Question about GE 25 in. Nautilus GSC3400J Free-standing Dishwasher
Leaving gray white streaks and spots on dishes
Leaving bad white gray streaks and spots on dishes
    Prodigy:
    An expert who has answered 500 questions.
  • 677 Answers
The spots are caused by hard water. there is a product out to fix this problem once and for all. its called the dishwasher filtration system. it filters the water going into your dishwasher leaving them crystal clean with every load. it is guaranteed to work and you will love the results. very affordable! get it at www.dishwasherfilter.com.
Posted on Jun 24, 2009
  • 6,784 Answers
Check the following to address this issue--
1. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
2. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
3. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
4. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
Posted on Jun 02, 2009
My Maytag quiet series 200 is not cleaning and despite many attempts it is also leaving terrible residue on dishes.
I found this on ehow I believe it will help. How to Troubleshoot Dishwasher Residue By Dale Yalanovsky eHow Contributor
5Found This HelpfulGeorge Doyle/Stockbyte/Getty images
Dishwater residue is a fairly common occurrence, and several things can cause it. Even the newest dishwashers may leave residue, and it might have nothing to do with the actual dishwasher function itself. However, there are things you can do to prevent, limit or completely remove dishwasher residue during every washing cycle.
Other People Are Reading
  1. Detergent Residue
    • Modern phosphate-free detergents are the main culprits when it comes to detergent residue. After every wash, many leave a slight whitish residue behind. After several washings, the residue becomes caked on and leaves a noticeable white tint to your dishes. Some dishwasher detergent brands are better than others, and either minimize residue or do not leave any. Once residue is present, however, the only way to remove it is by hand scrubbing or scraping.
    Hard-Water Residue
    • Hard-water residue comes from non-softened water from your hot water tank. Non-softened water leaves a white tint on dishes, but no amount of scrubbing will remove it. Only by wiping a small patch of the dish with vinegar or lemon juice will you be able to ascertain whether the white residue left is hard water or detergent. The slight acidic action of the vinegar or lemon juice removes hard-water stains, but they have no effect on detergent residue.
    Greasy Residue
    • If the dishes feel greasy when they come out of the dishwasher freshly washed, you are dealing with a greasy residue. There are two main reasons for this: either the detergent is not an effective grease remover, or the hot water inside of the dishwasher, either from the hot water tank or the dishwasher's heating elements, is not hot enough. Boosting the hot water temperature on the water tank may solve the problem, and a second wash cycle may be needed for the dishes. A preventive measure of running the dishwasher empty with a full load of detergent also removes the residue inside of the dishwasher.
    Streaking and Spotting Residue
    • If you have spotting or streaking on your dishes, that may be a sign you need a rinse agent. Many modern dishwashers recommend a rinse agent to prevent spotting or streaking, and without one, your dishes will never be crystal clear or streak-free. The next time you do a dishwasher load, add a rinse agent. If the dishes come out spot- and streak-free, the problem is solved.
Read more : http://www.ehow.com/info_12285021_troubleshoot-dishwasher-residue.html
May 19, 2015 | Maytag Dishwashers
Cloudy film left on glasses and white residue on edgings on inside of door as well as white residue streaks on inside of door.
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Jan 23, 2011 | KitchenAid 24 in. KUDI01ILBS Stainless...
Water not draining, and leaving dishes streaked and spotted
check the drainpipe it will be a crinkled 1 inch pipe that connects under sink it should have atleast a 6 inch upward bend that keeps sink water from running back into dishwasher
Sep 15, 2010 | Frigidaire Dishwashers
Hard water area, all dishes streaks and inside machine cloudy white. I think salt is blocked, not topping up as much as I had to in the past
Sep 13, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
White residue left on dishes; Plastic ware being oxidized
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
May 10, 2010 | Bosch 24 in. SHX46A02 / SHX46A06 Built-in...
Our DLX series dishwasher leaves dishes and glasses diffusely cloudy. Not spots and not streaks. A repairman found some blockage in the drain hoses and thinks he cleared the obstruction. We have tried...
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Jan 15, 2010 | Bosch 36 Inch Pyramid Chimney Hood - Black
After approx 1-2mins the screen fades to black and white streaks and spots
LCD is going bad and eventually it won't show any image. LCD is not able to regulate the voltage going into it so to much is going into the LCD and thats why the spots and streaks are showing up.
Nov 28, 2009 | Toshiba Satellite 5105-S501 Notebook
Light streaks and gray streaks and little contrast.
Sounds like there are multiple problems on this machine. Dirty optics can cause light images, white streaks can be caused by dirty cortron wires(becareful when cleaning the wire or all the wires 3 usually, Q-tip can help) , not enough toner in the ink hopper, dirty cleaning blade in the drum modual. A bad heat roll can cause streaks also. Background with light images and black spots can be caused by competitive toner not working very good.
Oct 15, 2009 | Canon PC-920 Black and White Copier
Kitchen Aid dishwasher leaves heavy soap film
its not soap actually the problem is hard water. www.dishwasherfilter.com has a new product out that solves this problem once and for all. it filters the water going into the dishwasher removing the hard minerals that leave those spots. it is very affordable and guaranteed to work or your money back. you will love the way your dishes look.
Mar 27, 2009 | KitchenAid 24 in. KUDS01FLSS Built-In...
GE 25 in. Nautilus GSC3400J Free-standing Dishwasher Logo
537 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
