Question about Indesit W 123 Front Load Washer
W washer My Indesit washer has the door LED flashing only, can anyone suggest what this means and how it can be fixed?
    Champion:
  • 249 Answers
It maybe door electric lock easy to fit,take door seal at the front ONLY,take off the two screws holding on lock,have new one in hand, lock I mean,copy the way the three wires are on the old one,swop for the new one.bye Ire.
Posted on Dec 24, 2007
Indesit washing machine
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Oct 14, 2015 | Kenmore 24032\24036 Top Load Washer
Indesit wil 153 door red led is flashing after I set washer settings, doesn't start cycle ?
The flashing light means that the machine thinks the door is not closed (The door lock switch is not activating). 99% of the time this is simply a sticky switch and the solution is to give the door a good firm slam shut (Don't get silly here, but it will take a pretty good "teenager slamming the bedroom door in a temper tantrum" type slam).
In the event that this doesn't work, then you're looking at a faulty door interlock switch. They're not that hard to obtain or fit if you're fairly confident. Drop me a comment back here and let me know how you get on. Happy to help further if the above hasn't allowed you to solve the problem.
Aug 15, 2011 | Indesit W 123 Front Load Washer
Iwde12 indesit, not selecting programmes not releasing water, not drying
Hi, I have an indesit IWDE12, I programme the washer which then starts to spin with no water, after 2-3 mins the rinse light, the clock light and the door lock light start to flash and tha washing stops. Does anyone know what this problem could be?
Jun 15, 2010 | Indesit W 123 Front Load Washer
Indesit widl102 washer dryer has 2 led lights flashin
unplug it for a few minutes and plug it back in again might be a pain but till you can get it serviced it should delete the fault code and run thru a full cycle. hope this helps a little.
Not a true fix just a work around.
best to you.
Nov 30, 2017 | Indesit W 123 Front Load Washer
Lights flashing on indesit WIL123S
Hi, sounds like you need to change the door interlock located where the door catch pushes into.
Take the top off and undo the two screws with a tork screwdriver
and replace.
(Remember to turn off the supply and pull out the plug top)
May 09, 2009 | Indesit W 123 Front Load Washer
Indesit W123 5 flashes error!!
The F05 fault means the pump is blocked, check the filter at the front bottom right of the machine behind the plinth and if its connected under a sink check the hose & connection
Nov 03, 2008 | Indesit W 123 Front Load Washer
Indesit W1A 111 front load W/M
hiya
no need to worry they do this.
hope this helps
please dont forget to rate the helpfulness. thanks kj
Jul 20, 2008 | Indesit W 123 Front Load Washer
INDESIT 1000 DOES NOT START
Had a similar problem ,flashing red led means door not locked, I removed door from machine removed front from door and found hinge pin for lock had come adrift, religned pin and chapped back into position .THen replaced door and door to machine .dor shut and lock worked perfectly, hope this helps
If this doesn't work you may have to replace the EMW. Should cost you around 60$
May 23, 2008 | Indesit W 123 Front Load Washer
Indesit Standard WIL 123 (UK) Washing Machine
Jan 04, 2008 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
199 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
