Question about Dell 5650 Computer Speakers
In need of direction on how to install my 512 memory board into my desktop
Attempting to install my 512 memory need diagram
  • smith_tyrone Jun 02, 2009
    I need directions or a diagram on how to open the front of my desktop computer safely to install my 512 memory to my dell
  • John Moore May 11, 2010
    Install memory into desktop or laptop?
  • 256 Answers
Unplug all the wire attachments to the back of the computer. If you have never done this before, lable them so you can put them back, Lable each connection and cable with corresponding numbers.
Set the computer on it's right side. Remove the two or three screws holding the side to the back. Slide the side backward about 1/2 inch and lift off. Disconnect the power connections to your drives (1 red, 2 black & 1 Yellow wire) and gently move them out of the way. Disconnect the data cables to your drive (the wide flat ribbon cables) and move them out of the way.
If you already have the ram (Randon Access Memory) then you know what to look for. There should be an empty slot on the motherboard. You will see the the RAM module has two notches in it. Look at the slot where the RAM will go and insert it into the slot, lining up the notches correctly. Press down gently but firmly on the ends of the RAM module while you lift up on the latches to hold it in place. When it snaps into place, latches and RAM, then it is installed.
Replace the drive data cables and press them home gently but firmly. Replace the drive power cables. Re-attach all the wire attachments to the back of the computer. Start the computer. If it starts OK, then use it for a few minutes. Shut down the computer and replace the side and screws. Now it is all set. If you have problems, go back over your work to make sure it was done correctly. It is reasonably easy, but somewhat daunting the first time.
Posted on Jun 02, 2009
Will 9500 GT either 512 mb or 1 gb work on intel la crosse D865GLC board..?? it has 3 pci slots 32-bit long..
Yes you can.
For 512 Mb RAM you can use a single 512 Mb memory module or two 256 Mb memory modules.
For 1 Gb RAM you can use a single 1 Gb memory module or two 512 Mb memory modules.
Apr 13, 2011 | Intel Desktop Board D865GLC (MBIND865GLC)...
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
T2742 Desktop eMacine I want to upgrade the RAM from 256 MB to 1 GB. Can I replace the single 256 MB memory board with a single 1 GB memory board? Or, should I use two 512 MB memory boards?
Maximum Total Amount is 1GB.
EACH ram slot's Maximum Amount is 512MB.
Note* If you only install one ram memory module, make sure it goes into Slot 1.
(On the motherboard it may have DIMM 1, printed next to the slot)
Slot one is closest to the Processor. The processor reads ram memory that is in Slot 1, first.
Apr 16, 2010 | E-Machines T2742 PC Desktop
I have compaq presario 5000 series...and iwant upgrade my ram ...i have 128+128 sd ram so how much i upgrade my ram...can i upgrade 512+512 sd ram OR 256+256 sd ram...thank you
the RAM upgrade will depend on ur motherboard capacity and specification.
u need to check ur MB manual
if ur MB can have only SD RAM then only SD RAM upgrade is possible...DDR will not work....
so be careful while buying ur RAM
intelD845GLLy MB...the following details are from the intel website
http://www.intel.com/support/motherboards/desktop/d845glly/sb/CS-012825.htm
System Memory Features
The D845GLLY board provide the following memory features:
  • Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts
  • Unbuffered non-ECC DIMMs only
  • Maximum total system memory: 2 GB; minimum total system memory: 64 MB
  • Serial Presence Detect (SPD) DIMMs only
  • Suspend to RAM
Caution Do not use ECC DIMMs with the Desktop Board. Using ECC DIMMs could damage the Desktop Board.
Integrator's Notes:
  • Registered DIMMs are not supported on the Desktop Board.
  • This Desktop Board has been designed to support DIMMs based on 512 Mbit technology for a maximum onboard capacity of up to 2 GB, but this technology has not been validated on this board.
Note To be fully compliant with all applicable PCI33 SDRAM memory specifications, the board should be populated with DIMMs that support the Serial Presence Detect (SPD) data structure. This allows the BIOS to read the SPD data and program the chipset to accurately configure memory settings for optimum performance.
hope this helps
Reg....bye
Feb 24, 2010 | Intel D845GLLY Motherboard
How to install memory on ecs G550 laptop can only see one slot with 512 MB ddr sodmmm where is the other slots to upgrade to 1GB ram
There are two memory slots which support PC2700/333 Mhz memory, maximum 1024 per slot.
ECS suggests using identical/matched pairs of chips from the same manufacturer for their units.
In most laptops there is an access panel which when removed gives you direct access to the memory chips for replacement. I couldn't find a mainboard diagram for this unit so I am unable to see if the memory slots are adjacent on the board but there is little reason they shouldn't be. You should be able to access both slots once the proper access panel is opened.
This is the website page for direct contact with ECS tech support if you have any further questions: http://www.ecsusa.com/ECSWebSite/Support/TSSRequest.aspx?CategoryID=3&MenuID=19&LanID=0
Feb 05, 2010 | Generic Memory Computers & Internet
Help my pc is not detecting the correct amount of ram installed
Okay, first things first. IF the memory you installed is 1024 and you are using the on board video and it is 512 MB, you will only have 512 MB usable memory. This is because the on board video uses the installed memory to function. What ever the video memory is, subtract that form the total memory. If this is not the case, try re-seating the memory. If the numbers still do not add up then if there are four memory slots, make sure the memory is installed in the same color slots. Most desktops with 4 memory slots have two slots one color and the other two another color. Make sure both memory sticks are installed in the same color.
Jan 06, 2010 | Computers & Internet
512 MB memory boards do not work in my Fujitsu Lifebook S2020
frquance is not set and it is not recommand that 2 different friquance ram is not working propaties
Jan 09, 2009 | Fujitsu LifeBook S2020 Notebook
OptiPlex GX270 mini tower
Remove the 256mb memory and insert the 512mb memory in slot1 and see whether it works. Please note that the memory needs to be in pairs.
I think the GX260 is mini tower has two different moles
1) PC3200 compatible with memory - 184 Pin DDR3200 400MHz
2) PC2700 compatible with memory -184 Pin DDR2700 333MHz
Please enter the service tag on dell.com and find the manual and the right memory for your PC
All the best!
Dec 17, 2008 | Dell OptiPlex GX270 Small Mini-Tower...
Dell 5650 Computer Speakers Logo
171 people viewed this question
Top Dell Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
