Question about RCA P61940 61" Rear Projection Television
RCA 61" SOUND NO PICTURE HDTV
WE CAME HOME ONE DAY AND TURNED TV ON GREEN LIGHT CAME ON BUT NO PICTURE WE RECONECTED THE CABLE NOTHING WE UNPLUGED AND PLUGED NOTHING THEN PUT A DVD ON WE HEARD SOUND BUT STILL BLACK PICTURE.
  • nageltjane Jun 02, 2009
    were trying to do this with out contacting a tech we live in the country and its expensive for them to come out
  • 378 Answers
Contact a Technician to check your HV section of your TV, sometimes the heater on CRT have no supply.
Posted on Jun 01, 2009
My RCA HDTV D52W23 Will not Turn On!!
Trying installing a new power supply. This is the main problem with tv's with the issue. But if you just bought it I would try to get my money back from where I bought it from. Installing a power supply for a tv is not that hard at all.
Sep 03, 2009 | RCA D52W23 52" HDTV CRT TV
No picture but sound
most likely the color wheel needs replacing.
Aug 08, 2009 | RCA HD61LPW42 61" Rear Projection HDTV
61" RCA DLP won't turn on after power blip
Hi, thank you for visit fix ya.
Do you havve problems with power supply capacitors.
Replace this:
2200uf 25V, 220uf 25V ( bowed or vented). Located beside power transformer.
Thank you
Jul 26, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My 61 inch RCA Scenium, currently has sound but no picture appear
My exact same problem turned out to be the cable box not the TV. Try unplugging cable box for 5 minutes then power up! Solved my problem!
Apr 01, 2009 | RCA Scenium HDLP61W151 61 in. HD-Ready...
My RCA is screeching
To install the color wheel, turn off and unplug the tv, take off the lower back casing (17 star type screws), remove the lamp door, remove the lower back casing. Look just left of the lamp you will see 3 smaller star type screws near a small circuit board (which is on the color wheel), remove those screws unplug cable from color wheel, unplug other end of 2nd cable from tv circuit board (just to the upper left nearest to the color wheel.
All you have to do is install the color wheel, plug in both cables, put the back on and place the lamp door back in its position, the lamp door pushes in a lillte blue lever which allows the lamp bulb to light up.
I'm in the process of doing the same myself on my RCA same model. Where did you buy the color wheel from?
rw9704
Jan 06, 2009 | RCA HD50LPW42 50" Rear Projection HDTV
You have a bad colorwheel in the light engine. Due to the complexity of the repair, I suggest you call a tech to check this out
Dec 18, 2008 | RCA HD61LPW42 61" Rear Projection HDTV
The picture on my RCA Scenium HDLP61W151 61 in - was completed black
unplug both the TV and the cable box for 2 minutes then replug them in. this will reset the micros in both units. if there is still no sound check your SAP setting make sure its off.
Feb 06, 2008 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Will not come on.
if you have p scan you need red green blue cables to the tv and both need to be set up to do p scan, it sounds like you have p scan but its not cabled correctly.
Jan 14, 2008 | RCA RTD255 System
50 inch 1999 TheatreView Television
#1 When I turn on the TV the power button comes on then blinks 6 times then goes off for a few seconds then repeats the cycle. I have sound over my surround system during this time but no picture.
#2 My sound would crackle and pop every once and a while until now it does nothing. I have to watch it with the surround sound on.
Nov 26, 2007 | RCA HD52W59 HDTV Projection Television
RCA P61940 61" Rear Projection Television Logo
144 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
