Question about Frigidaire Dryers
We have a stackable unit and whenever we have to unplug it, the dryer will not heat. Is there a reset button?
We have a stackable unit and whenever we have to unplug it (we're renovating), the dryer will not heat. Is there a reset button? We've tried everything...sometimes it just starts again. Frididaire Model FEO1442ESO. Thanks.
  • 121 Answers
Can you describe to me alittle more in detail what your doing and is it electric heat
Posted on Jun 02, 2009
Low heat in stackable dryer
get a dryer vent brush--clean out the dryer and vent--allow the unit to breathe--
May 17, 2014 | Frigidaire 7 Cu. Ft. Stackable Electric...
I have a frigidaire stackable washer/dryer model number FEX831CS0 an the washer works but the dryer is seem not to be getting any power
Hello cbrhonda125 - Try resetting the unit dryer by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes. Restart unit and if it proves to be ineffective, there are multiple possible causes; faulty power cord, house wiring, defective control board, thermal limiter or door switch. This is something that a professional would need to properly diagnose.
Dec 19, 2012 | Frigidaire FEX831CS Top Load Stacked...
Kenmore dryer stackable unit, no heat coming from dryer, all else works
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 24, 2011 | Kenmore Elite HE4 Electric Dryer
Electronic moisture sensing Kenmore stackable dryer, smells like gas when it runs only. Heats up. I opened it up and looked in back, I can see a red glow then it shuts off, kind of intermitant. Whats...
This is usually caused by lint on the heating element, You should have it cleaned out by an appliance person or if you feel comfortable you can unplug the unit, remove the back panel and try cleaning it out your self. you should also try cleaning as much as possible from behind the lint filter inside the drum. Hope this helps.
May 05, 2011 | Dryers
Is there a reset button on Frigidaire stackable washer/dryer combo. Dryer will not come on, washer works fine. thanks
Sorry to read about your problem.
Sorry no reset switch.Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective. in addition you may have a clogged dryer vent.
I suggest you place a call to a service company.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
Dec 25, 2010 | Frigidaire Washing Machines
How do i replace the heating element on my kenmore stackable washer dryer 98702 machine
Could you please post the model number of the unit? It will be under the washer lid, in the dryer door, on the top, or the side of your unit.
Dec 25, 2010 | Kenmore Washing Machines
I have a frigidaire dryer (front loader) and the it keeps flashing 'error' and continuously beeping - The dryness panel has all 4 lights blinking. It's a stackable, so I can't get in the back to try and...
Try and turn off the main circuit breaker to the unit for a couple of minutes.if this does not reset the machine you may need to replace the control board make sure to check and make sure none of the buttons are stuck.
Sep 08, 2010 | Frigidaire Dryers
Dryer of stackable washer/dryer stopped heating... is it fixable?
yes tis unit is fixable the most common problem is one of the thermal fuse has gone bad.the heating element could also be bad.
does the unit still run and you just have no heat check the above items this should take care of you problem.
Sep 18, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity...
Electrolux washer/ dryer dryer not heating
Actually on most models there are thermal fuses (nonresetable) that do shut only the heater down but on yours it shuts the entire machine down so it sounds like either you dont have 230v to the unit (what i mean is it is common for one line to have burned out either on the terminal block where the cord is attached or in the home wiring the washer and dryer motor will work because all that only needs one line to work) or the heater )the element) is bad. Tear down is not very easy since its a stackable.
Nov 16, 2007 | Washing Machines
Kenmore stackable
Dryer probably element or thermostat, washer sounds like a suspension arm collapsed. Price up the parts & then decide if its worth it! Regards
Apr 09, 2007 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
156 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
