Question about Garden
Spin trimmer only accelerates about half rpm's. new carb. same pr
Acts almost like the brake is on a chainsaw. string spins but only as strong as the engine revs. I put a new carburetor on and then took the clutch off and still have the same problem.I'm stumped. it is a shindaiwa t242 spin trimmer
SOURCE: Ryobi gas string trimmer won't run
I have a RYobi SS30 and it will not run at all. I have pulled the cord about a hundred times, yes after about 10 I should have gotten the picture, but if anyone knows what to do to correct this I would appreciate this. I am not very mechanically inclined so any help would be appreciated
Posted on Sep 28, 2008
StickyBeets
SOURCE: put string on tb425cs troy bilt trimmer
there are two ways to install the string..the cool way is without pulling the inner reel off the trimmer..just leave it in place..cut (2) approx.two arms length (thats spreading your arms out like airplane wings) of .095 string..now, align the arrow of the inner reel (it turns counter clock-wise..the arrow points outward) with the arrow on the outer spool (pointing inward)..holding the spool and reel together so the inner reel doesnt move, push one of the cut strings through the eyehole in the side of the outer spool, and it should come up to the right, through a slot next to a small round hole the diameter of the string..if it doesnt, it just missed the exit (as i call it)..pull out and try again..let about an inch come thru..now take that end of the string and push the line into the little round hole until it stops, which should be about a little more than 1/8 of an inch..hold it in while pulling the excess line outside the spool to keep it in place..now do the same with the other string for the other side..once you have both lines in place, turn the inner reel counter clock-wise to draw in both lines through the eyeholes of the outer spool..you may or may not get all of the line to wind in..not a problem..you will still have enough to do what you need to do..just cut off the rest..one problem you may or may not have that i do most of the tyme is that it gets hard to turn the inner reel..one solution is to bump the top of the 'bump knob' with your fist, then pull both strings at the same tyme, then continue to turn..this method is quicker and easier than the second way of having the inner reel out and trying to wind both lines at the same tyme and trying to place the reel back in the spool..hope this works for you...
Posted on May 19, 2009
#1 Taper
  • 1040 Answers
SOURCE: engine starts finem, but will not reach fill RPM.
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Posted on Jun 28, 2009
moretons
  • 155 Answers
SOURCE: Troy-Bilt TB425CS trimmer hard to start, won't accelerate
Hi the key is moulded as part of the flywheel on most machines these days which doesent take much to sheer off , By the sounds of it this may well be your problem.
Posted on Sep 08, 2009
  • 63 Answers
SOURCE: TB465SS trimmer won't rev up
change spark plug and check the gap between points
Posted on Jul 24, 2010
IT STARTS BUT TRIMMER PART WONT TURN
Disconnect the two halves of the shaft. It should be pretty easy. Inspect the drive cable to make sure it hasnt snapped. Also make sure the cable is inserted into the female half. Its a square shaped cable that spins and drives the string trimmer head.
Jul 24, 2016 | Troy-Bilt 25cc 2-Cycle Curved-Shaft Gas...
What do i need for replacement string? Can i go heavier or stay with the smaller string? This is for mastercraft 20v grass trimmer. thanks
the size of the string is critical in electric driven trimmers
it does have mass and the thicker string will over load the motor
stay with the recommended string size and keep to the recommended distance to the grass being cut
string line cutters work on the principle that the tip speed of the string is what does the cutting and that means that the first 1/2" of string cuts the grass
the rest back to the hub acts like a brake as it is dragged across the grass and slows the cutting speed and loads the motor
remember that the machine is designed to trim edges and not to cut down growth-- that is a job for heavier duty units
May 13, 2016 | Garden
Why does the weed eater not trim even though it spins?
it is getting hot from friction because you cannot tighten it so the head spins but everytime it hits a wed it tries to stop spinniing because it is slipping from the bolt not tightened. fix the bolt hole with a tap and put in a new bolt
Jul 14, 2015 | Troy-Bilt Troy-Built Gas String Trimmer...
Head not spinning shaft cable is.
place a screw driver in the slot the drive goes into and hold the trimmer head feel the head
Aug 16, 2012 | Troy-Bilt Troybilt Mtd String Trimmer...
Stihl fs-46 string trimmer wil staqrt and run(idle) but will not run high rpm or accelerate. Cleaned out carb and checked spark plug already. Grog
2 things to check firstly run it without the carb foam filter see if it revs then and secondly thin gas mixture by half for testing see if that has any effect. You are basically testing fuel mix ratio and testing that it is receiving enough air.
Jul 04, 2011 | Garden
I bought a new grass trimmer, gardeners choice, it would not start, noticed the end were you put the nylon keeps turning around,some how that shouldn't, .
Your trimmer may not have a centrifugal clutch, and if that is the case, the string head will turn when you pull on the starter rope and it will always rotate with the engine running. The trimmers with the clutch don't engage the drive shaft until RPM's are up to a certain speed and when that speed is achieved, the clutch engages the clutch drum, the flex drive turns and the string head begins spinning.
May 07, 2011 | Garden
My TB70SS cranks and runs perfect! The problem is the clutch seems to not engage. The head will spin at idle speed, but, when I pull the throttle trigger, it seems to bog a bit, and the head almost quits...
There may be an issue with the clutch or the clutch drum. Some disassembly may be required if the string head doesn't spin quickly when accelerating the engine. The clutch itself is threaded onto the crankshaft of the engine near the handle end and the clutch drum is screwed into the end of the crankshaft. If you can disassemble to that point, you will be able to diagnose your clutch problem...maybe it is worn severely and needs replacing.
Aug 14, 2010 | Troy Bilt Tb70ss Gas Trimmer
Can't set carb. on Husqvarna chainsaw.
Most chainsaws and small engines are 1.5 turns out.
You need to set the mixtures for the carburetor. You will find a Low and High adjustment screw. At idle turn the screw in or clockwise until the rps starts to decrease. Then start turning it out till you hit max idle rpms. Turn screw back in a quarter to half turn and it should be idling smoothly. Be careful here and get someone to hold saw if necessary but hold in throttle to full speed and do the same with high adjustment screw. turn it in till rpm starts to drop then back it out until you get to max rpm and it won't go any higher then turn it back in a half a turn.
Jun 20, 2009 | Husqvarna Forest & Garden 125l 18" Gas...
No power
It sounds like you have something wrapped around the spool, (where the string is), that is keeping it from spinning.
If that's not the problem, then it is the carburetor. It will need to be cleaned or it will need a new carb. kit. How old is it?
Let me know if you need cleaning tips.
Jim
Jun 11, 2009 | Garden
Troy Bilt in Hell String Trimmer TB465SS Running Problem
You need to clean the carb. or you may need to buy a carb. kit. But do a cleaning on it first. If you need tips on how to best do this, just let me know. Also check the fuel lines for cracks. As they age, they become brittle.
Jim
May 31, 2009 | Troy -Bilt String Trimmer/Blower...
Garden Logo
110 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
