Question about Mitsubishi WS48511 48" Rear Projection Television
Mitsubishi ws48511 ghosting problem
I have blue ghosting that comes and goes, any channel and with extrnal inputs like DVD player. Sometime it last 10 minutes, sometimes a day or two and then clears up. What would you recommend?
Pete
  • 126 Answers
You need to have the convergence output IC's replaced. These are large amplifiers which control where the red, green and blue beams land on the picture. When they fail you will get colored ghosts. This is a very common problem for any projection television. Any reputable tv repair shop can do the repair in your home and the average cost of the repair is between $225 and $325.
Posted on Jun 02, 2009
I have a Mitsubishi WD-62525 TV with a Blue Ray DVD player hooked up to it. When I play a standard DVD, the picture is fine but if I play a Blue Ray DVD the picture is scrambled. I hooked the same DVD...
Might be tuned to the wrong output. The big tv has more than one input and is select able. Is there a blue ray selection for TV or input for that device.
Aug 09, 2014 | Mitsubishi WD Televison & Video
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi wd 52628 input issue, blue screen and input error
there are no analog channels, they are all digital now, be sure your antenna is facing proper direction before scanning for digital channels
Apr 20, 2013 | Mitsubishi WD-52628 52" Projection HDTV
Red ghost in my ws48517
U can solders wright?Buy a convergence kit at Tv Repair World.com.To repair it ur self.Try U Tube.com for some sample for replacing some DLP tv IC convergence problems.
Feb 15, 2010 | Mitsubishi WS48511 48" Rear Projection...
My mitsubishi and the dvd player!! need help asap!!!
dvd players use component or hdmi cables for hookup
select the proper input on the mitts
Jun 13, 2009 | Mitsubishi WS-65513 65" Rear Projection...
Color convergence problem
If you follow the instructions on the other thread, you should be able to resolve the problem. Try the simple stuff first. Resolder the pins of the convergence ICs and see if that alone resolves the problem. Sometimes that is all it takes.
Keep us posted.
Dan
Jan 30, 2009 | Mitsubishi WS48511 48" Rear Projection...
Blue color cannot be adjusted
there are two ics trhat control the three colors alignments. Its always recomended to replace both Convergence ICs at the same time when doing the repair as they both share the green color between the two ICs.
Sep 03, 2008 | Mitsubishi WS48511 48" Rear Projection...
Video channel
if your DVD player supports a HDMI cable a single cable is enough for both audio and video channel.
but both your player and TV must support HDMI.
Aug 12, 2008 | Samsung DVD-V4600 DVD Player/VCR
Mitsubishi ws48511 convergence problem
Your model uses one convergence IC its a STK392-110 you need to replace that IC. You can get a replacement at the following link with free instalation instructions with pictures so you can do the repaair yourself. Here's the link.
http://servicemanuals.vstore.ca/
Jun 26, 2008 | Mitsubishi WS48511 48" Rear Projection...
Changing the inputs
It might depend on the type of input. VCR often use A/V or component cables. if you are using AV (red, white, yellow) make sure they are plugged into the right input. if plugging in to a component (white, red, green, blue, red) make sure the yellow plug goes into the green input. If plugging in component make sure your red wires are not backwards. There should be a white and red together (these are the audio) and a green blue red together (these are video)
Sep 08, 2017 | Mitsubishi CS-35505 35" TV
Mitsubishi WS48511 48" Rear Projection Television Logo
137 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
