Question about Bryant Heating & Cooling
Compresser is not running
Compresser will not come on . The fan in the condenser wont run. Temp in house is84 thermostat is set on 65 degrees . the heat pump is running but the fan is not blowing in cold air.
  • bbakenbetty Jun 02, 2009
    my heat pump and condenser was installed nov 2003 it is only 5 yrs old so I dont think it is blown.
    Problem Solver:
  • 6 Answers
The condenser fan motor is most likely blown. A replacement fan motor and a run capacitor are most likely needed to get it back in working order.
Posted on Jun 01, 2009
The unit is on Heat, Fan Auto it's 36 degrees outside, Thermostate set on 73 Actual temp inside 70. Unit runs continuously. How can I get more heat. I tried Emergency heat and that doesn't help.
Have you cleaned the air return filters ? Wash them, don't vacuum or brush them. It damages the filter screen. Sometimes a thermostat will be out by a few degrees. If the filters are clean, try turning the temp down a bit to 65 degrees and see if the air con shuts down. ( If your room temp is showing 70, it should switch off the machine) If it doesn't turn off, keep reducing the temp by 5 degrees at a time and wait a few minutes each movement to see if and when it shuts down. If the machine keeps running, I would suggest your thermostat is shot and you will need a new one.
Jan 04, 2016 | Heating & Cooling
Rheem split system condenser high pressure limit/safety needs resetting frequently before it reaches the set temp of 76 degrees faren. what's wrong and what do i need to check?
Is the outdoor fan running? The fan cools the coils and compressor, therefore keeping the high pressure low enough to run. Either the fan is not working or its not spinning fast enough. Check the capacitor, or just replace it.
Apr 18, 2017 | Heating & Cooling
Just cut on 8 year old Goodman CPLE24-1 AC for the summer. Ran 8 hours fine, Next morning noticed outside unit running, very little cool air blowing out of inside floor vents (like the blower fan was...
Due to the many different questions I see about Air Conditioning, I am including this overview to help us better understand each other for trouble shooting. A basic air conditioning system has a Thermostat, Air Handler or Furnace Fan and a Condensing unit. In a split system, the condensing unit (Condenser) is separate from the furnace and usually in the back yard. When working properly, it blows hot air. It connects to the cooling part of the system by 2 copper lines. One large line and 1 small line. The part that cools the house is the "Evaporator" and is usually on top of the furnace inside the square metal box (Plenum). When the Air Conditioner is running, the large copper line should be cold and the smaller line should be warm. Common signs of low refrigerant are that both lines are the same temperature and/or frost or ice has built up on the large line at the condenser. The thermostat will normally display room temperature on till it is touched to change the setting. It could have a "Span" setting as well as times and temperatures. The operating "span" of MOST residential thermostats is 40 to 90 degrees. That means you can set it as low as 40 degrees and no higher than 90 degrees. It probably has a fan switch also. When in the "ON" position, the fan will run constantly, 24 / 7, but the condenser will still cycle on and off as needed to keep the house at set point. If you have a suggestion to include in this paragraph, please let me know.
I think I have it covered above. Let me know if you need something more specific. Thank you. Roger
Apr 12, 2011 | Goodman CPLE24-1 Air Conditioner
Unit only stays on for a couple of minutes before shutting off
Does this help to narrow it down for me? How long does it run? How do you restart it? Roger
Apr 11, 2011 | LG LS-K1830CL Cool Mini Split Air...
Display shows "cool ** " I have never noticed two
the issue is most likely not with the thermostat, set the temp down to 65 degrees and listen for a click at the thermostat (it may not make any sound). go outside where the condensor fan is and look to see if the fan is spinning. if it is then the thermostat is probably ok. If you still are not getting anycool air and just warm air pumping out you may need to have someonne come and check the coolant level in your system. It may just need a recharge, but if you have lost coolant there may be a leak in your system. Alll that being said, you may need a licensed professional to come out and check your system
Mar 23, 2011 | Shaw Robert RS-9420 Thermostat
The refrigerator part is 60 degrees and the freezer part is blow 20 degrees, I found the cond fan motor locked up not running, I have cleaned the condenser coils, replaced the cond fan motor but the...
Please follow these steps.
Keep temp setting at 5 degree. Check defrost timer, thermostat and frost heater are working properly. Call repairman to check above all. Thanks.
Feb 02, 2011 | Admiral 26 cu. ft. Side-By-Side...
Wont get cool, can you refill?
Does AC turn on at all? if yes, remove front cover, do coils get cool at all? if no, thermostat may be bad telling unti that the desired temp reached is satified.. or.. you have the desired temp too low, if you have it set for 75 degrees, and it is 72 in your house, the fan will run and no cool air will be present.
Jul 07, 2010 | Kenmore 75085 Air Conditioner
I have a Honeywell programmable Thermostat (an expensive one that handles humidity, etc) and every spring and fall the thermostats behave improperly by ignoring the programmed temperature and cooling the...
What is the model number of the thermostat? What may be happening is the humidity control is trying to satisfy the humidity setting by running the a/c. In the installers set-up, there should be a setting to determine how long the system should run to satisfy humidity setting. I typically set thermostats for a 3 degree droop. Meaning it'll only drop 3 degrees below set temp. Also check your humidity setting to be sure it's not set too low. It should be set between 45% and 50%.
May 03, 2010 | Honeywell Programmable Thermostat Heater
Carrier unit runs all the time, never shuts down and the fan in the house will not shut off ' the house isnt getting beloe 80 degrees inside, even though I have the thermostat set at 76, I turned the...
Ya need preventive maintenance preformed evaporator clean condenser cleaned and the blower wheel clean unit could be under charged have it tuned up and your electric bill wont surprise you leave it running like it is and you will have a very large bill
Jun 27, 2009 | Heating & Cooling
Cannot set heat setting by using "hold" feature
make sure it is not telling you room temp, some of the Honeywells, will display room temp over desired temp. check that, if it wont let you switch temp than buy a new one, if you dont have a heat pump a new cheap stat is around 20.00.
Dec 31, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
354 people viewed this question
Top Bryant Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Mike Squire
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
