Question about Acer Aspire One PC Notebook
My mousepad won't work on my Aspire laptop. Ok, the mouse pad works (the pointer will move around), the physical button right click works (not double clicking), but any click on the mousepad and the left click doesn't work. I checked the pressure graph, and the mousepad is registering pressure when I press down on the mousepad. Drvier is updated, and I even rolled back to the last one just in case. Went through all the properties and reset to defaults. No good :( ...
  • hoppin122 Jun 02, 2009
    Wow...sadly, that actually worked.
    Thank you for saving me!
    Guru:
  • 597 Answers
Check for dirt under the keys. See if you can blow under key and turn the laptop on it's side while you're doing it so anything under it can fall away.
Posted on Jun 01, 2009
Mousepad doesn't work
what does it say in device manager click on mousepad ,click on properties does it s device working ok . in control panel go to input devices /mouse and check if mouse pad is selected to use.
Jul 29, 2014 | Dell l Latitude 620 9300 9400 1...
Laptop screen frozen;arrow wont move;cant type in user name.ACER Aspire
The appeal to any laptop is the ease of portability of the machine, and an Acer laptop is no different. With an integrated mouse pad, these computers can be quite the boon to those looking to have their technology on the go, but a number of issues can afflict Acer laptops, including unresponsive mouse pads. Fortunately, a few clicks of the keyboard and some driver downloads can alleviate most Acer mouse pad problems.
Take a close look at the Acer laptop mouse buttons. Make sure the exterior of the buttons are clean and that there is no grime around the edges and crevasses of the Acer buttons. Dirt on top of the mouse pad can result in slower performance or an unresponsive experience, while grime around the sides of the mouse buttons can cause problems with the pressing and depressing of the mouse. Is there any way your mouse pad has been turned off? Check into this possibility. On an Acer laptop, hitting the "Function" (Fn) key and "F7" on the key board will result in the mouse pad being switched off. Hence, you may have hit this function and your mouse pad may not actually be broken or require any repair. Hitting the "Fn" button and the "F8" key on the Acer keyboard will result in the mouse pad being turned back on again. Click on the "Printers and Other Hardware" option on your PC. This is an alternative method to the above. At this point, examine the menu that comes up and click on the button at the top that reads "Device Settings." You should then see an option to click on your Acer mousepad. Highlight this option and click "OK." Launch your Web browser and go to the official Acer website. http://www.acerpanam.com/ The above steps may not have worked, so downloading new drivers for your mouse may be necessary. Select your country of origin, then click on "Support." You will be asked to click on your country again. After you do so, click on the link that says "Drivers and Downloads" on the left sidebar. Select your product line ("Notebooks") as well as your specific Acer computer model, and then hit "Search." Click on the link that says "Touchpad drivers." Your Acer computer may only require new drivers for your mousepad. Download the .exe file and run it to install the contents to your Acer computer. Restart your Acer computer after fully completing the download and installation process. Once the restart process has completed, the driver installation will be complete and your mouse should work again.
b>
Feb 06, 2013 | Acer Aspire Computers & Internet
Hp 630 touchpad not working -pointer moves but doesn't click
Double click on pad surface. Buttons could be faulty. Check mousepad settings. Install drivers
Dec 08, 2012 | HP Pavilion ZD8110US Notebook
Tapping on gateway nv 53 trackpad not working
This just happened on my HP2730P. I always used the click on the touchpad, plus used the right click button at the bottom. Yesterday it just decided to stop working and went haywier...it started doing the selecting and dragging while I was moving the mouse around and my left click stopped working. Obviously my enable tap click was already on cuz I used it all the time.
My solution was disabling the buttons under the "buttons" tab. Then my mousepad tap started working again, I regained function in the scrollbar on the mousepad again, and if I need to right click I can use the point stick buttons right above the pad.
OR
Does it start working when you reboot? If so, try changing the "Touchpad Sensitivity" option :)
Jan 24, 2012 | Computers & Internet
Logitech mouse stopped working when using my right hand on the mousepad. Will work with my left hand on mousepad or anywhere else. Also will work with right hand if I move the mouse pad to another area. ...
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Jan 17, 2011 | Computers & Internet
Pronblem
there must've been some prob with the mousepad/ external mouse driver.go to control menu->double click mouse->choose hardware tab->properties->driver->update driver... do this with ya motherboard/laptop cd/dvd in the cd/dvd rom. choose search software driver automatically. once ya done. restart and start using mouse as before.
Jan 11, 2010 | Acer Aspire One PC Notebook
Gateway laptop running Vista suddenly developed an issue with the mouse pad.... double click doesn't respond. However the touch pad works to move the mouse
I have just had this problem with an Acer laptop running on Vista Home. When I double clicked on the actual pad itself rather than the bottons, it wasn't recognising it at all. Wouldn't scroll down or select a folder etc, just if I double clicked on the actual pad. Everything else worked OK.
I tried the solutions above but they didn't work.
Turns out it's the 'Tapping' function that needs to be enabled. Go to Start > Contol Panel > Hardware > Mouse > Device Settings > Then it says devices: and lists what pad hardware you have (mine is Synaptics Touchpad V7.2.
Under the box are 3 buttons Enable, Disable and Settings, presuming yours is enabled go to Settings > Tapping > Enable Tapping. Hey Presto! :-)
Aug 21, 2009 | Computers & Internet
Mousepad not working
Hi Sharad arya,
Try pressing Fn+F8 to activate/deactivate touch Pad.
takecare.
May 12, 2008 | Lenovo 3000 Y410 Laptop
My acer aspire 5100 mouse buttons
You have to go through the Control Panel, double click the mouse icon and find the settings for what is actually called a Glide Pad and change any values from there.
May 11, 2008 | Acer Aspire 5100 Notebook
Mouse pad is not working but usb mouse is!
Try pressing the FN+F7 buttons together.. This enables / disables the touchpad
Jan 17, 2008 | Acer Aspire 3000 Notebook
Acer Aspire One  PC Notebook Logo
542 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
