Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
Stopped working after power failure. Would not come on (at all) after power came on. Was in spin cycle at time of power failure.
  • 30 Answers
Check the plug in for power at the fuse box. May have shorted out motor or timer. Should check with a appliance repairman for electrical problems and for your safety. Start with the fuse box first. Hope this might be of some help
Posted on Jun 02, 2009
My Kenmore HE2t washer is stopping about 8 minutes into the cycle (any wash cycle)..completely turns off. I can run rinse and spin then and it completes the cycle. No error codes when it turns off. W
htc sensor isnt working i would recon
perhaps the element isnt getting power
did it trip your circuit breaker
some times the htc fails
all you get is machine stop because the heater is not detected
if it spins rinses and empties in a timely manner
then all thats left is the heater system
Jan 09, 2015 | Kenmore HE2t 3.7 cu. ft. Front Load Washer
Spin cycle does not work
Possible that there is power to the motor when the program comes to the spin mode. You need to confirm this with a voltage check when the cycle moves to SPIN. If so the fault lies with the program controller unit. There can be failure in this output.
Jan 08, 2013 | Washing Machines
Kenmore he4t washer codes
The control for the washer likely detected a problem. The failure code will not be displayed on all models of washers. You can recall the error code by using this procedure:
  1. Select the "Drain/Spin" cycle.
  2. Select No Spin.
  3. Press the "Prewash" options and hold this button for 5 seconds.
  • Immediately after those 5 seconds the last stored failure code is displayed for 4 seconds.
  • After those 4 seconds the display switches automatically back to the selection mode
NOTE: If your washer does not have the Pre-Wash option. Then use the 2nd Rinse button (called Extra Rinse). The failure code should stay in the memory so that it can be recalled as often as necessary and as long as it is the youngest failure Code.
Nov 30, 2012 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
My Roper top load washer stops in mid cycle and will not drain or do anything else
Most of the time that is lid switch failure. The lid switch must be engaged before the tub can spin. You can bypass the lidswitch to see if that is the problem. The lidswitch has 3 wires. 2 live wires and one ground wire which is green and bolted to the frame. Tie the 2 live wires together and see if the washer will work. You can use it that way but is could cause harm if anyone was to try and grab clothes out the tub while it is spinning full blast.
Sep 23, 2012 | Roper RAS6233KQ Top Load Washer
Stops on spin cycle and gives a f11 error code
F11 is a serial communication error. Communication between the main board and the motor control board is not being sent correctly. This could be a bad main board, motor control board or motor itself. The testing can get pretty involved. Try putting the machine in a self test mode and see if the error clears. Press Cancel, then by pressing the drain spin button once on the left side then move to the spin speed button the the right. Press this button until no-spin lights. Press the prewash button 4 times. C00 should appear in the display. Let it run it's tests, there will be 8 of them and end up on C08. If this doesn't work, it's best you wait for the service tech.
Mar 29, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
Final spin failure
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Jan 07, 2008 | Washing Machines
Washing Machines Logo
227 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
