Question about GE Profile 19.0 cu. ft. Top Freezer No-Frost Refrigerator TBX19PABWW
I need to know how to change the door opening. What do I do with the wires in the hinge?
I need to know how to change the way the door opens on the ge profile tbx 22 pr. There are wires in the door hinge that operate the in-door ice maker.
  • GE Master
  • 1,606 Answers
Since the wires come up thru thr hinge , you cannot reverse the doors .
Posted on Sep 23, 2009
Westinghouse wse6070sb*5 front display reseting when door opens or closes
Youmost likely have a bad connection of the wires at the top of the door where there hinge cover is you need to remove the hinge cover and check that plug that connects the wiring to the door or you have a broken wire
Appliance 911 Sea Breeze
Jun 27, 2012 | Refrigerators
Door open warning
Yes, the doorjam switch is either shorted or broken. This switch is on the cabin door opening by the hinges. In rare cases the pin may be self adjusting. Sometimes you can press in the pin by hand to see if it shuts off the interior light. Do not slam the door with your finger in the hinge area.
There may be a problem with the door adjustment or the hinge may be broken and you do not know it. It can be a lose or broken wire inside the cabin shell.
Feb 12, 2012 | 2004 Mercedes-Benz C-Class
I own a Kenmore HE 5T washer. I washing clothes, as normal. Out of no where, when I went to open the door it was like it was sticking or wanting to hang up. I can open it, but it is not smooth as it was, I...
If the door swings smooth after it is opened it is not the hinge. In most cases it will be on of the 2 parts of the door latch. Look at the door first. There should be a plastic pointed arrow looking part sticking out. See if any of it broke off or got chipped. That is an easy part to change. If not that, it will probably the door latch switch which is the part the pointed part goes into. You will probably need a tech to change it. The hard part is getting to it which in some cases involves unhooking the door boot wire retainer on the outside edge of the cabinet.
Sep 05, 2011 | Kenmore Elite HE5t Washer
My front passenger widow won't go up unless I open the doors and hold the buttons on both front doors. The driver side will not go down at all. I saw some of the other responses to similar problems but...
if working with the door opened a wire between the door and the hing pillar has a short in it
you will need to open the rubber conduit up to inspect fot the broken or frayed wire(s)
Mar 31, 2011 | 2004 Mitsubishi Endeavor
Is it possible to reverse door swing on dryer? My daughter has a new Elite front load dryer that swings from left.
REVERSING DOOR SWING
Your dryer is designed so the door swing may be reversed at any time without additional parts. Conversion is accomplished by transferring hinges to the opposite side of the cabinet.
To change the direction of the door opening:
1. Open the dryer door. Remove the four hinge hole plugs from the left side of the door opening. Place nearby for future installation. NOTE: You may need a plastic knife to help pull out the plugs. Be careful not to scratch the paint.
2. Remove the four screws that secure the door hinges to the dryer front panel (see below). NOTE: Remove one screw from each of the two hinges first. Hold the door firmly before removing the last two screws.
3. Rotate the door 180° and reinstall the door hinges to the dryer front panel with the four screws.
4. Install the four hinge hole plugs in the open screw holes on the right side of the door opening.
Hope this helped Tim
Dec 01, 2010 | Kenmore Elite HE4 Electric Dryer
Written instructions for changing door on fridge freezer KGV36V10GB. Diagram is confusing!
Open door, unscrew hinge, Pull door top door off first, then remove middle hinge, then second door, then third hinge. ( good to take pic before so you know what direction the hinges are facing.
When putting on, put bottom hinge on first, then door (tape it close and in place) then second hinge, the top door (tape in place, THen finally the top hinge. Once hinges are in place, remove tape.
Jan 18, 2010 | Audiovox Bosch 718 World Cellular Phone
Thermador oven (c301u) door hinges weak, how to install new hinge
This is a relatively easy fix however you will need to remove the door and it is heavy!
Start by opening the door completely and engage the small "locks" that are at the base of the hinge. This will ensure that the spring loaded hinges do not "spring open" when you remove the door. You then will need to remove the hinges from the door via a series of phillips head screws that hold the hinge assembly in place. The new hinges must be "preloaded" into the Open position using a vise or some means of holding the hinge in place while you use a small section of pipe to provide leverage needed to open the hinge so that the Locks can be engaged.
Once the new hinges are "pre-loaded" and the locks are engaged, you can reverse the procedure to re-install the hinges into the door and re-install the door.
Good luck!!
The hinges are commercially avaialble from Applianceparts.com
Jan 18, 2009 | Thermador C301U Electric Single Oven
Seat belt does not move when i opn the door
If only one seat belt does not move when you open door then check the pink wire in the rubber boot passing from the door panel to the cabin around the door hinge, however if it is both seat belts that don't move when their respective doors are opened, the problem is in a little box located right under the hand brake lever, behind the shift lever, of course you have to remove some of the decor to get to it.
Oct 30, 2008 | 1991 Toyota Camry
I have a Whirlpool Oven #SF395LEE* (RB26126336) accubake Systems. Today the oven door came off and I need to know how to put it back on. I do not see this over on your list. Can you help? Thank...
ok wht you have to do is grab the hinge with pliers or your hand and fold the hinge to the open position,carefull this hinge has some pressure to it and you dont want to pinch your skin ,once the hinge is open,you want to take a screw or strong nail and stick it thru the hole that is between the top of the hinge and bottom in the center put the nail thru the hole and let the hinge close slow i,it will hold the hinge 3/4 open,now hook the door on it will be 3/4 open once you feel it latch on the door open the door all the way pull the nails out and close the door ,it takes a little practice but youll get it remember to use the nail to hold the hinge open,youll see the hole on the hinge
Jul 13, 2008 | Whirlpool RBS245PDS Electric Single Oven
Can I change the way the door opens?
no you are stuck with the fact how they were buld.unless you want to mover the doorlock and all wiring and the hinge.
also have to make a hole for the doorlock.
I would not advice this.
May 02, 2008 | Kenmore Elite 45986 Front Load Washer
Refrigerators Logo
174 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
