Question about Delphi Roady2 SA10085 XM Radio Receiver with Car Kit
Roady 2 signal goes in and out....
My Roady 2 unit has worked fine for years, but in the past three days or so, the signal is strong for 5 seconds then goes out for two seconds repeatedly. I have not moved the antenae from where it's been all these years. I've checked all connections and they are fine.
  • nnovosel Jun 03, 2009
    I may have fixed this problem myself. I repositioned the antenae and it has been working fine since for the past two days.
    Nicholas
We've been having the same problem with our Roady XT unit at the office. Sometimes I think it's possessed because it goes in and out, changes to the mute mode, and sometimes turns itself off. Just got another Roady XT unit today. It played fine, then went into the mute mode. Called XM and they told me to reset unit to factory default. It's fine at the moment.
Posted on Jun 03, 2009
My Netgear Rangemax WND3300 has been working fine for 1 year, but in the past 2 days the 2.4 GHz wireless signal has been cutting in and out every 30 seconds, making it impossible to use my laptop. I...
Well, There seems to be an issue with the wireless network on 2.4 Ghz band. Please change the wireless channel on 2.4 Ghz to a diffrent value and check if works fine.
Let me know if you need any further help.
Oct 20, 2009 | NetGear RangeMax WPN824 Router
My Delphi Roady XT receiver will not maintain the signal. Does not work even I replaced the antenna. Works for a about 5 minutes before losing the signal
I had the same problem with my xt two years ago. I had two other roadys' at the time and they both worked with that antenna so I called xm customer service explained what was happening and they sent me a new receiver for $10. They told me that those units aren't worth trying to repair. Maybe you'll have the same luck I did. Give em a shout. Good luck.
Aug 19, 2009 | Delphi Roady XT XM Radio Receiver
When I press the power button the screen flashes once & then goes blank again. Some times I see a quick flash of "XM-Radio" This started happening overnight one night-nochanges on our part.
I had exactly the same problem with my Roady XT. The power supply gradually failed, with the symptom that the reception kept getting weaker and more spotty. Finally, the Roady would not turn on. The screen flashed as you describe. I happened to have another 5VDC, 2A power supply in the closet from some other electronic gismo from the past (I save the power supplies just in case). the connector on the old power supply was not correct for the Roady XT, but a little surgery put the new plug on the old supply... (verified by a volt meter). When I plugged it in the Roady quickly turned on and showed full signal strength. This had never happened in 2 years of use. Apparently this radio needs more power than the stock power supply can provide. Now it "loads" stations in 2-3 seconds and never fades.
Jul 12, 2009 | Delphi Roady XT XM Radio Receiver
Polaroid 32 lcd picture keeps going on and off....audio works th
Providing you are using component input SOME LCD tvs need a strong signal or they will blank out like that. i have seen it on samsung and hitachi models. make sure the output signals of the supply device are strong enough.
May 05, 2009 | Televison & Video
Trying to install Roady 2
If the Roady2 has a fm modulator built in, you can go to the menu and set the fm frequency. If it doesn't, you could use a fm transmitter that they have for mp3 players to listen to in the car
Apr 13, 2009 | Delphi Roady2 SA10085 XM Radio Receiver...
Can't get Roady XT to turn on. Previously wouldn't load signal.
there is a bad connection on the voltage input on the radio. look in the hole you will see a copper contact if it wore, you will see a hole in it, you needed to bend it towards the center contact just a little bit. then try it again I worked on mine
Dec 26, 2008 | Delphi Roady XT XM Radio Receiver
Roady xt
i figured it out with help from a delphi service rep.! you need to go into the menu and reset to factory default.this will erase everything you have changed from the factory settings,but once done you can reprogram your settings and they will stay. step 1-enter menu step 2-reset factory default settings step 3-reprogram your preset stations,FM freq. colors etc. step 4-use power button on the roady to turn it off.once the roady shuts down turn it back on with the power button. step 4-now you should be able to turn the key off without erasing your presets.
Apr 25, 2008 | Delphi Roady XT XM Radio Receiver
Delphi Roady XT Radio won't turn on
You need to replace the transformer that plugs into the wall.
Dec 17, 2007 | Delphi Roady XT XM Radio Receiver
Roady gone wild
Called service and they asked if I had a remote close to the unit, I did and they suggested that the battery was low on the remote possibly. I took the batt out of the remote and several hours now with no channel changes or shutting off. the second thing was to make sure that the power adapter was giving steady current.
Dec 05, 2007 | Delphi Roady XT XM Radio Receiver
Roady XT Transmitter problem
Mine is doing the same as well. Been working for 1 year. Now it starts cutting out while listening. I noticed if it is broadcasting the fm frequency menu is there. The minute it cuts out I press Menu and that menu item is gone. It comes back once the radio starts working again. Mine is 1 year old. I got it Christmas of 2006. I do know that if you have it directly connected then this menu item will not appear and that is by design. I think my xm roady xt has gone bad.
Jul 02, 2007 | Delphi Roady XT XM Radio Receiver
Delphi Roady2 SA10085 XM Radio Receiver with Car Kit Logo
310 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
Darrell
xxxxxx xxx
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
