Question about Homelite Consumer Products 4.0 Amp, 13 In. Trimmer
Need to change string holder, its empty. can't get old one off.
Need new string on homelite electric trimmer. Can't get old one off. Mod. UT41110 13inch.
SOURCE: Replacing the bump head on homelite string trimmer
undo the 2 screws on top of the carb. The bulb is part of a 2 piece cap undo that and it fall out.
Posted on May 16, 2009
  • 27 Answers
SOURCE: how to replace string in a homelite trimmer
have the same weedeater, see utube vids too hard to explain with words
Posted on Jun 10, 2009
  • 6 Answers
SOURCE: st185 Homelite string trimmer starts then dies
I resolved my problem by taking apart the carborator and cleaning it. There were clogged passaged that had stuff come out of them when I used airisol carb cleaner to blow them out. I only had to make one gasket the carb mount gasket which is pretty basic only 5 holes.
It ran for the next 3 hours, ran fantastic!!!!!!
Posted on Jun 14, 2009
#1 Taper
  • 1041 Answers
SOURCE: homelite st-175g trimmer
This is for a duel line trimmer. I hope this will help.
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Posted on Jun 19, 2009
#1 Taper
  • 1041 Answers
SOURCE: Installing new line on my string grass trimmer
Jim
Posted on Jul 03, 2009
How do i remove string holder to refill on a homelite electric 13 inch trimmer
You push in the tabs on the side of the spool retainer. Then, you pull the spool retainer up to remove. Then, you can remove the spool. See page 13 of your owners manual here with more instructions and diagrams also.
http://www.homelite.com/system/manuals/stringtrimmers/UT41110_221_eng.pdf
Jul 04, 2011 | Garden
How to remove the string holder on a homelite mighty 26cc
Here is a manual similar to your owners manual. See pages (13 and 14 ) inside for instructions on this procedure.
http://dl.owneriq.net/7/7d91348b-6b05-4cce-ad47-08aad2e1f2dd.pdf
Jul 02, 2011 | Homelite Mighty Lite Lawn Trimmer
I need a new trimmer head for myhomelite trimmer model HTL800A
I see that this is an older model electric trimmer. The correct model number is HLT800A. Parts for electric models are difficult to find (online). Most service centers refuse to work on them and they say it is not cost effective. They basically just issue warranty replacements. Even Searsparts direct that has parts for most makes and models only lists gas models for Homelite.So, if you can get the old head off (or even if not); take it to the Home Depot garden center and there you will find a vast array of different string heads that may or may not fit this model. I know that most of them are for the gas machines. You may even find a new electric model on sale there that suits your fancy. I have been unable to find any spare parts listed for this model.
Nov 06, 2010 | Homelite Curved Shaft Trimmer Bump Feed...
Homelite trimmer, gas, string - y is the string wrapping itself around the head of the trimmer?
The line on my new 26cc Homelite would also feed out by itself. That started me thinking the line was wound backwards. I wrapped the line in the opposite direction as was shown on the bump feed reel and now the dang thing works although the bump feed needs to be "bumped" pretty hard to work. Is it possible that the reel was manufactured with the (string direction) arrows pointing the wrong direction? The new 26cc unit is also underpowered compared to my older 25cc trimmer.
Jul 20, 2010 | Homelite Factory Reconditioned 26cc...
How to restring dual feed trimmer
YOU MUST REMOVE THE STRING HEAD YOU SHOULD HAVE TWO PEICES THE IUTER HOUSING YOU SHOULD CLEAN THE INNER SPOOL REMOVE ANY OLD STRING AND LOOK ON THE BOTTOM THERE SHOULD BEARROWS TO TELL YOU WHICH WAY TO WIND THE NEW STRING
Aug 16, 2009 | Homelite Garden
How to change the string
If it is a duel line trimmer then:
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Jun 29, 2009 | Homelite Mighty Lite Lawn Trimmer
Need string for Homelite trimmer (Model UT20042)
Genarally the size of line for that size of line trimmer is 2.0mm
May 07, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Homelite Consumer Products 4.0 Amp, 13 In. Trimmer Logo
267 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
