Question about Acer X191WSD Monitor
I have am x191w monitor. I am getting a no signal message
All of the cables seem to be conected properly and I still get a no signal message. I have tried powering the monitor down and unplugging it
  • 256 Answers
Try the monitor on another computer. If it works the suspect the video card on first computer. Try a different video card in first computer with monitor to see if that works. If it does, re-install first video card in first computer and see if this works. If it doesn'r work, first video card is dead. If it does work then poor contacts prevented monitor from working but replacing renewed contects and it now works.
Posted on Jun 01, 2009
Need driver for Acer x191w moniter
http://www.nodevice.com/driver/X191W/get72415.html
get the monitor driver from this link.
You just have to put the code in the bottom of the website in above link and download it.
best of luck!
Mar 12, 2012 | Acer Computers & Internet
Acer x191w white display and lines?
possible a dropped monitor. bad 19" lcd monitor possible internal damage;
also check your cables connecting the 2 devices.
Aug 22, 2011 | HP Pavilion zd8000 Notebook
I have a samsung syncmaster 930b attached to an HP Pavilion Slimline s5660f Desktop PC, plugged into the DVI port of the PC. However, I cannot get the monitor to come up. There is power to it. I get the...
from user manual troubleshooting section
(When connecting D-Sub cable) Check the signal cable connection. (When connecting DVI cable) If you still see an error message on the screen when the monitor is connected properly, check to see if the monitor status is set to analog. Press Source button to have the monitor double-check the input signal source.
Source button Activates a highlighted menu item.
/ Push the 'SOURCE', then selects the video signal while the OSD is off. (When the source button is pressed to change the input mode, a message appears in the center of the screen displaying the current mode -- analog or digital input signal.) Note : If you select the digital mode, you must connect your monitor to the graphic card's port using the DVI cable.
https://images10.newegg.com/User-Manual/User_Manual_24-001-063.pdf ninth page in user manual
source button fourth from the left when facing monitor. looks like a box with an arrow pointing left.
Mar 05, 2018 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Signal cable not connected
what do you mean? You are getting that message when you switch on? Have you checked the signal cable between your PC and your monitor? If you cable is connected properly and you are still getting that onscreen message, it means your monitor main board has failed, and if its out of warranty, its time to get a new one, because few repair shops will touch them, and when they do, it is not cheap.
Jun 18, 2010 | BenQ FP567s 15" LCD Monitor
An Out of range box
frankr2327
If you are getting this message this means that you are connecting a device to the monitor and/or a connection that is putting out a signal that is not supported but the monitor. You may also need to look at the cable you are using. Example I have an XBOX 360 with the official VGA cable when I use it to connect to my monitor it works fine. However I have been testing cables to get a setup for my PS3 as I have not been able find an Official one from Sony. So when I connect my RBG to VGA cable to the end of my RGB XBOX cable then to my monitor I get an Out of Range message. So something with the cable is case a problem with the signal to not to be sent properly.
Note with monitors they have a safety feature that they would turn off if they got a signal they did not properly support and/or not read properly. This has always been there they just not got where they would show you a message. Plus with monitors getting bigger they have stopped supporting lower resolutions so you may see this issue more often when hooking up older devices. I my self still have a 15 and 17 inch on my work bench for toubleshooting.
Hope this helps clarify things. Feel free to reply back with what device you are having trouble with.
Issken
Dec 30, 2009 | Envision Computers & Internet
I turn on my computer but my monitor says there is no signal
hello, try to unplug the cables on your desktop, then plug it again, sometimes its loose, or sometimes the power supply on your computer is not functioning properly.
Nov 02, 2009 | Computers & Internet
No input signal
Make sure that the correct cable is used vga to vga or dvi to dvi..... try some different cable.... try a monitor slf test you cannot access it by just removing the monitor cable..... if do get the test the monitor is bad
May 02, 2009 | Computers & Internet
My monitor not turn on when the computar turn on to . and when you try to turn on the monitor its like flash for 1 sec and tune off to black . to turn the monitor on i need to prees the botten 30 time on...
First you sec your monitor power cable is not loos or power in properly if ok then you sec your monitor VGA cable is properly conect to your pc if ok then you disconnect your VGA cable in your pc then you power on your monitor and sec that youre monetor screen. show a masege or not masage like tiis : CHEEK SIGNAL CABLE or NO SIGNAL : if show this signal then you men your display card is not responding or monitor shows nothing then you meen your monitor is faulty then contact any monitor techenican and solve your monitor problem.
Jul 19, 2008 | Computers & Internet
Acer X191WSD Monitor Logo
257 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
