SOURCE: Siemens Gigaset 8825
Yes. See page 59 of user manual--you must subscribe for distinctive rings through your local phone company.
You can download the manual from the link below:
http://www.barclayent.com/manuals/Gigase...
SOURCE: Siemens Gigaset 2420 Desk Staion LCD Display
That is a common problem with those types of displays, they are sensitive to heat, cold and any movement. They were used by Siemens, and almost all the other manufacturers during this time period. Unfortunately on this particular model, they are not soldered in, they are pressed on by a machine. So if you don't have a Zebra cable press machine ($1000's), and a brand new display, you can only resort to sending it in for repair. Sorry.
SOURCE: need a master PIN
To reset the Gigaset 2420 Pin
At "System Settings" in the Menu press *65# then press the Select button.
"System PIN Reset" will be displayed (if the PIN was not already the default).
The default PIN is 0000.
Goodluck..
SOURCE: siemens gigaset 2420. how do i reset pin on desktop base
Please complete the following steps to reset the system PIN on 2XXX back to 0000. On the system base station:
Please complete the following steps to reset the cordless handset PIN on the 2XXX back to 0000.
SOURCE: need a manual for siemens gigaset as185 or as185
Well you can please follow the below link to get your manul -
http://gigaset.com/medias/sys_master/A31008-M2026-L101-1-7643_en_GBR.pdf
Good Luck!!
