Question about Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television
Panasonic 53" tv pt-53wx42
I have a panasonic 53" hd projection tv it hads blue lines on screen
  • 643 Answers
Your convergence ic is going bad. remove front and adjust the level of blue.
Posted on Jun 01, 2009
Picture out of line Problem with the Panasonic PT-53WX42 53 in. Rear projection. Possible convergence circuit? How do i change it
Picture colors lines R,G,B mis alingments,have colors shadows pictures or 3D pictures look alike?Yes.The tv convergence board is dead,the board require changes 2 STK convergence ICS and some or all of it resistors too.To fix the tv convergence board.U must have tools like a soldering iron,a desoldering pump or a roll of desoldering braids and also can do soldering work?Yes,tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit belong to ur tv model and make to repair it ur self.Or the shop will cost u like $300-350 for parts and labors.
Mar 23, 2011 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic 53" tv
Blue background lines with colors otherwise OK may be a loose or dirty blur drive potentiometer on small circuit board behind front grille and beneath front imerboard cover. These are hot-glued in place from factory but may be the cause f the problem. They're VERY sensitive.
If you have bowed blue lines instead of properly aligned colors, you probably have a blown convergence amplifier IC. These boards are no longer available so yours will have to be repaired. Some shops repair them but many send them out for 6-10 weeks. Fairly expensive too considering the amplifier chips are about $35 each (x2).
Jun 01, 2009 | Panasonic PT-47WX53 47" Rear Projection...
PT-53WX42
Need to replace the convergence amps and any 2.2 ohm resistors in the return. That unit takes two STK392-110 Sanyo amps - but for greater reliability use STK392-150's and get them, from some place like ACME to be insured their not chineese knock-offs..
Bill
Apr 09, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT -47WXC43G 42 inch TV
replace the convergence amp ICs both of them. They cost about 15.00 each
Mar 09, 2008 | Panasonic PT-53WX42 53" Rear Projection...
My darks are to dark on TV
what happens if you adjust the contrast or brightness?
Feb 21, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic tv
This model does not use a OEM Protective Screen. However, i found the Lenticular (outer screen) and Fresnal (inner screen) Screens for purchase.
Feb 19, 2008 | Panasonic PT-53WX42 53" Rear Projection...
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic 53wx42, no power, Blinking LED
Have you gotten any solutions to this problem? We had the same thing happen to our TV recently. Haha, maybe they all died on the same day. Before this, we had a convergence problem with the blue color. If you had it fixed, how much did it cost? Our warranty just expired too! Thanks
Aug 03, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-53WX53 53" Rear Projection HDTV-Ready Television Logo
193 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
