Question about DeLonghi DBM8150 Work Top Blender
Handle came loose on DeLonghi DBM8150 - DeLonghi DBM8150 Work Top Blender
Took Handle apart and reglued broken pieces.
Posted on Jun 02, 2009
The power light on the Ninja Blender flashes and will not turn on.
Make sure the pitcher lid is assembled properly aligning the arrow on the lid with the arrow on the handle. Press down firmly on the handle until you hear a slight click to ensure it is fully engaged. The Ninja will not run if the lid is not assembled correctly & the handle is not fully engaged.
Sep 28, 2014 | Euro-Pro Ninja Nj600 1000 Watt Xl...
How to remove the top
are you pushing the handle release button on the lid, swinging the handle straight up and pulling on the handle straight up?
see page ten figure 6: http://www.ninjakitchen.com/manual/NJ600_30_IB_ENG_100527.pdf
Nov 10, 2013 | Euro-Pro Ninja NJ600 Pro Blender - NJ600
Ninja lid removal
your pushing the handle release button on the lid, swinging the handle straight up and pulling on the handle straight up?
Nov 10, 2013 | As Seen On TV Ninja Professional Blender
I took the spout of the smoothie plus 600 apart and can't put it back together
When you say you took the spout apart and can\'t put it back together its only 5 total pieces. The spout, the spring, the handle, the dispenser (rubber insert with plastic stem) and the threaded cap which holds the dispenser and handle to the spout.
If you can\'t get the handle to re attach, that does not surprise me. This is very poor craftsmanship. The plastic nobs that hold the handle onto the dispenser tend to break off.
If this is your problem, you can either, buy a new one for $5 plus shipping depending on where you live OR
You can fix the part that broke.
All you would need is a Drill, a small piece of number 14 copper about an inch long and same size drill bit. Drill the handle as close to center where the plastic molded nobs were located that either broke off or worn away. Then drill with the same size drill the stem to the dispenser which has the rubber stop attached. Drill this as close to the top of the stem where the nobs would snap in to hold the handle in place. You are basically making a pined handle, which will outlast the quality of this blender.
NOTE: You want to use a drill bit about the same size as the number 14 copper wire.
Then with one hand hold the threaded cap with the dispenser placed into position through the hole, be sure to put the spring in, small hole to the bottom of the rubber dispenser, pushing the spring and dispenser up through the threaded cap, attach the handle by putting the piece of copper wire in your hole which will connect your handle to the stem of the stopper. The copper should be cut no wider thent the width of the handle, if it sticks out a tiny bit, that\'s ok. The plastic cap will simply be carved out where the copper rubs against it. After that, simply screw the handle cap back onto the spout and screw the spout back onto the blender making sure the two washers are still on the pitcher.
All in all, for someone who is handy, this should take about 10 minutes. I would rate it about a 5 out of ten for difficulty simply because you have to drill straight and centered in the handle where the nobs were. Other then that its easy and if you can have someone help you put the pin in place, it would also make it easier.
If for some reason the rubber stop does not seem to go back into the spout, make sure the rubber didn\'t role up onto itself. Also if the spout drips, you didn\'t either put the spring back in or you didn\'t drill at the top of the plastic stem but some where in the middle, simply ream the hold towards the top where the plastic nobs would stop. Its a square reseated area in the stem. Looking at it you should be able to tell.
As for the spout instructions, you can download the pdf manual at the manufactures website: http://westbend.com/spl6white-smoothie-maker-plus-600.html
Hope it all helps, Its worked for me!
Dec 31, 2012 | Back to Basics 600 Smoothie Plus Work Top...
When ever i insert a sim card. It ask me for restriction code. And now i cannot use the phone since i got it.
If the Phone asks for Restriction code means it locked to network .It's Nokia ? You can get the Restriction code for Nokia Phones from Theunlockspot.com/nokia/rs10wp8/ and unlock it.
Jun 02, 2012 | DeLonghi Blenders
How do you remove the cuisinart blender handle to clean he glass beneath it?
i have a perfect answer! and own this very modle with the same issue. Plus i have done it myself.
Instructions:
*on the lower part of the hadle you will see two holes, with a small 6" school sized METAL ruler (no thicker than 3/4mm) gently insert it inbetween the two holes and push down. ((The handle has a clamp there) NOTE: you MUST start at the bottom of the handle or you will brake it!
*then while still inserted push the ruler away from the jar. this should releese the clamp that will allow you to remove the outer piece. REMEMBER your handle is plastic.
*now slowly lift upward and the side clamps will release. STOPpulling when you get to the at the top clamp.
*now you want to carefully hold your thumb down with slight pressure on the top of the handle (where you see the ingroved space that connects the hadle piece, it looks just the same as the bottom but without the holes) and lift up the handle slowly. this should release the outter part of the handle.
* now that the outside piece of the handle is off you can see the scews, unscrew with a phillips scewdriver and take handle fully off.
*Lastly the wire-like rings MUST be slipped off towards the bottom. do NOT try to prie off the wire-like ring from the little piece that is holding it together to create the ring, you will snap it.
*after you have taken off the rings, clean them with VIM (with bleach) by placing them FLAT on the sink edge to keep them from changing shape. Scrup away. Also scrub the plastic parts but DO NOT use the VIM on the outside of the plastic handle as it could scrub away the silver paint. only do this on the inside to remove the mold and grime.
NOTE: VIMis the only thing i found that will even remove rust build up. use an old toothbrush to scrub away the rust and grime. preferably dry with the vim, no need for water. water will dilute the VIM and cause it to be uneffective.
* you can take the little nub that conects the rings off by twisting them to the left or right, for cleaning, doesnt matter. I tried both ways but prefer to keep them on.
* now that you washed all parts let them DRY or you will end up with the same rust and grime issue. After the parts have dried you can now reasemble youir handle, and have peace of mind :)
* Try not to overdue the assable and reassambling of your handle, keeping in mind it is made of plastic and plastic wears easliy.
Hope that helps.
Jun 14, 2011 | Cuisinart CBT-500 SmartPower Premier Work...
My kitchen has a single handle faucet. The water
Check the aereator screen at the spout. Commonly get clogged.
Dec 31, 2009 | Blenders
REPLACEMENT GLASS JUG FOR KF 1850M DELONGHI BLENDER
I want to replace plastic jug of my blender, It leaks
Dec 09, 2007 | Bosch MMB2000 Work Top Blender
DeLonghi DBM8150 problem
These instructions disassemble an electrical appliance. You should have some technical/mechanical/electrical experience to attempt this and you do so at your own risk.
See exploded diagram : http://www.kenwoodservice.co.uk/uk-delonghi/exploded/exploded-KF8150M.pdf
This is not a very good diagram to show the disassembly, however, it will at least help me to identify the parts.
Prise out the center insert in the drive wheel (#15 on the diagram) on the top of the base unit (I used a paring knife and worked my way around the circumference to work it loose).
Remove the four rubber feet (#19) from the base by pulling them out.
Undo the 4 phillips head screws in the holes where the feet were.
Remove the base and carefully position it along-side the body of the blender.
Prise off the silver switch knob (#13) - it slides straight off the switch shaft and I used a screw driver to carefully lever it off, working from each side a little at a time.
Undo the drive wheel on the top of the drive shaft by holding the fan on the bottom of the drive shaft and turning the drive wheel CLOCKWISE.
Undo and remove the two screws holding the switch support (#11) and cut the tie wrap that secures the blue cable to this support.
Undo the four screws that secure the motor assembly to the casing and remove the screws and their shake-proof washers.
Remove the internal components as a single assembly. Tilt/angle the motor assembly towards the switch support until the top of the shaft clears the rubber boot in the top and then the whole lot comes out easily.
To replace the switch (Part No. HS1144 - #10 on the diagram):
Carefully lever the white gear wheel off the switch shaft.
Undo the two small screws that hold the dial gear wheel cover in place on the switch support.
Remove the cover and the small gear wheel (noting which way around the gear wheel goes the two ends of the shaft are slightly different).
Undo the nut on the switch shaft that that secures the switch to the support (nut is 14mm diameter and needs a thin wall socket. I used long nose pliers to remove and re-install it).
The wires connect by simple push fit into their slots and the angled brass blades inside the slots grab the wire and lock it in place. To withdraw each wire, use a very thin screw driver (or similar) to depress the brass blades inside the slot. This enables the wire to be withdrawn as you depress the blade.
Re-assembly is the opposite sequence.
When putting the dial back together, remember to check that the dial reading lines up with the switch position (adjust the gears by resetting the teeth if the alignment is not correct.
Here’s the really interesting thing. After I replaced the switch, I pulled the old one apart. IT HAD FAILED BECAUSE THE CONTACTS HAD BURNT OUT. They had obviously been arcing and had completely burnt through. There were burnt off tails of the contacts lying in the switch housing and there was evidence of burning (carbon deposits) inside the switch. In short – the switch is not up to the job and will fail. Poor design and a latent defect.
Aug 17, 2007 | DeLonghi DBM8150 Work Top Blender
DeLonghi DBM8150 Work Top Blender Logo
80 people viewed this question
Top DeLonghi Blenders Experts
eyecam
Ross Keen
Are you a DeLonghi Blender Expert? Answer questions, earn points and help others
