Question about SanDisk Sansa e250 MP3 Player
When i turn on my sansa its said sandisk , then raspody sansa then it shut down by itsself , the turn on by its self and its repeats over and over again.
My sansa wont start when i turn on my sansa it says sandisk, then after a few seconds it turns off. after a few more seconds it turns back on and repeats
  • 93 Answers
Try reformating your sansa using sansa updater.
Posted on Aug 16, 2009
My sansa willo not charge. It keeps shutting down
try checking every five minutes and turn it on.
Sep 29, 2009 | SanDisk Sansa e250 MP3 Player
My sansa wont turn on
STEP 1 – Reset the device
  1. Slide the Power switch up and hold it for approximately 20 seconds.
  2. Release the Power switch once the device is powered down.
  3. Turn the device back on.
STEP 2 – Download and Install the Sansa Firmware Updater.
http://mp3support.sandisk.com/sansa/Application/SansaUpdaterInstall.exe
this is their instructions not mine, but i hope this helps you.
Aug 20, 2009 | SanDisk Sansa e250 MP3 Player
Reset All
NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
TO PERFORM THIS OPERATION!
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
will be gone.....IF that doesn't work try to recover...download the update software and install then lock your sansa hold in the rec key on the left at the same time push the menu/power button this will take you to recovery mode then connect to the computer Star the update software if it doesn't start automatic goto /start /all programs /Sandisk/sansa updater/ sansa updater and start it up manually... follow instructions on the updater and the sansa hope this works.... Please rate
Jun 01, 2009 | SanDisk Sansa e250 MP3 Player
Screen turns white at start up
Probably a hardware-related issue that will require replacement, but try these methods - especially updating the firmware:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Mar 16, 2009 | SanDisk Sansa e200 MP3 Player
Problem with my battery
how to convert my photos to sansa e 260
Jan 14, 2009 | SanDisk Sansa e260 MP3 Player
My Sandisk Sansa c250 wont charge or turn on
Opening the player up was a bad idea. You probably could have run the Sansa Recovery Tool from Sandisk's website, but now you might have moved the hardware around - there is YouTube video that shows the inside of the Sansa player (several actually) that might give you some hints. But try the soft fixes first:
-Tha Mp3 Doctor
Dec 16, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa 8.0 gb
refer to the anythingbutipod.com forums for help correcting this problem. they have a specific sansa e200 forum.
Aug 02, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 mp3 player
-Tha Mp3 Doctor
Nov 18, 2007 | SanDisk Sansa e250 MP3 Player
Turns on and off over and over byself, computer will not detect player
-Tha Mp3 Doctor
Apr 05, 2007 | SanDisk Sansa m230 MP3 Player
My mp3 sandisk meida player frooze up and nothing i do works
just hold down the power botten for 15 secends and it sould turn on by its self
Jan 09, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
