Question about Canon PowerShot A70 Digital Camera
I have a Canan thats giving my problems too
When i turn on my camera my screen is black. It still takes pictures but when i switch it to playback mode they dont appear there either. But i did figure out that when i hold my camera under the light, the screen show up just a little bit letting me do some stuff. Do you know whats wrong. when i review my pictures they are washed out with horizontal lines through them same as above. Exactly!
  • 4,806 Answers
Hi there.
Its possible the pictures are fine if you download them to the PC.
The fact that if you can see a ghost image on the camera indicates that the inverter has gone on the camera and it need to be repaired.
This can cost a lot of money to get sorted out, so if your happy to snap away and then transfer the pics to the PC then your all good, but if you prefer to see what pic your taking then a repair is eminent, other than that its a new camera.
Thanks for using FixYa!!
Posted on Jun 01, 2009
Black screen on canon powershot a1200 can see the symbols and takes black pictures
Did you try to press the display button several times? You then switch between different modes, while shooting and while playback. One of the modes is screen out.
Nov 23, 2014 | Canon Cannon Powershot A1200 12.1mp 4x...
Canon 60D playback images turning up black
Did you switch to Tv (shutter mode) and took pictures for several seconds? like in the dark? Because saving the picture can take as long as the shutter time was.
Before panic. (Actually you never should panic) check your camera in automatic mode. And make sure you did not select any power save action, that puts your display on dark while shooting.
But always be sure your battery is charged and check its capacity. In the menu yo can check under the wrench symbol, when you select Battery info. Page 268 of the manual.
Working with a bad battery can damage the camera in the end.
Dec 27, 2013 | Canon EOS 60D Digital Camera
Screen went black
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Feb 27, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
When turn on camera on screen is black
I think your Canon A70 camera does not show live view in camera mode to take pictures but show you previously stored picture properly in playback mode.
If that is true then Canon A70 camera got problem of bad ccd imager that will be replaced to get live vew in camera mode.
Canon will replace ccd imager for free, click Canon CCD Imager Advisory for details.
Thanks.
Sep 23, 2009 | Canon PowerShot A70 Digital Camera
Panasonic Lumix DMC FX12
HI,
It's impossible to turn the camera off. Only way is take out the battery.
No button warks, but I can change the shooting mode and turn playback, but I can't change the image in playback mode.
Please, help me to solve this problem.
I think, the camera needs to be restarted, but how to do that?
Thanks a lot.
Jun 17, 2009 | Panasonic Lumix DMC-FX12 Digital Camera
I OWN A CANON POWERSHOT SD1000. THE DISPLAY SCREEN IS BLACK WHEN I TRY TO TAKE A PICTURE. HOWEVER PLAYBACK IS CLEARLY VISIBLE. IT IS ONLY WHEN I ENDEAVOUR TO TAKE A NEW PICTURE THAT THE SCREEN IS TOTALLY...
If you take a picture using the optical viewfinder, does the camera actually record the picture? If so, you may have the LCD turned off in the camera mode (there are three options: standard, detailed, and off). With the camera in the shooting mode, press the "DISP" button and see if the LCD turns on.
Aug 27, 2008 | Canon Cameras
Turn on camera but the lcd sceen is black
Have you checked the display mode you're in? If you have the display set to off (to save power) and also the picture review time set to off, then you'll just see a black screen. Try pressing the 'Disp.' button below the screen when the camera is on - it should cycle through different settings with each press: Off, On, On with picture info. Similarly, in the playback mode this will show you more or less info about the picture you are viewing.
Even if the display is switched off, if you have your 'review' option in the menu set to anything other than Off (i.e. 2 seconds), then you should see the picture you've taken appear on the screen straight after taking it.
If it's not that, then I don't know the answer....
Oct 17, 2007 | Canon PowerShot S500 IXUS 500 Digital...
Camera freezes in any picture taking mode
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. you need professional service to fix it.
Dec 28, 2006 | Gateway DC-T50 Digital Camera
Can't take pictures or videos
The lens block appears to be defective. If you need this pl.let us know further.
Aug 07, 2006 | Sony Cyber-Shot DSC-S40 Digital Camera
When i turn the camera to take a photo, no image appears in the LCD or the eyepiece. this just happened all the sudden. I am able to view pictures that I've already taken in the LCD and the LCD will also...
there may be two reasons for this problem. 1. may be a defective or broken CCD. 2. the shutter is not working may be due to broken flex circuit cable. in any of the case you have to get it fixed from a professional camera repairer
Aug 02, 2006 | Fuji FinePix S5000 Digital Camera
Canon PowerShot A70 Digital Camera Logo
77 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
