Washing Machines Logo
Anonymous Posted on Jun 01, 2009
Out of balance condition
Kenmore HE3T Out of balance during spin. It doesn't matter if it is in extra-high or extra-low spin mode it still wobbles and knocks things off the top of the machine. No whining noise, just what is clearly an out of balance condition. Large load or small load, same problem. It seems to be getting worse (once only in extra-high spin, and now all spin modes). Any advice will be much appreciated. I would like to attempt to repair this machine as it's my daughter's but I am from out of town and may not have time to wait for parts. Thanks in advance. My washer is a front load and knocks during the spin cycle. I have leveled her a nd also taken off the back panel and the springs and struts appear to be fine. I have only had this unit for three years. Where do you go from here?
  • Anonymous Jun 03, 2009
    Yes it is belt driven. I have the front panel off and ran the unit. It's start off fine on spin cycle than as it increases in speed its still knocks. The knock seems to be coming from the drum weights.
J. Bradshaw
Level 2:
Sniper:
  • Expert 121 Answers
  • Posted on Jun 01, 2009
J. Bradshaw
Expert
Level 2:
Sniper:
Answers
121
Questions
Helped
87686
Points
323
I had a Fridadaire model and had the same problem. It could be 3 things. 1- the weight came loose that balances the drum. 2- the bracket that is attached to the drum could have cracked. 3. the bearings to the drum have worn out. All of these problems involve taking the washer completely apart. This is big process, but if you have time and patience it worth it.
Is this model belt driven?
  • J. Bradshaw Jun 03, 2009
    One more thing it could be. Look to see if you washer has springs holding the top of the drum and on the bottom of the drum there should be an absorber on each side. See if any of these have came loose.
How to run diagnostic on Kenmore elite smartwash quiet pak 9 HE4t washer? Model#110.45087401
Diagnostic mode for Kenmore Elite He3t model 110 42926 ...
iFixit https://www.ifixit.com > Answers > View > Diagnostic...
Apr 8, 2016 - With the washer empty, close the door. · Push "control/on" or "Start" · Select "Drain/Spin" · Select "No Spin" by pressing SPIN SPEED touchpad.
3 answers · 2 votes: I believe this is very similar to the model I have. Here is what I did to run a diagnostic. ...
F11 error code during Diagnostic test? - Kenmore ...
1 answer
Jan 18, 2016
SOLVED: F11 code error on Kenmore HE3 - iFixit
Mar 3, 2011
SOLVED: f h error code - Kenmore Elite HE3 ...
Feb 21, 2012
It seems like the washer has no power - Kenmore Elite ...
Nov 2, 2017
More results from www.ifixit.com
Diagnostic Test; Starting The Test Mode; Test Program ...
ManualsLib https://www.manualslib.com > ... > User manual
Close the door. Select the DRAIN/SPIN cycle. Select NO SPIN by pressing the SPIN SELECT button five (5) times. Push Prewash Option button four (4)times within ...
Diagnostics ok but only spins slow
Water pump screen is plugged. Will not drain properly even though it goes into high spin.
1helpful
My Kenmore Elite 3T washer has a loud whistling noise in the spin cycle. ??? Thanks!
Hi.
When that happens it is often because the drum bearing is starting to go. The first symptom is a loud high pitched noise during the spin part of the cycle. As problem gets worsening you will notice that the drum will be a bit wobbly if you spin it by hand.
Here parts and diagrams.
Regards.
Ginko.
My Kenmore elite he3t is giving me a problem in the spin cycle. Even thought the spin setting is set on high or extra high, the drum turns very slowly and will eventually stop and the washer starts...
The machine will not advance to the high-speed spin cycle unless the water is drained first. The F02 error code manifests this condition as it means draining problem. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working. The display can be cleared by pressing the Pause/Cancel button twice.
Disconnect power and remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Click on the link below for further troubleshooting should the cleaning of the filter does not resolve the problem.
Troubleshooting Error Code F02 on Kenmore Elite and Whirlpool Duet Front Load Washing Machines
Sides vibrate during spin causing a lot of noise and machine moves. could it be out of balance?
1- Clothes are not balance inside the tube. Try to rebalance the clothes when it happens. It usually happens when towers leaning on on side when water level selector not set appropriately. 2- Try to level the washer by adjusting the leg screws at the bottom of the washer. 3- It make a lot of noise since the whole washer moving against the floor. When it spin only the tube then it won't be like that.
2answers
Kenmore elite make a funny sound during a drain spin cycle
it either is the something in the pump or something in between the inner tub and outer tub
1helpful
check the drain pump in the bottom of the unit and verify its not clogged, verify unit is level, also check the support struts/springs for the tub.
Spin issues
Your clutch is no good You will need to replace it.
Empty washer tub wobbles during spining, plus burning smell
BOTTOM OF TRIANGULAR PLATE ARE 3 SKID PADS, USUALLY WHITE OR BROKEN HALF MOON SHAPE WHEN WORN OUT RESULTS IN THIS
Maytag MAH3000 new bearing & seal kit still out of balance on high spin cycle
send me an email at [email protected] ill send you a service bulletin that might help
Alexander
vince
