Question about Estate TAWX700JQ Top Load Washer
Wont spin how do i open to see the belts
Estate washer wont spin how can i open a older estate 3 cycle washer machine and see the belts
  • Anonymous Mar 22, 2014
    how to change belt
  • 121 Answers
Is it a direct drive moter?
Posted on Jun 02, 2009
Machine will rinse but wont always spin
Possible that the program controller is not proceeding sequentially to the program cycle and so there is a missed spin at some point.
Check the connections from the program controller, before it can be suspected.
Jan 22, 2013 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washer wont cycle
Number 11 is your lid switch. It is very easy to repair. To test it watch the video.
Older models would wash with the lid open but not spin. This later model washer won't wash or spin with the lid open so I suspect you have a broken lid switch. IF that turns out not to be the case then I would next check the motor start capacitor. When these fail the motor won't work at all.
On your machine you gotta have a long skinny screwdriver . On the back side of the washer you back out a screw on each side and then she pops up.
I gotta whole page of stuff on these washers HERE
Nov 01, 2011 | Estate TAWS850PQ
My estate washing machine will not spin out, all of the other cycles work correctly.
Hello
Try to clean the magnetic door switch,some windex and a paper towell.Just do the part on the door or lid and where the lid meets the top of the magnet.Make sure this is not loose and is seated in the machine.
You may need to unplug machine and remove the door switch,take both wires and tie them togther so they make contact.Then try a wash cycle or try the spin cycle.
The door switches in the estate washers fall apart and get corroded and can stop the spin cycle.
If the machine works with the switch taken out then you will need to get a new one from whirlpool.
Mar 25, 2011 | Estate Washing Machines
My hotpoint washing machine wont do final spin!!!
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Aug 23, 2009 | Kenmore 46462 Front Load Washer
My washer wont spin it shows an error e 13.
Thank you for contacting Fixya.com
Aug 19, 2009 | Bosch Nexxt 300 Series WFMC2201UC
ESTATE TAWS800JQ1 WILL NOT SPIN
May 27, 2009 | Estate TAWS800JQ Top Load Washer
Washing machine spin problem!!!!!
whirlpool estate washer is dun the clothes are ring Wet
Jan 13, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
My washer doesn't spin
if it will pump out in spin cycle then the motor coupler is most likely bad / larryyb
Dec 07, 2008 | Washing Machines
Final spin cycle
Lots of possibilities to check out before considering a problem with the machine: Is the load unsorted, too big or off balance? Drain restricted or too high? Oversudsed? Water draining completely out before going into spin?
Jan 08, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Estate TAWX700JQ Top Load Washer Logo
348 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
