Question about E-Machines eMachines Desktop PC
2001 Hyundai Elentra window replacement
Ok, so I have never done this before. The driver window hasa 2 clips that attach itself to the track. One of the clips broke. I had to buy a brand new window to put in, but i am clueless on how to replace it. Windows are not my expertise. Anyone else done this? Can anyone walk me through this? HELP!
  • Dick
    Dick May 11, 2010
    The E-Machines computers are not compatible with automobile windows, only Microsoft Windows.
  • 98 Answers
One of those clips moves in and out,you have to push that side in first.then the other one will fall right in.
Posted on Jun 09, 2009
How to repair drivers window
Remove door inner panel.. Look for why it fell .. It is off the lift track, probably something broke.. find broken part and replace or repair.. its not uncommon for window regulators to break.
May 31, 2014 | 2001 Pontiac Grand Am SE
Can window clips on drivers side window be replaced ?
Are the clips that you are talking about the plastic ones that ride inside the track and attach to the cable?
Mar 16, 2014 | 2000 Oldsmobile Alero
Noticed a strong gas smell in the passenger compartment while idiling 2001 hyundia elentra
The fuel pressure regulator located on the fuel rail that supplies the fuel injectors must be check for wetness it has a vacuum line going to it if it looks wet replace it if it checks out ok locate and check the purge canister it may be malfunctioning.
Jan 05, 2010 | 2001 Hyundai Elantra
How do you replace front frivers side window on 2002 accent and can you send me pictures on how to do it. I had someone attempt to replace it and lost some of the clips and stuff, do most car windows...
There are no clips. There are 2 10mm bolts. Remove the door panel and roll the window down to where you can access these 2 bolts. Remove the bolts and turn the glass clockwise to remove it from the tracks.
The "clips" should be permanently attached to the glass. If they come off, you need to replace the window. We tried applying adhesive at the dealership, it only results in the same thing happening again within a year or so.
Dec 04, 2009 | 2002 Hyundai Accent
The front drivers side window on my 2005 Hyundai Elentra was working fine last night i rolled it down on my way to church and it got stuck and will not roll up. It appears to be off the track. Could you...
Sounds like the window regulator has malfunctioned. Best solution: Take your vehicle to an authorized Hyundai dealership and pay the diagnostic fee... they will tell you exactly what the problem is and the cost of parts/labor to fix it... at least this way you'll know what the problem is and what's required to fix it.
Oct 25, 2009 | 2005 Hyundai Elantra
Locked out of vehicle Broke out sliding center section
Put the top part first, and the lift it until you can put the lower part in and lower it.
Mar 29, 2009 | 2005 Dodge Ram 2500 Truck
2002 Land Rover Disco 2 Windows inop
Replace the Window Regulators and maybe the motors. Sounds like the drivers window has done what mine did and the cog has rolled off the end and jammed on the regulator. Reg's are cheap (£35 or so), make sure you buy some panel clips for the door trims as you will break some! A trim removal tool is also recommended. Clips are a few quid, tool is usually around £10 or so.
Jan 02, 2009 | 2001 Land Rover Discovery Series II
2001 hyundai elantra idling high
weeeeiiirrdddd. i have a 2001 hyundia elentra gls, and my third cylinder is misfiring as well. my car also revs constantly on idle and in between shifting. it will flutter between 2-3000 or it will just stay at 5000. i replaced my plugs and wires to no fix with my cylinder. autozone also told me that it sounds like my throttle position sensor needs replaced, but every part they try to sell me will not fit and they swear up and down this is the right part...
Dec 10, 2008 | 2001 Hyundai Elantra
Driver side window in 2001 Dakota
Jon,
after changing 2 regulators in my Dakota (1 front driver and 1 rear passenger), I can tell you that if the cables have "come off the track", then the regulator needs to be replaced. There are several Delrin clips/fasteners that hold the cable system in place. When one of these cracks/breaks, the cables come off the regulator assembly, and there's just no way to "re-route" since the mechanism is broken. I guess there is a small chance that one end of the cable just slipped out of the slotted holder, but I'm betting that one (or more) of the plastic clips have broken, and you need to change out the entire regulator. There not too hard to do, and you can by replacement aftermarket ones for about a $100. The first one I had replaced was done by a dealership, and it cost me $425.87....most of which was labor. Hope this helps.
KB
Aug 03, 2008 | 2001 Dodge Dakota
E-Machines eMachines Desktop PC Logo
46 people viewed this question
Top E-Machines Computers & Internet Experts
Matthew Spark
Matthew Spark
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
