You will need to remove the fuel tank. The less fuel there is in the tank, the easier it is to do this. Remove the seat, then uncouple the quick release fuel line connection by pulling down on the chrome ring where the fuel line enters the fuel tank; the fuel line should pop free. You might want to place an absorbant rag underneath to catch any fuel that spills. Next, Follow the electrical wiring from the bottom of the tank rearward where it meets a connection plug behind the engine against the frame downtube. Disconnect this coupling and free the wire harness from the bike. There is a vent tube built into the bottom of the tank; unplug the fuel tank vent line rubber connection there. Remove the front and rear fuel tank mounting bolts. Once the tank is off the bike, turn it over on a soft, non-scratch material or pad. On the bottom of the tank you will see an oval plastic fitting where the fuel line and wiring harness attaches. Remove the eight or so Torx head screws and carefully remove the fuel pump assemble from the tank. You kind of have to twist and turn the unit to get it free; go easy. The fuel filter resides inside the tall translucent plastic housing. There is a clip attaching the filter housing to the fuel pump assembly. You can use a screw driver or suitable tool to remove the clip. Watch out or it will take off on you! After the housing is free, the fuel filter can be removed by slowly rotating the housing to free it from the o-rings that secure it. Remove the filter.
Reverse to reinstall.
