Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
Transmission leaking fluid
Hi, I have a Husqvarna GTH2654T riding lawnmower. I was having issues with mower not having the able to climb the hills it use to climb.I replaced my belts and 3 of my pulleys. Now does it not climb hills but it barely goes on flat grown. I have also noticed fluid dripping from transmission. My transmission is a Turf Tork 7A646084160 S/N #46BN0001512 if that helps any. I think I am low on transmission fluid but not sure how to add it. Also I guess I need to fix the leak. Can you help me?
  • Lowell Harris May 11, 2010
    Have you had the rear wheels off?
I am having the same exact problem. If you do get an answer, please relay it to me. noslo.d@juno.com
Posted on Sep 27, 2010
When a husqvarna lth 2142d ride on lawnmower losses speed what is problem
21 hp briggs big motor
if not a drive belt or gearbox issue
is the Governor set properly
rider mower serviced regularly
carby jets adjusted
no stale fuel clean fuel filter
valve clearance to spec
newish plug
not burning oil
Oct 24, 2016 | Husqvarna Garden
Husqvarna snowblower brand new wheels will engage then stop at all times transmission issue noticed yellow fluid in snow
Get a hold of where you bought it. Should be under guarantee
Should be no oil leaking..
Jan 27, 2015 | Husqvarna Garden
What would cause the mower to slow down and stop after 3 hrs mowing then after it cools down it moves what would cause it to do that ?
you have unseated valves the hotter it gets the less power you have until it stops to cool down need to take to shop and get vavle job about 100.00 dollars if you wait you will damage motor
Aug 29, 2014 | Husqvarna Garden
Wireing diagram husqvarna rideing lawnmower
check with the dealer on this... I even have issues with Husqvarna and there wiring diagrams and I'm a dealer !!!
Aug 22, 2014 | Husqvarna Fast Tractor YTH24K48 48" 24HP...
Husqvarna riding mower yth2448t won't go up hills
Check oil level in transmission. Only replace with Synthetic oil 15W-50 of high quality. It is very expensive, but well worth it! Transmission may be stuffed.
Jul 20, 2014 | Husqvarna Garden
Cub Cadet LT1046 shutters when under a load, climbing steep hill
i would check the belt for oil or slipping the check rear axle fluid level
Mar 27, 2012 | Garden
My husqvarna mower has quit moving. The engine runs smoothly but when I shift out of neutral, nothing happens. It stopped working suddenly. I have moved the small lever in the back that allows you to...
either the drive belt from the engine to the top of the transmission has broken or gone slack due to a tensioner issue, or the transmission has failed. with the engine NOT running you can put your hand up under the deck and feel the topmost belt, if it is there and snug, then you have a transmission problem and that requires a replacement.
May 25, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
820 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
