Question about Frigidaire FRS26R4A Side by Side Refrigerator
My frigidaire is not cooling
The freezer and fridge are not coolingat all ther is no sound on the compresor or fan an the digital temperatre reader is not even showing but the light, ice dispencer,water dispencer on the door are working
    Problem Solver:
  • 16 Answers
If able unplug for aout 3 minutes then plug back in (it should reset control unit) this should help
Posted on Jun 02, 2009
My condenser fan is not working on my frigidaire gallery could it be the inverter is not working right?
Sound like your capacitor popped is the condenser running and does it work on both units
Sep 28, 2016 | Frigidaire Refrigerators
Fridge is freezing food fan seems to be running all the time
sounds like you may have a stuck freezer control.try bumping that knob with the back of your fist,if it stops,that is it.if not it still may be the problem.let cool down in freezer for 10 min. open freezer door and turn knob back to off very slow,if it kicks off just at off ,control most likley bad.
Apr 16, 2014 | Frigidaire Refrigerators
I have a frigidaire model Frt18P5Aw1. The freezer is cold but the fridge is not. How do I fix?
there is a fan that blows the cold air from the freezer into the fridge. it's on the inside back of the freezer. it's either blocked in the freezer, in the fridge, or the motor is bad. remove any blockages in ther back of the freezer and feel if there is any air blowing into the fridge. if not, replace the fan motor. it's frigidaire manufacturers number 5303918549.
May 13, 2012 | Frigidaire Refrigerators
The compresor runs but the inside fans do not. the box is getting warm
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 21, 2010 | Frigidaire FRT18S6AW Top Freezer...
Top mount freezer won't cool, fridge works fine.
check for compresor operation. a relay on compresor could be out
Feb 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not freezing, and the panel between the fridge and the freezer gets very hot
The condensor fan motor is probably not running. The condensor fan keeps the compresor cooled, if the compresor gets to hot, it shuts down until it cools off and tuns back on, but will not keep temp. Heat exchange lines go in the panel between the doors to serve as a heater so the doors dont freeze shut, but when the compresor overheats, so do those lines. That would be why that panel gets so hot. Both problems will be resolved with a new condensor fan motor ( located by the compresor).
Oct 16, 2009 | Estate TS25AFXK Side by Side Refrigerator
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
Compressor doesn't run
If the fan located next to the compresor works that means that the compresor relay is bad or the compresor burned out.
Jul 18, 2009 | Frigidaire FRS23R4A Side by Side...
Freezer or fridge stopped cooling. Can not hear compressor kick on
If the compresor is trying to start and it won't you 'll heard a click and the compresor will be very hot ,that means that the relay is bad or the compresor is stuck or burned and needs to be replaced, but first before replacing the compresor try with the relay (no more than $20).But if the lights and fan inside the fridge work and the compresor won't start and is not hot ,the problem is in the cold con trol (you can put a jumper wire between the two wires to the cold control and if the compresor starts thats your problem) after all this if still the compresor won't start could be that the timer is stock in the defrost position.
May 01, 2009 | Refrigerators
Fridge powers on but does not cool
Try pressing light blub switch whist doors are open as fan will only start when doorsclosed. If compreesor is running but not chilling it is either the compreesor has gone and wont be pumping or it has lost its refigerant. Hope this helps
Aug 23, 2007 | Frigidaire FRT18B4A Top Freezer...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
240 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
