Question about Ricoh Aficio 2018D All-In-One Laser Printer
Ricoh 2018D fuse unit
Where could i get Ricoh 2018D Fuser Unit in Sydney? How much is it?
I can't find it on website.
  • infodemo Jun 18, 2009
    Thanks Matt, Just received comparable one, cost me $750. OMG.
  • 29 Answers
You will have to get onto a Ricoh Service Centre, and they will be able to order the parts for you =]
Posted on Aug 21, 2009
  • Ricoh Expert
  • 393 Answers
The part # is B2594003 for 120 volt
B2594006 for 240 volt as for cost??? 400 plus is my guess.
-Carl, please let me know if this helps.
Posted on Jun 25, 2009
  • 31 Answers
You probably won't find one new, the model is to old, used is your best bet.
Posted on Jun 18, 2009
  • Matt_Sr
    Matt_Sr Jun 19, 2009
    The 2018 was discontinued Jun of 01 with parts availability ending May of 08. I never liked the fusers on those, they were hard to take apart and had problems with the one-way on the UFR drive. That amound of money would've purchased a much newer MFP.
4 Suggested Answers
JackHeath
  • 1049 Answers
SOURCE: Ricoh service mode to reset
This is the solution from Ricoh website:
Please press Menu. Then scroll to Maintenance and press Enter. Scroll to Color Regist and press Enter. Scroll to Color Regist Auto Adjust and then press Enter to Auto adjust. If after completing the procedure the error persists, please contact your service representative for support.
I'm told this works as well...
On the main board put dip switch 101-1 on and then off and then enter 97 and press the aps key. Then power cycle the printer.
Posted on Jul 24, 2008
  • 9 Answers
SOURCE: Ricoh Aficio 2238c: Fuser Oil Unit
you really can not refill the bottle but I would recommend two things. One find a fuser oil unit on ebay and order it quickly. Next hit the yellow clear modes button, then hit the numbers 1 0 7 , then hold the red clear stop button till the display panel changes. hit copy sp, select 7 data log. now use the page down arrows located in the middle of the disply till you see 7804 push it then go to #10 oil supply and hit execute. this will reset the oil counter and allow you to use the machine till you get the new unit.
Posted on Dec 16, 2008
  • 86 Answers
SOURCE: function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Good luck and please rate me, thanks.
Posted on Mar 02, 2009
Ricoh mpc3500 fuser unit setting error
Most common problem is the electrical connector on the fusing unit or the connector that the fusing unit connects to inside the machine is broken. So when you push the Fusing Unit in to the machine the connector moves out of position and doesn't connect properly.
Aug 01, 2016 | Ricoh MPC3500
Just after fuser unit, gears
what photo check your post it isn't there
Apr 09, 2015 | Ricoh Aficio 2018D All-In-One Laser...
Err 553 Ricoh aficio 2018D
SC 553 is a fuser error code, could be thermistor or thermal fuse or fuser lamp
Sep 27, 2013 | Ricoh Digital Copier Toner for Aficio...
Ricoh Aficio 2018D
This could be a very bad code its "main motor lock", either you have too much load on the drive unit ( paper stuck, locked up pcu or fuser ) and maybe bad BICU board.
Jun 26, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
It is what it is. No, you can't refill it
Apr 06, 2009 | Ricoh Office Equipment & Supplies
Function sc:552 problem RICOH AFICIO 2018d
Mar 02, 2009 | Ricoh Aficio AP3800C Laser Printer
Code error
Push Buttons in this order:
Yellow/clear key
7
and Hold Red/Stop key, for 5 secconds.
If this works, turn machine off/on, the code should be reset. Alltho the code may come back, when the Copier attempts to print a page. If this is the case, you need your Fusing unit Repaired.
Oct 26, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Error code 541
hi!!!!
may be the drum is damaged
try to clean it use dry tissue
or
repkaced the drum!!!
Sep 16, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Ricoh Aficio 2018D All-In-One Laser Printer Logo
146 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
