Question about HP Pavilion A730N (PJ510AA) PC Desktop
Front panel wire placement
I just bought a new case and I forgot were the font panel wires go please help Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Motherboard: ASUS PTGD1-LA
  • HP Master
  • 4,806 Answers
Hi there.
Get a strong flashlight and a magnifying glass (if you have one). On the motherboard look for the front panel, it should be marked PWR and coloured green, also the plug that connects to it should be marked PWR_SW. On some boards there are no colours but the markings are the same, so take a good close look.
Have a look at these pictures for an idea >>>>>>
Please post back with the results and any more advice if needed.
Good luck and thanks for choosing FixYa!!
Posted on Jun 01, 2009
Needed to move motherboard to new case because of overheating / ventilation problems - do not know what the power / reset / hdd led leads are for the 9 pin f_panel (new case has each as separate...
Photo of the Asus M2N78-LA motherboard,
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&cc=us&docname=c01421635&dlc=en
This photo also shows the orientation (Direction), that the motherboard is sitting in a computer case.
To the very bottom right is the Front Panel header.
The front plastic panel of the computer is the Front Panel.
The area of pins on the motherboard that the cables, (Wires) from the Front Panel connect to, is the Front Panel header. ( F_PANEL )
The Front Panel header, is the black rectangular shaped plastic block, that is sitting vertically on the motherboard.
Has two columns of pins.
4 on the left side, 5 on the right side. Makes it look as though there is a pin missing, at the top left corner.
I'm going to number the pins.
Pins on the Left side starting at the Top, going down;
Pins 1, 3, 5, and 7.
Pins on the Right side starting at the Top, going down,
Pins 2, 4, 6, 8, and 10.
A) Pins 1 and 3 are for the Power On switch. (Power On button)
B) Pins 5 and 7 are for the Power On LED light.
Pin 7 is for the Positive ( + ) wire.
(If the LED light is dim, reverse the wires around)
C) Pins 4 and 6 are for a Reset switch, IF a Reset switch is used. (Reset button)
D) Pins 8 and 10 are for the HarDDrive activity LED light.
Pin 10 is for the Positive wire. ( + )
(If the HDD LED light is dim when operating, switch the wires around)
Pin 2 at the top Right is NOT used. (NC. Not Connected)
For additional questions please post in a Comment.
I am looking at a motherboard manual in PDF file form, for the Asus M2N78-LA motherboard.
Regards,
joecoolvette
Sep 03, 2011 | HEWLETT-PACKARD HP Pegatron M2N78-LA ASUS...
Today i just cleaned the mother board m4n68tm asus, and i joined reset-sw , power led & -, power sw, hdd wire on my on, at the first statup there was nothing but nw when i shut it down and than...
Hi, I am giving a link to download your motherboard manual. CLICK HERE to go to page. Choose your language for the manual and download. Scroll down to front panel connectors and you will find the correct pin placements.
May 25, 2011 | ASUS M4N68TM Motherboard
How to rewire an NSPIRE ASUS p5p800se. Wires for microphone and speakers to motherboard were damaged.
I'm not sure that the damaged wires are the ones that connects your peripheral audio devices with the jacks on the rear panel of the motherboard. If these cables are damaged you can easily replace them with new ones. If the problem is on the rear panel jacks you can partial replace the usage of these jacks with the front panel connectors. In case of a problem on the board here is the front panel pins.
The whole manual for your motherboard is available here.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Feb 27, 2011 | ASUS P5P800 SE Motherboard
Correct front panel wire connector to the motherboard pins
Please refer to the link that i provided to you for the detailed information of your motherboard. Please click here.
May 31, 2010 | ASUS P5PE-VM Motherboard
Asus P5LP-LE Motherboard Front Panel Pinouts
N/C Reset Gnd HDLED- HDLED+
GND PWR PWLED- PWLED+
Mar 11, 2010 | ASUS P5LP-LE Motherboard
Asus chassis wiring confusion for front mic input [colour code?]
the wires comming from the front of the case. at the end of the wire on the black insulator should have a stamp on it telling what the wire is.
Mar 22, 2009 | Computers & Internet
Which wires are positive on the front panel of case
Don't forget it is about pairs. You never gonna see a pair {Red with Yellow}
RED = +
Black = ground (minus)
yellow = +
white = ground (minus)
green=+
black=ground (minus)
Jan 12, 2009 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
FRONT control PANEL Wiring
You need to determine manufactuer of board go to there website and download the user manual ...
Jan 09, 2009 | FIC VI 13L Motherboard
Front panel audio connection to asus pk5 se mobo
Hi Tracybow,
The Front Panel Audio connection should have a couple of wires to plug in into your MotherBoard. Usually, the connectors are named and all you need to know is the exact location in your MotherBoard.
I would suggest you to visit your MotherBoard manufacturer and download the manual for your MoBo. You will find in the manual a diagram of the MotherBoard which shows the location for those wires.
Hope this helps.
Best regards
Eduardo
Oct 03, 2008 | Computers & Internet
Wires they connect two 2 pins on motherboard
Do you have the manual of the motherboard, please mention the type, make, model, manufacturer of motherboard please this way we can help you out. Also please try to mention your question clearly.
Thanks
Dec 10, 2007 | ASUS P4C800 Deluxe Motherboard
HP Pavilion A730N (PJ510AA) PC Desktop Logo
322 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
