ & AUTO SURR/DIRECT keys continuously for 2 sec. and it will tell you the fault it encountered if the receiver is in otherwise working condition.
Mar 12, 2009 | Pioneer VSX-818V-K Receiver
Pioneer vsx-d511 amp error
I've had the same problem for over a month and have yet to find the time to get to it. However, I there may be a fuse on the circuit board that needs to be replace. That's just my guess.
Hope it's the solution.
Sep 08, 2008 | Pioneer VSX-D511 Receiver
Blinking Standby
regarding the Pioneer VSX-912 blinking standby light. This is how you reset it; press the "advanced surround" and the " enter" at the same time for about 3 seconds. Make sure you press the ENTER on the reciever (its the one on top next to the small dial) If you press the "ON" instead of "ENTER" it will not work. If an error message comes on and shuts the unit down, just reset it again. This should save you some $$$$. To bad Pioneer did't put this info in the manual.
May 22, 2007 | Pioneer VSX-D912 Receiver
Help me please?
Speaker wires need to be checked at the back of the unit.I had the same problem. I needed to replace 2 amplifiers in the unit for $180.00.
Aug 27, 2006 | Pioneer VSX-D810S Receiver
Pioneer VSX-818V-K Receiver Logo
173 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
