Question about McCulloch FHH18A Electric Pressure Washer
McCulloch FHH18A - Wash Machine Hand Assembly leak
When I set up pressure washer and make sure of water flow, etc. I then turn on the electric. The Wash Machine Hand Trigger starts spraying out water out the sides in addition to shooting a stream of water out of the end of the trigger. What would cause the trigger to stream water out the side of the trigger?
4 Suggested Answers
  • 104 Answers
SOURCE: pressure washer leaks
I had a Karcher water sprayer that did the same thing , the repair man told me it could be repaired IF he could get parts , guess what, he COULDNT get parts so i had to buy another one , the answer to your question is yes they can be fixed provided you take it somewhere that can get parts . hope this helps
ps i could have fixed it myself with the right part, its not a hard job to strip it and rebuild it
Posted on May 26, 2009
  • 19 Answers
SOURCE: Where can I purchase oil rings that go into the
I assume you mean the rubber O rings inside the wand. I had to replace mine as well. I had to visit several plumbing supply stores to find one that fit. I ended up taking the end of the wand with me so I could make sure the O ring fit. The ring you are after is a number 5, but you need to make sure it is thick enough to make a good seal.
Posted on Sep 14, 2009
Asbestos 56
  • 191 Answers
SOURCE: I have a McCulloch FHH18A
I would guess there is a leak somewhere inside the unit that is spraying water on some electrical component and causing a ground fault.
Posted on May 16, 2011
Trigger don't release
I have a hose and gun that fits the McCulloch FHH18A that I no longer need as I had to buy a complete universal hose/gun and wand unit since I had broke the wand and the replacement wand was no longer available. If you are interested in it, email me at burmakow@nwciowa.edu and we can figure out a price.
Apr 28, 2012 | McCulloch FHH18A Electric Pressure Washer
Prssure washer m1000 3 hp used to wash boat water leaks from inside cannot find allen wrench to fit wrench has small hole in center
They are probably not allen head screws but rather tamper proof Torx screws. You can break out the small pin or you can now buy special Torx bits with holes to remove tamper proof screws. They should be available at most hardware outlets or at shops that sell Chinese imports. Torx bits are prefixed with a "T" and the size you are looking for is probably about a T20, but the sets come with an assortment of sizes up to about T40.
Apr 22, 2011 | McCulloch FHH18A Electric Pressure Washer
1. Decrease in pressure. Can't clean deck properly. 2. Water leaking from underneath. 3. There is a short clear hose not attached to any thing. 4. I'm not a mechanic. I'm an x-ray tech and my...
If the pump is leaking then it is going to either be the water seals or o-rings on the inside of the pump. If this is the case I would recommend just tossing the unit, what it would cost to rip the machine apart and replace these items would be more than what the machine is worth.
Oct 15, 2010 | McCulloch FHH18A Electric Pressure Washer
Doesn't attain high pressure
possible orifice is clogged,either end of connecttion
Apr 20, 2010 | McCulloch FHH18A Electric Pressure Washer
Where can I purchase oil rings that go into the spray wand of a McCulloch FHH18A electric power washer.
Sep 10, 2009 | McCulloch FHH18A Electric Pressure Washer
Fhh18a water flows INTO the tanks during operation.
There should be a ball and spring in the valve where you attach the soap suction hose.
Jul 05, 2009 | McCulloch FHH18A Electric Pressure Washer
What are the steps to use Mc Culloch FHH18A powerwasher? What is the liquids I should use?
Hello awseibel:
  1. attach your garden hose to the inlet (at the back I believe)
  2. Attach high pressure hose with gun wand/nozzle
  3. turn on the water
  4. plug into electrical outlet
  5. turn on/off switch on
  6. spray away
  7. Any non-caustic soap can be used
  8. You must set the machine on low pressure to apply soap.
McCulloch M#FHH18A High Pressure Jet Washer,
On hooking up to a water source and plugging it in to an electrical outlet any attempt to test the unit is unsuccessful to include having the on/off switch in either position. With the switch in the on position pump does not operator. The last time I used the unit was July of last year and prior to storing it I did drained the hose.
May 29, 2009 | McCulloch FHH18A Electric Pressure Washer
McCulloch FHH18A Electric Pressure Washer Logo
205 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
